348 problems and fixes | Page 7 | FerrariChat
Discussion in '348/355' started by jford10014, Oct 5, 2015.
  1. jford10014
    jford10014 F1 Rookie
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    At this point, I reinstalled the glass and the inner door. I don't have pictures of this, as I was very paranoid that I would break the glass, so I needed both hands. The glass and assembly is twisted back into the door. Make sure that the motor, which seems to dangle, doesn't hit the glass. The the inner door goes back on. Some bolts of the inner door attached the inner door to the frame, and other bolts attached the glass guides to the back of the inner door.
  2. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #152 jford10014, Nov 1, 2015
  3. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    the above picture is part of the kit sold at Home Page. What this kit does is as follows. Most electrical components on a car only have 1 wire going to them, as the -ve side of the battery is connected to the car frame and hence any electrial component can get the -ve side from the car frame. In the case of the electrical window motor, there are two wides going to the motor, as the polarity of the wires is reversed depending on up/down on the switch. Wire = resistance so in the case of the window motor you have double the resistance as double the amount of wire.
    This little mod taps into the two wires as well as a third wire to the ground. When the mod detects the switch being active, if routes the other wire to the ground, thus halving the about of electrical cable and (in theory) having the resistance. Less resistance = more volatage = faster windows
  4. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #154 jford10014, Nov 1, 2015
  5. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #155 jford10014, Nov 1, 2015
  6. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #156 jford10014, Nov 1, 2015
  7. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #157 jford10014, Nov 1, 2015
  8. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Ok. Ran out of photos. Here is the scoop. The window went back in, and I tested it. After all the cleaning / greasing / mod kit the window is still very slow. The mod kit certainly helps. If you hold the ground off and on the door whilst operating the window, you can see that it visibly speeds up. Unfortunately in my case, it goes from very very slow to very slow.
    I also have a problem where the window seems to travel too much up. I would say it overshoots my about 1/8 inch. When the door is closed, it's travelled so much up that there is a very visible gap between the door and the rubber. Pretty sure it wasn't like that before.
    Does anyone know how to adjust the window ? I know there are little stoppers that you can adjust, but in my case i have all the way out, and when I feel with my fingers I can't see they are touching anything when the window is all the way at the top.
    I'm wondering if the gap issue i because I put on the new rubbers / brackets holding the window at the bottom. Perhaps I didn't push them all the way home, and this is why the window is travelling to far.
    The other odd thing, is that if you just connect the motor, without the assembly to the wiring, and push the swtich, it seems to turn and turn for ever. So the question is, what is cutting out the motor when the window reaches either the top or the bottom ?
    I had to leave this for another day, but I'm now wondering what to do next. In summary :
    - Windows are still very very slow
    - Window seems to travel to high.
    - When the window is in the middle of it's run, it seems to be a little faster, but gets slow at the top. (I read somewhere that you can undo the little plastic triangle sale and perhaps this is how you adjust it ?)
    I'm wondering also if I should scrap the fastferrariwindow mod and go for the 2-relay approach that I've read about.
    Any thoughts welcome ....
  9. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Also - I have one other question.
    On the 308, the motors were packed with grease which overtime hardens and effects the speed of the windows. I have taken out my 308 motors and cleaned them a few years ago. Does the 348 suffer from the same problem ? I know I read somewhere this week about the 2-relay solution and it was noted that you must clean out the motor before doing this, as the motor could burn out if you apply the 12v 2relay fix.
    Having searched for 348 windows I didn't see any reference to this, and could only find one post where somebody actually took the motor apart.
    Thoughts welcome
  10. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #160 jford10014, Nov 8, 2015
  11. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #161 jford10014, Nov 8, 2015
  12. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #162 jford10014, Nov 8, 2015
    So. I speculated that the reason the window was going up to high has the glass wasn't fully seated in The new brackets/rubbers. So I took the whole think apart again and got out my fine adjustment tool.
  13. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #163 jford10014, Nov 8, 2015
    As I was resembling the inner door, there is a cable which connects the door latch pull on the inside to the door lock assembly. When connecting to the door lock, there was too much tension in the wire. It was pulling the lever on the door lock even when in the open position. I tried adjusting the adjuster but no luck.
