348 Plenum Redesign | Page 4 | FerrariChat
348 Plenum Redesign
Discussion in '348/355' started by vvassallo, Jan 31, 2013.
  1. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    if memory serves, you'll get an additional 1-1.5% gains @ speeds over 100mph... and thats only if the intake opening is correctly designed and positioned at a high pressure area. most of the boards theory of high flow, high velocity is inverse of what u actually want in an airbox leading up to an intake. you want to SLOW down the incoming air at the throttle plates to build pressure. but this if fchat after all....
  2. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Guys guys guys guys..... what's with all this harmonic flatulence stuff.
    Just get some Jenvey throttle bodies, attach it to the engine, new ECU and whammo.... you got yourself 360 Stradale performance.
    It's been done and it works.
  3. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Yeah we know. What part of "affordable and smog legal" did u not get? :p It might end up here anyway, but we're looking at all options. :) Personmally, I think our tbs, plenum airboxes, etc. are all choking the sheit out of the engine. If I had the cash, I'd redesign the lot of it.
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,758
    followed by::
    Sound like Ernie needs to get a clue...........
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    #80 ernie, Feb 12, 2013
    Sounds like you still haven't built anything.
  6. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Keep on with the ideas as I'm anxious to do some engine modding.
    Mine would have been done by now if all my parts hadn't been destroyed.
    One question. What would the effect of installing 355 throttle bodies on the 348 engine be?
  7. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,927
    Richmond
    Pete
    With stock heads and cams?
    I really don't think Ferrari would have left a ton of power on the table just in intake design, it would make no sense to build the heads and cams for 360-380hp and then choke it off with a poorly designed intake. It would make more sense that the heads and cams are designed for 320hp and the intake to match it. You might gain 10hp after throwing 10k at the engine in bolt ons, but is it really worth it? 10k would get you some well ported heads and reground cams to match, or even a complete 355 longblock...
    The flow numbers posted earlier in the thread support that, with stock sized valves the intake has pretty much no influence on the flow, meaning it's not the restriction on a stock engine.
    Good luck, but it seems to me you're starting at the ends of the engine when you should be starting at the middle and then working your way out. CARB will have no way to tell your engine isn't completely stock if you port the heads and re-grind the cams. Just keep the overlap similar to stock and you shouldn't have emissions issues. You'll also be able to bump compression if you go bigger on the cams giving you some gains across the whole rpm range. I've played with this stuff before on other engine families, you start with identifying your limitations first and then build around that. Until you identify exactly what your limitations are, you're throwing money and time away with a shotgun approach. It's the ready fire aim mentality vs. ready aim fire.
  8. plugzit
    plugzit F1 Veteran
    7,810
    Redondo Beach, CA
    Bruce Bogart
    I've done it-it was a Stooge project. See the thread "355 throttle bodies on a 348". Really not hard other than machining an adaptor. Ran very good with stock and slightly modded ECU, but didn't dyno it. My goal was to do away with the MAFs and run velocity stacks so I was (am) going to machine one more part for a sensor pickup for the Haltec. See that thread for much more info.
  9. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    We actually hope to strap the 355 tbs on the race car and see just what that alone does to performance. That's because we can tune the Motec on it much more easily than our chipped Motronics.
    Bob, we get what you are saying, but the Stooge mod budget is somewhat more modest than, say yours. ;) So, yes we are doing it on the cheap and "starting in the middle" as you say. That's because starting at the beginning is out of our financial reach. Plus, on a personal note, if I were to consider that route, I'd just as soon swap out the 348 for a nice 355 or even (gasp) a 550.
  10. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Yes, stock heads and cams.
    You'd only change the cams to keep up with 430 scuds!!
    :D
  11. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    No not a ton, but there is evidence that they were not as thorough in 1989 as they are now in their design and flow work. Obviously they left a bit in the exhaust system. Now we want to see what's left on the top end. Thiis is the lower hanging fruit. After that, we will see just how much it takes to get more performance.
  12. time
    time Formula Junior
    Sep 15, 2011
    511
    DeeGee
    #87 time, Feb 13, 2013
    I started down this path last summer but life happened and I pushed it to the side. The added volume of my Euro influenced plenum pictured below didn't make power by itself. Step 2 was to sort out the rest of the intake system. I purchased the parts but haven't had the time to make it happen. The parts include a pair of 65mm tb's including Bosch tps sensors, 355 air filter boxes (I believe Bruce has the plenum boxes), aluminum mandrel bends and couplers to match. I'm on board with a Stooge intake parts pool. It gives me an excuse to wrap up what I've started.
    At some point I plan to install management, the LM engine and be done with the 348 power quest.
    Plus, I have the EV itch... my first time publicly admitting this problem.
  13. fatbillybob
    Aug 10, 2002
    29,343
    socal
    I thought I said my last word in this post but eee gaddd who welded that!!!
  14. time
    time Formula Junior
    Sep 15, 2011
    511
    DeeGee
    I didn't think the were ugly enough so I globbed some JB weld on the pin holes just for you. It was sliced up for testing not aesthetics and by the time its finished I hope to have included some duct tape, bailing wire, and zip ties. Thanks for the kind words though.
  15. plugzit
    plugzit F1 Veteran
    7,810
    Redondo Beach, CA
    Bruce Bogart
    Makes me proud to be a stooge!
  16. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    LOL
    You forgot chewing gum.
  17. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    +1
    Quality Stooge welds if I must say.
  18. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    +1
    This might be the best quote I've seen in a long time
    I'm in the market for a newer Fcar, but I am keeping my 348 because I love it...
  19. Dohangs
    Dohangs F1 Rookie
    3,129
    Florida
    Spiro
    I agree with you. I love my 348 but wouldn't mind it to be a little faster. My 430 is fast enough but I could use a little more in the 348.
  20. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    Read the thread 348 Dyno runs.. Fabspeed has my car and is adding some great bolt on horse power mods. There will soon be some real solutions for our cars
  21. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    Agreed , 320 hp from a n/a 3.4 , i don't think they left anything on the table. i'm sure everything is perfectly matched to make max hp. It's a Ferrari , not a freakin civic!
  22. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Our next Stooge project should be getting a better engine managment system. We are definitely losing out on performance tweeks because no one can figure out how to hop up a Motronic (or they're all dead) and it's old school chips that cannot be tuned on the fly - one map whatever it is. ;)
  23. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    AEM makes a nice setup along with a few others. If I did not have to OBD test yearly I would go stand alone for sure with some of those pulse injectors and real spark.
    348/355 would be a different animal with proper engine management.
  24. zakeen
    zakeen Formula Junior
    Aug 29, 2004
    989
    Czech Republic
    My 348 has been sitting in my garage for a month now without the engine in it. Im getting some work done on the motor. New pistons, rods, cam cranks, etc.... This was the first step. How the company works is they take your engine, measure everything, flow tests, etc.... and come back with what they recommend. The full break down test was 50,000kc, 2000euro(about). I was in there yesterday and he kinda said the intake design is terrible. While this was not the first thing I wanted to do in step one he said that it would be about 12-15% it is holding back on the torque gains.
    Now Im waiting on a quote to have a custom one made. I will report back when I have some more info.
  25. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Since the 358 race car has Motec and we kind of know our way around that, I was thinking of doing one for the SS. Motec 48 with ignition expanders. Problem is, that once you dive down this hole you don't come back for a retrofit if it doesn't work.
    Wait - unless, you create an adapter for the stock ECU connector block. Hmmm, never considered that. But then we have 2 of those and the Motec is a single unit. Hmm, still possible.
