348 problems and fixes | Page 4 | FerrariChat
Discussion in '348/355' started by jford10014, Oct 5, 2015.
  1. jford10014
    jford10014 F1 Rookie
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    my next task was to give the doors and overhaul. The first goal was to fix the broken lock with the hill engineering upgrade. This would allow me to lock the doors !
    The second goal was to try and fix the window speed. I bought the kit from Home Page which will hopefully do the trick. (or at least help).
    Starting with the passenger side, I measured down took 8 seconds, and up took 11 seconds.
  2. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #77 jford10014, Oct 27, 2015
    First step of removing the door trim is to remove the thin strip at the edge of the door. This has four screws and is in two pieces.
  3. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #78 jford10014, Oct 27, 2015
  4. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #79 jford10014, Oct 27, 2015
    The bottom section is held on with plastic clips and pulls off. There is a high chance the clips will break when you do this so I ordered a bag of new ones.
  5. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #80 jford10014, Oct 27, 2015
    The next section I believe has one screw at the end of the door, and plastic clips, but in my case the screw is missing, so this also pulls off.
  6. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #81 jford10014, Oct 27, 2015
  7. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #82 jford10014, Oct 27, 2015
  8. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #83 jford10014, Oct 27, 2015
  9. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #84 jford10014, Oct 27, 2015
  10. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #85 jford10014, Oct 27, 2015
  11. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #86 jford10014, Oct 27, 2015
  12. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #87 jford10014, Oct 27, 2015
  13. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #88 jford10014, Oct 27, 2015
  14. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #89 jford10014, Oct 27, 2015
  15. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #90 jford10014, Oct 27, 2015
  16. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #91 jford10014, Oct 27, 2015
  17. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #92 jford10014, Oct 27, 2015
    Some other posts I've read say that taking the door strakes off the front is optional. It takes a few mins to do this, and allows much better access so I took mine off. There are two hidden bolts on the inside of the door.
  18. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #93 jford10014, Oct 27, 2015
    And four hex screews on the front of the door. My screws were very rusty and two of them the head was nearly stripped so I will be replacing them.
  19. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Cool to see the reflection of the 308 in the door of the 348. :)
  20. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Hi mike. I didn't notice before you pointed it out, but it does look pretty cool !
  21. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #96 jford10014, Oct 28, 2015
  22. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #97 jford10014, Oct 28, 2015
  23. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #98 jford10014, Oct 28, 2015
  24. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #99 jford10014, Oct 28, 2015
  25. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #100 jford10014, Oct 28, 2015