    On closer inspection of the inner door I found this. The wire had snapped and the PO had bodged it. Unfortunately the "fix" didn't work as there is too much tension in the line. This has the affect of pulling the lever to much and the lock assembly jams or the central locks "dance".
    I now fully understand why my passenger door got jammed back in August. I will be buying another cable !
  14. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,553
    Jeff
    #164 348Jeff, Nov 8, 2015
  15. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thanks for the speaker pics, jford10014. IIRC, the 348 was delivered with speakers installed, but without a head unit or amp. I thought the original speakers were two-piece components with separate tweeters behind the corner dash vents. Could be completely wrong though, but seems like there are pics here to support that. In any case, it's cool to know that there's a speaker out there that bolts right in.
    As to your window going too high, I can't help but wonder if it has something to do with the fact that it isn't contacting the adjustable stops. Is it possible that pieces are missing? Perhaps someone replaced the side glass previously but left those parts out? Seems odd that there are stops, and that they're even adjustable like they should be, and yet they're not serving their purpose. Maybe someone who's done this before can help, or maybe it's in a previous thread?
  16. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Hi,
    So I just updated my profile so people won't call me jford10014 anymore - HA !
    Thanks for the replies. I think (?) I've fixed my window going up to high. I think the "fine adjustment tool" did the trick. The new brackets are very tight, and I don't think they were pushed all the way home. Or I just put everything back differently ? I'm still curious how the motor knows how to stop at the top and the bottom. When the motor is detached from the assembly, and given power, it just turns forever.
    All this talk of speakers has made me add "new stereo" to the list of projects. My 308 came with (and still has !) a tape deck, and my 348 came with a CD player. Yeah ! if only I owned some tapes or CDs.....I was looking on amazon today at single DIN bluetooth stereos...
    Jeff : Thanks for the reply. I have read your thread from start to end. If anyone is reading this, and wants a good thread, check out Jeff's. The level of detail is amazing and inspiring. There are many procedures, outlined in great detail, which I will be doing to my car. Namely, the section on the engine bay foam, the piston in the center console, the relay replacement (I ordered 6 last week), the painting of the capliers. On and on. Great read. Jeff - I will be in the UK at the end of the month, and will be visiting Tesco's for some carpet cleaner !
    Having re-read the pages Jeff has posted above, I will be taking my lock out again, so I can respray the barrell !
    So - as I was upstate with just my son this past weekend, and hence had an opputunity to take the car out, I decided to put the passenger door back together without the cable to open it from the inside. So - here goes :
    The glass goes into the door, followed by the inner door. The glass assembly needs to be connected to the inner door, as well as the inner door connected to the frame.
  17. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #167 jford10014, Nov 9, 2015
  18. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #168 jford10014, Nov 9, 2015
  19. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #169 jford10014, Nov 9, 2015
  20. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #170 jford10014, Nov 9, 2015
  21. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #171 jford10014, Nov 9, 2015
  22. m.stojanovic
    m.stojanovic F1 Rookie
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    The motor is just stalled by the window top and bottom stops. Some cars have an overcurrent-thermo circuit breaker (self reset or manual reset) in the power supply to the windows to switch off the current if the window switch is kept on too long after it has hit its stop. In some cases, the circuit breaker will also cut-out if you try to close both windows at the same time.
  23. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Thanks Mirlojub for the explanation.
  24. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,553
    Jeff
    Jason, if you do take the lock out take the opportunity to replace the pins with Hills engineerig ones as its another common breakage :-(
  25. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Hi Mirlojub. I really meant to write more than that, but got distracted and hit send.
    So - you are saying that the power is also on at the motor when the switch is held down (assuming no cutout). So if you held your finger on the switch, then you would eventually burn the motor. I need to test this with a volt meter. Assuming that my FastFerrariWindows don't give an good result, I was reading about the 2-relay mod, but wanted to make sure this wouldn't have a negative effect on the motor if you held the button down accidently.
    Jeff - I did get the hill part. I'm also faced with the same choice as you w.r.t the srping. in the passenger door I did find the spring in the door, but in the drivers side I did not. I may just swap the driver / passenger around given that the drivers door would be the most used.
    I really liked (and was holding out hope) for your fix using the key chain rings, but i'm guessing that this didn't work. Why didn't it btw ?
