348 no power to a/c heater control panel | Page 2 | FerrariChat
Discussion in '348/355' started by iflylow90, May 25, 2008.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    The 30A fuse provides permanent 12V to the A/C control box (Pin 1) only for the purpose of maintaining the clock and the memory. The box comes "alive" when 12V is also switched "on" to Pin 3 by the ignition switch so the box needs both supplies to function properly. The pinout below shows how the power is connected to the A/C box (plus the pin for the heater water pump).
  2. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    Yes, that's the main power fuse. Fuse 6 provides key power to the panel also.
  3. Pellegrini
    Pellegrini Rookie
    Jun 4, 2024
    4
    Yves Chung
    Ok thx Guys..
    So probably the unit is dead.
    Perfect timing Caus im going on roadtrip next week to visit the factories in Modena and Bologna..
  4. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    954
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    You need to eyeball the 30 A fuse yourself.
    It’s a phaff to remove the trunk lining to access and I suspect he ( your mechanic) can’t be arsed .
    plenty of threads with pics on hear .
    Under all this carefully push away and you will see it .
    Most relocate it and use a different 30 A reset fuse . I placed mine by the AC dryer so I can click it back easily without the ball ache of dismantling the front of the car .
  5. Pellegrini
    Pellegrini Rookie
    Jun 4, 2024
    4
    Yves Chung
    I only removed the trunk liner partially.
    ( took 5min) The fuse is on the right of the 2 green relays. My car is from 92, maybe its different from another yearbuild..
    Anyway its still intact. Cant it be the relay instead of the fuse?
  6. Qavion
    14,601
    Ian Riddell
    We’ve seen melted wires on the relay sockets, too.
    Have you tried shaking the wiring at the back of the control panel?
  7. Portofino
    Sep 17, 2011
    954
    Portofino
    It’s the fuse holder and it’s wires that burn …..loosing the connection leaving a intact fuse .
    Qavion likes this.
  8. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    794
    Treasure Coast Florida
    MATT
    AC panels are junk and have long been a topic on this chat mine was so bad that I would get in the car and never knowing if it was going to work usually I could just slap the side of it and it would come back on. I recently found that every few months just by simply unplugging the main plug harness and plugging it back in I can get three or four months of trouble for use out of it worth a try it is a multi-pin connector. Easy access and can be done and situ just remove the passenger side kick panel
  9. Pellegrini
    Pellegrini Rookie
    Jun 4, 2024
    4
    Yves Chung
    Yes got it back to work! Kinda did the same.. unplugged the relay and fuse and when i plugged it back, it worked again.
    Thx and have a good weekend!
    Qavion likes this.
  10. Qavion
    14,601
    Ian Riddell
