348 or F355 | Page 2 | FerrariChat
348 or F355
Discussion in '348/355' started by fdekeu, Oct 1, 2009.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yeah, cut the new belt and then super glue it back together. Should be good for 3yrs/30k.
    Hahahahahaaaaaa!!!!
  2. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    Lol!! Loctite make a strong superglue. ;);)
  3. PAP 348
    Dec 10, 2005
    100,234
    Pap
    #28 PAP 348, Oct 1, 2009
  4. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Joking aside the fact is that's true, you don't need to remove the pulley. The center bolt is undone and the pulley is pulled forward enough to slide the new belts in. There is no twisting of the belts either before anyone mentions it, the belt only has to slide behind the pulley. For example pulling the pulley forward even by 10-15mm allows the 7mm belt to easly slide behind the pulley.
    Why swing a door wide open to the wall to walk through. When you can easily walk through a door half open just as easily:)
  5. PAP 348
    Dec 10, 2005
    100,234
    Pap
    +1! Thats how its done. :D:D
    I dont know WHAT that person was thinking when he cut out that cross-member! Maybe had to remove the pulley? :p:p
  6. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Maybe he just needed someplace to rest his arm on?
    :D
  7. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Well I'm still pulling the whole thing out.
  8. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    lol
  9. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #34 sambomydog, Oct 2, 2009
    :D....Sorry have to do this, i am only trying to help..:D
    Look at this video... http://www.youtube.com/watch?v=kvrlI3xGRaE
    Heres the translation into English from Italian...:D (borrowed from another forum)
    "In 1991 Montezemolo bought himself a yellow 348. One day he finds himself at a red light and a black GTI pulls up to him and beats him to the next light. Guy rolls down his window and in a Roman accent says "Monteze' this goes better than that". He goes back to the office without telling anyone what just happened and requests specs on the 348. This engineer by the name of Lombardi says to him "I'm the Ron Dennis of Ferrari". He goes on to say the 348 has the best in class acceleration. Montezemolo sits quietly through the presentation. He then says "Boys...unfortunately I'm a client of this ****ty car. It makes too much noise and barely moves". He then invited Niki Lauda to try this car (348) and he completely agreed with him."
  10. KKSBA
    KKSBA F1 World Champ
    15,303
    SBarbara-La Jolla CA
    KKSBA
    Wow! Depressing for 348 owners I'm sure as LDM is so well respected that anything he says must be true.
    It is quite shocking now that it has been translated...
  11. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Na i wouldnt say that........But i agree with Niki Lauda:D:D
  12. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    I am very happy and very proud to own the worst Ferrari ever made. I have no intention to ever sell it, I will add more Ferraris to the collection if I ever want to get a different model, but the worst Ferrari ever made will stay with me forever.
  13. 348SStb
    348SStb F1 Rookie
    #38 348SStb, Oct 2, 2009
    Look, not to hijack this thread and further its distance from the original topic...
    But look. It's well established that changing the timing belts and bearings and "servicing" the engine while the engine is in the car constitute the dumbest way to service the 348/355 engine. Ask any qualified mechanic. The best mechanics in the United States have commented on this board as to why over and over.
    Can the 348/355 engine be "serviced" with the engine in? Sure. Just spend almost the same amount of time removing the gas tanks. Is it the bonehead, bass-ackwards, penny-wise pound-foolish way to do it? You betcha. (Sorry Ernie you're certainly no bonehead :D And folks certainly should listen to you when you say it's the wrong way to do it since you did it yourself.)
    Lots of care needs to be taken with various steps of the process, such as the resealing of the valve covers. This is crucial. The same goes for putting the belts at proper tension and various other unmentioned important steps. Doing all these with the engine out of the car allows for the utmost precision and care and therefore the longevity of the job. Doing it with the engine in is, for lack of a better word, a fudgejob.
    Please. Don't buy a Testarossa, Mondial t, 348, or 355 if you cannot afford to either take the engine out yourself or have your mechanic do it for you the proper way.
    Case closed, please?
  14. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #39 sambomydog, Oct 2, 2009
    Being that you bought it up. Equally there are also the best in Europe (dealers and specialists) that do it both ways. Regardless of what the best in the United States say.
    Now you can close the case:)
  15. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Whoa, whoa, whoa!!!
    I think you're confused.
    I didn't take out the tank to change the belt. NO!! I took out the tank to fix the stupid thing because the spot welds holding the baffles inside the tank pulled out and the tank was leaking. I also took the opportunity to wiggle inside the space for the tank just to see what kind of room there was in there.
    When I did my major I pulled the whole engine out, the proper way. And will be pulling the whole engine again to do the belts this next time around. Especially after having been inside the cramped space were the tank goes. No way would you catch me trying to change the belt by pulling the tank.
    Remove the engine to change the belts.
  16. PAP 348
    Dec 10, 2005
    100,234
    Pap
    Lol! :p:p
  17. 348SStb
    348SStb F1 Rookie
    Ah ah. I understand now.
  18. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    the proper way to change the belts in an F355, according to the Ferrari workshop times book is either engine out OR fuel tank out.
    but what would they know?
    however, on the 355 the tank is secured by mounts that are not in slots like the 348 and therefore the tank wont come out easily.
    anyone know what the trick is to get it out?
  19. jm348
    jm348 F1 Rookie
    Mar 21, 2007
    3,017
    Redondo Beach, CA
    Jeff M
    I have owned a 348 and currently have a 355.....I loved my 348 as it was my first Ferrari. I do miss the raw feel of that car. However, the 355 is simply amazing and I couldn't go back to a 348 after the 355. The power difference is huge, smooth 6-speed, the exhaust sound is incredible and the power top, seat and more modern feel inside I think all make for a better car. I do wish the power steering on the 355 had a bit less assist though...:eek:
    Had 348 for 2 years and currently 2.5 for the 355 and both have been problem free.
  20. KKSBA
    15,303
    KKSBA
    There you have it, 355 Winner! 348 Fail. :D
