348 - 348 Parts Thread | Page 9 | FerrariChat
348 348 Parts Thread
Discussion in '348/355' started by plugzit, Mar 1, 2005.
  1. randyleepublic
    randyleepublic Formula Junior
    Dec 2, 2007
    825
    Beautiful Reno
    The Junior Timer Connectors that Amp's website depicts are the type that take the plugs. They do not show another type. I conclude that the other type has been obsoleted. The lip that retains the rubber boot is still there, but they list no boots. As for weatherproofness, if you had to use one or the other, I don't think that there is any question that the plugs are superior. It's simple to effectively seal one round body in the center of a round hole, but to seal a bundle of round bodies is nearly impossible. All the "Sealed" types use the plugs, only they add retainer clamps to secure the plugs.
    Not saying that I would not use boots if I had them along with plugs, I would, but I wouldn't worry about how tight they were either. Best I think is to replace the whole mess with something else and modify the clamp as needed. It seems silly to have the crank sensors set up like that as if they needed to be replaced every 6 months. Mine were failing, but I bet they were the originals: that's 18 years of service.
  2. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    I never saw those pics - that does fit well. I remember looking at that male connector and thinking it wouldn't really fit well.... Damn internet pictures. Thanks Ian, it appears that you can get replaceable male connectors that work well.
  3. haris6000
    haris6000 Rookie
    Mar 6, 2009
    1
    Hi there, I own a 1990 Ferrari 348 TS, I was wondering where I could get some reasonable priced after market brake pads with those sensor wires?
    Thanks in advance!
  4. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Don't know if they have the sensors, try these:
    http://www.buybrakes.com/axxis/apps-Ferrari.html
    --Mike
  5. WillW
    WillW Karting
    May 23, 2005
    209
    Helsinki, Finland
    Ville
    Porterfields from Ricambi :)
  6. Marco Bussadori
    Marco Bussadori Formula Junior
    Aug 6, 2007
    430
    London
    Marco Bussadori
    www.autoelectricsupplies.co.uk. They ship worldwide, sell quantities from 1 to kingdom come and always have stock. I'm not affiliated nor do I have an interest but for helping fellow F-chatters get what they need.
    I have practically changed all 2,3 and 6 pin Power Timer male/Female in my engine with their parts.
    Slop some dielectric grease in the connector and fill the boot with silicone sealant (gasket maker) and you'll find the connector gets stiffer, will never have moisture problems and the rubber will never crack.
    My new plugs have done 10k miles in 15 months and still look perfectly clean and new (including the CPS ones which get soaked in the oil I'm leaking from the front of the engine!
    Marco
  7. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Don't forget the part #:
    I love a story with a happy ending...
  10. agnello11
    agnello11 Karting
    May 27, 2008
    84
    348 Delco Remy alternator rebuild parts - in the UK. Just while I have the info to hand I will throw some numbers in here for the Rectifier and Regulator on the Delco-Remy CS130 series alternator as fitted to early 348s.
    The original Rectifier carried part no. DR5162. In the UK, a direct replacement would be RTF39824 from Wood Auto Supplies Ltd. http://www.woodauto.com/Component.aspx?Ref=RTF39824 They also do a heavy duty version RTF39834 - which is recommended.
    The Voltage regulator replacement would be VRG3626 from Wood Auto Supplies Ltd. http://www.woodauto.com/Component.aspx?Ref=VRG3626 and there is masses of cross-referencing available from that sight to other vehicles.
    There is an excellent write-up on CS130 series Alternators here:- http://www.alternatorparts.com/cs130_sbpage1.htm
    Parts kit for CS130 series in the US:- http://www.alternatorparts.com/D1-5130_kit_contents.htm or Elreg as described elsewhere here.
  11. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
  12. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
  13. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Guys - Are the Walkers a better quality or just better price? Aren't all O2's created equal?
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    No, there are internal samplers and external samplers and faster sensors that don't last as long and slower sensors that last longer and different price points and different plug-n-play packages...but this thread is not really the place for that sort of discussion. Suffice it to say that in my opinion the Borg-Warner and Walker O2's are better (and cheaper!) than Bosch O2's for 348's.
  15. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I also wouldn't have had a problem buying the B-W's, and just meant to indicate I was happy with the Walkers, especially for the price!
  16. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
    One advantage of the universal fit Walkers was that they come with top quality butt splices: first you crimp them, then you solder them through the little hole in the middle, finally you slide the heat shrink over them and shrink it. No flaky splices with that set up, although to be sure, I did add a larger piece of heat shrink to cover all four wires.
  17. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    #218 FandLcars, Apr 27, 2009
  18. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    Philip Barnard-Brown
    Idle control valve replacement numbers part.
    Bosch - 028 140 505 & 0280140505
    Alfa Romeo - 60813324 & 7637024
    Ferrari - 142432
    Fiat - 60562537
    Fiat Lancia - 60813324 & 7637024
    Hyundia - 3515022000
    Iveco - 7637024
    Kia - 0K011-20-660
    Saab - 8857179
    VW - 034 133 455
    Hope this helps someone in the future.
  19. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,631
    The Brickyard
    The Bad Guy
    #220 ernie, May 8, 2009
    Early 348 front wheel bearings.
    The way to tell if you have the early bearing is to look on the back of the front wheel hub. If you have 6 bolts holding the bearing in place then you have the early version. The bearings come off of a 1985-1991 Citroen CX
    The SKF part number is: 441696M
    The SNR part number is: TGB10894S03
    Here is a link to the thread I post on how I removed mine. http://ferrarichat.com/forum/showthread.php?t=241309
    You can find then from a bearing supplier for about $250 each.
  20. SHEMM
    SHEMM Formula Junior
    Jul 8, 2007
    393
    Toronto
    ILIO
    My flywheel fell apart recently - price for a new one is not in the cards. Anyone know where I should begin to look for a decent used one at a reasonable price?
    Thanks,
    Ilio
  21. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
  22. ernie
    Nov 19, 2001
    22,631
    The Brickyard
    The Bad Guy
    #223 ernie, Jun 10, 2009
    Charcoal Canister Purge Valve - Bosch part number 0 280 142 150.
    The same part is used on a lot of cars but the two cheapest I found where:
    1992 BMW (E36) 318i,
    BMW part number 13901726705
    $100 was the cheapest I found from a BMW dealer
    1993 Hyundai Scoupe
    Hyundai part number 28910-22000 (original number) and the updated part number is 28910-22010.
    I ended up buying mine from the Hyundai for $87.
    Here is the link on how to remove them. http://ferrarichat.com/forum/showthread.php?t=241642
  23. mihakrapez
    mihakrapez Karting
    Aug 16, 2007
    131
    Slovenia-Europe
    Miha
    I have them on stock.
    Fast road 80€/set
    normal 40€/set
    Can ship to us (extra 10€ for shipping)
    cheers
  24. mihakrapez
    mihakrapez Karting
    Aug 16, 2007
    131
    Slovenia-Europe
    Miha
    Does anyone know the producer of OM timing belt and what is the code:
    Would like to find aftermarket one (I am sure that it fits somewhere else besides 348)
