348 resetting of ECUs | Page 2 | FerrariChat
Discussion in '348/355' started by davey_jones, May 1, 2006.
  1. Llenroc
    Llenroc F1 Veteran
    5,606
    Colorado
    Vern
    Glad you found the problem always feels good when an engine is running normal again. Huh and I thought it was the O2 sensors, HaHaHa. Regards, Vern
  2. davey_jones
    davey_jones Formula Junior
    Sep 28, 2002
    781
    wherever it's sunny
    Dave
    no, you said it would be the thermo-couplers! :)
    It's the little things that eat away at you. Just took a load off my shoulders so to speak.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Sweet fix. You've got to feel good about putting that right.
  4. davey_jones
    Sep 28, 2002
    781
    wherever it's sunny
    Dave
    Anyone know the Magnecor warranty??
  5. vegas1
    vegas1 F1 Rookie
    Jul 28, 2004
    4,202
    Australia
    I have the knob/turn switch on my 348 which is also fitted with Motronic 2.7 ignition. Further, I have an aftermarket battery charger fitted on-board in the front trunk which connects direct to AC power for charging the battery.
    I assume from what has been discussed that one should not disconnect the battery (whether by turning the knob/switch or via direct disconnection of the lead at the actual battery) when the car is not in use, unless there is a problem with the battery. So is it safe to charge my battery with the AC current when the battery is connected and/or does this affect the ECU settings? Winter storage cars in the USA and UK must encounter the above situations when the car is not used regularly.
  6. Llenroc
    Llenroc F1 Veteran
    5,606
    Colorado
    Vern
    I would say you are correct in not shutting off power for storage unless their really is no reason to do so. Unless like you said if you need to do for some reason, ie; work on the car, reset ECUs etc. When you charge the battery I would recommend not using a "battery charger" but use a "battery tender". Chargers are hard on batteries if left on for long periods of time such as thru storage periods. Regards, Vern
