348 - 348 Parts Thread | Page 28 | FerrariChat
348 348 Parts Thread
Discussion in '348/355' started by plugzit, Mar 1, 2005.
  1. I'm gone
    I'm gone Formula Junior
    Feb 5, 2006
    619
    Phoenix,az
    Brian
  2. Jatzz
    Jatzz Rookie
    Oct 31, 2023
    15
    Australia
    Alex
    Do 348s have a tow hook hole cover from factory?
    If so, is there a part number please? I’ve been unable to find one.
    My new to me car had a tow hook (non original) mounted which I’ve now removed and would like to cover the hole. (Front tow hook)
  3. m.stojanovic
    m.stojanovic F1 Rookie
    3,324
    Serbia - Niš
    Miroljub Stojanovic
    You should check the front bumper diagram, it should be there somewhere. But, as far as I know, it is just a simple flat black rubber plug so a universal automotive body plug of suitable diameter will do.
  4. Qavion
    Qavion F1 World Champ
    14,663
    Ian Riddell
    As Miro says...
    P/N 14507987
    ILLA NOIZ likes this.
  5. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    235
    España - Madrid
    Does anyone know the reference of the 12 o-rings that the flywheel and the large gasket have? I have searched and can't find anything
  6. m.stojanovic
    3,324
    Serbia - Niš
    Miroljub Stojanovic
    What "large gasket" are you referring to?
  7. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    235
    España - Madrid
    the big one that goes around the flywheel
  8. m.stojanovic
    3,324
    Serbia - Niš
    Miroljub Stojanovic
    Large O-Ring: 240 (or 242) x 3 mm
    Small O-Rings: 8.0 x 1.5 mm
    Manuel.G likes this.
  9. Dummyfatpigpoo
    Nov 20, 2024
    2
    Robert Weaver
  10. rob58
    rob58 Karting
    May 30, 2020
    140
    CT.
    Robert Orris
  11. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    I will check mine when I get home, definitely one light and the spark plug socket, but not sure if that 3rd one is a light as well as that one in your picture doesn't seem to fit the spot it goes in.
  12. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    235
    España - Madrid
  13. m.stojanovic
    3,324
    Serbia - Niš
    Miroljub Stojanovic
    It is to light the key hole (from inside) to make it easier to find.
  14. Dummyfatpigpoo
    Nov 20, 2024
    2
    Robert Weaver
    Yes, back on the tool kit question…. No one seems to know what goes/came in that fitted opening where the small light bulb is pictured? Rectangle shaped with the round indent deeper on one end. Also, can someone confirm the spark plug socket size? (Odds of finding a matching Kraftwerk one seem pretty low but somehow it makes me feel better to not have the space empty ). Finally, the leather straps in my (f)trunk were removed…. I have sourced replacements but am not sure of attachment location and method? (Firewall or front wall? Rivets?). Photos would be a big help! Thx in advance.
  15. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,555
    Jeff
  16. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    235
    España - Madrid
    photos of different cars on the internet...
  17. Brush
    Brush Karting
    Aug 26, 2023
    56
    Bruno
    Hi guys, is there any cross reference for the fuel pressure regulator of a gts? I think it's a 3.8 bar model right?
  18. m.stojanovic
    3,324
    Serbia - Niš
    Miroljub Stojanovic
    This is the info I found. See what Bosch number you currently have and look for the shown equivalents (I cannot comment on their quality/reliability).
  19. Shiva_Austria
    Shiva_Austria Karting
    Oct 7, 2013
    61
    Austria
    Does anyone knows where I could find these 2 parts?
    Sold out at Ferrair & Eurospares ....
    62153300 RH inner gasket
    62153400 LH inner gasket
    Many thanks
    ChrisEnzo from Austria
  20. Brush
    Brush Karting
    Aug 26, 2023
    56
    Bruno
    i did not uninstall my original pressure regulator yet and have access to only a part of the reference but it seems ending with '372'. Quite strange...
  21. m.stojanovic
    3,324
    Serbia - Niš
    Miroljub Stojanovic
    You may have looked at the batch or something number. Look for the number next to the Bosch logo, starting with 0 280 .., top of the two numbers seen on the picture (if your current FPRs are Bosch).
  22. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
  23. Chippa
    Chippa Rookie
    Nov 8, 2018
    36
    New Zealand
    Colin
    The door panel “Christmas (or for!) Tree” nylon clips on my 348 had lost their barbs, and weren’t holding the panel to the door frame any longer. Found identicals at Carclips.co.nz part# CC11292 (for Citroen/Peugeot). Cheers.
    ILLA NOIZ and f355spider like this.
  24. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Out of stock :(
    I'm rewiring my door wiring and figure I'm gonna break some doing all the rewire.
  25. Chippa
    Chippa Rookie
    Nov 8, 2018
    36
    New Zealand
    Colin
    Oh, that's so disappointing! I called them today and they said that new stock will arrive in two months :)(). But, on the positive side, I found I have 6 clips left from the stock I bought recently, and I'm happy to send them to you (for the cost of postage), if you wish? PM me. Cheers Colin
    But I am puzzled.... the door frame has 4 holes, presumably to accept 4 of these Xmas Tree style clips. But my panels only have 3 clips, and no provision for a clip of any kind to go into the 4th hole (at the outer edge of the door frame). Instead, a narrow beading runs down the edge of the door, with self-tappers through the beading, the panel, and into the frame. Seems kinda rude? Anybody have a clip fixed on the panel (Araldite maybe?), utilising the 4 hole as intended?
