348 Shift Gate
Discussion in 'Technical Q&A' started by rkrenek, Feb 26, 2004.
  1. rkrenek
    rkrenek Formula Junior
    Aug 26, 2003
    344
    Plano, TX
    Rob
    Hi Folks,
    I've removed the two screws holding the shift gate down in an attempt to remove it. Now it appears to be stuck to surface of the console. Does anyone have any hints on how to get it unstuck without damaging the plastic console?
    Perhaps if I remove the lower console it would be easier to work with. Anyone know how the lower console is attached?
    Any help would be appreciated.
    Regards,
    Rob.
  3. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,731
    CA
    Jerry
    #2 Chiaro_Slag, Feb 26, 2004
  4. colo348
    colo348 Karting
    Nov 1, 2003
    141
    Colorado
    Jim
    Hi Rob,
    I've taken my shifter gate off several times w/o any problems so I'm not sure how it can get stuck unless some one may be added some glue? However, to remove the console plastic parts here's what you do:
    1. Open the ash tray, take out the ash inserts.
    2. Unscrew the 2 screws holding the ash tray in then pull it out.
    3. Lift up the console part with the gas tank, door lock buttons, unplug
    the connector for these devices.
    4. Your at the shifter gate now may be you can see something holding it?
    Good luck, hope this helps.
    Regards,
    Jim
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,305
    Commifornia
    The Bad Guy
    To add to what colo348 said:
    5. loosen the screw under the ball on the shift leaver, unscrew and remove the ball, then take the shift gate and plastic piece completely off.
    This way you can mess with it from the bottom also.
    I think what has happened is that the rubberish coating on the part has stuck to the shift gate. You'll get it off.
  6. rkrenek
    Aug 26, 2003
    344
    Plano, TX
    Rob
    Thanks guys! I just removed the entire lower console to access under the shift gate (to add a new rubber shift boot). The shift gate is still stuck to lower console & I don't think its going come apart without causing damage.
    btw, has anyone replaced their console (upper &/or lower) with a carbon fiber style? If so, how do you like it? Please post a picture...
    Thanks,
    Rob.
  8. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,836
    East Yorkshire
    Justin Kenyon
  9. Ricambi America
    Sponsor Owner
    Kenyon -
    You have fiber sills, center console, and center controls (HVAC)? Where'd you get the different pieces?
    -Daniel
  10. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,836
    East Yorkshire
    Justin Kenyon
    I also have the CF front splitter and the air box is on its way soon.
    All CF parts are from Valence USA. Check out the Sponsors Section. Speak to Chris Coffing
