348 problems and fixes | Page 8 | FerrariChat
Discussion in '348/355' started by jford10014, Oct 5, 2015.
  1. jford10014
    jford10014 F1 Rookie
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #176 jford10014, Nov 10, 2015
  2. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #177 jford10014, Nov 10, 2015
  3. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #178 jford10014, Nov 10, 2015
  4. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #179 jford10014, Nov 10, 2015
  5. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #180 jford10014, Nov 10, 2015
  6. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #181 jford10014, Nov 10, 2015
  7. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #182 jford10014, Nov 10, 2015
  8. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #183 jford10014, Nov 10, 2015
    Credit to Jeff for this one. The hex screws which hold the side strakes to the door, two of mine were very rusty and the head had stripped.
    The photo is the exact screws you need if you want to replace. Thanks Jeff.
    As you can see, I couldn't get a smaller amount that 50 so if anyone wAnts one.....
  9. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #184 jford10014, Nov 10, 2015
  10. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #185 jford10014, Nov 10, 2015
  11. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,553
    Jeff
    The spring just wasnt strong enough so only worked once then stretched :-(
    I would bear the pain and pay for a spring kit or maybe look for a lock on ebay which includes the spring.
    BTW I think the window logo on your window up/down switch should be pointing forwards so check with the other side in case your switches are mixed up.
    I also painted my stainless screws black so they loked like originals plus also did another "set" in red to match the paintwork - like you I have spares! LOL
  12. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Great work and documentation as always, Jason. Glad you resolved the window height problem but I'm still curious as to why the adjustable stops apparently do not contact the window assembly.
    BTW, those screws are available here in the States at McMaster-Carr in case anyone needs them. I bought a box to use for mounting aluminum pedal covers. Nice to know they'll also work for the side strakes. :)
  13. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Hi. Thanks for the feedback. Agreed about the switch. I just ordered s new switch for the drivers side as one of mine the light is out. More to come on the Windows !
  14. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #189 jford10014, Nov 11, 2015
  15. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #190 jford10014, Nov 11, 2015
  16. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #191 jford10014, Nov 11, 2015
    I noticed the other day when doing my wiper project, that the little cap was missing off the passenger blade. As such the nut had rusted.
  17. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #192 jford10014, Nov 11, 2015
  18. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #193 jford10014, Nov 11, 2015
  19. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #194 jford10014, Nov 11, 2015
  20. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #195 jford10014, Nov 11, 2015
    On Sunday I started to take apart the drivers door. It really goes a lot faster if you are not taking pictures at each step !
    I discovered this. The picture show two rubber mountings which hold the center piece of the window assembly to the inner door. The reason this is an issue is that I'm pretty sure when I put the passenger door back together these were not there.
    With the window down, I open and closed the passenger door and did hear the motor smack against the inner door, so it's definitely loose. I know that I put back all the pieces I took out, so can only conclude this was always this way. Not good. I'm amazed the window assembly is still in one piece given that the motor is just swinging about.
    Call ricambi and Ferrari uk yesterday to try and buy these parts, and of course they are on back order. So I may have to improvise.
  21. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #196 jford10014, Nov 11, 2015
    One thing I didn't cover on the passenger door was taking the lock assembly apart. I did this already on the passenger door as the door jammed back in the summer. This is the drivers side.
  22. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #197 jford10014, Nov 11, 2015
  23. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    #198 jford10014, Nov 11, 2015
  24. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    You can probably get those rubber isolators in post #195 at McMaster-Carr as well.
  25. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Thanks Mike. I will check that out
