348 Suspension problems | FerrariChat
Discussion in '348/355' started by fcar200, Apr 15, 2025 at 8:32 AM.
Tags:
  1. fcar200
    fcar200 Rookie
    May 28, 2022
    2
    B M
    I love my 1990 348TS but the biggest problem is the suspension. I live in the Northeast, and although now is a particularly bad time for potholes, the car grounds out frequently, even over moderately sized bumps in the road or minor asphault repairs--all of which I try to avoid. I understand the car sits low to the ground but I still think something is wrong with it. The frequent grounding is the number one reason I usually choose a different car from my garage, and I'd really like to enjoy more time in the 348 now that the weather is getting warmer!
    My mechanic has evaluated the suspension (presumably same as new from 1990) and feels it's working as designed, primarily on the basis of checking the ride height.
    Anyone else having this problem? Is my mechanic right that nothing can be done? If I wanted to replace the suspension with a new set that is not lowered but performs more confidently over rougher roads, are there options?
  2. ChoonHound
    ChoonHound Formula 3
    2,055
    Saint Michaels, MD
    Lucas
    Man, one of the things I enjoy most about my 348 is the compliance of the suspension and the higher profile tires. I have cleared driveways in my car that I would not have thought possible. If yours is actually grounding out I might buy new springs and send the struts out to be rebuilt. You don’t need to go aftermarket, of which options are extremely limited anyway.
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,630
    Stock, a 348 is going to have about 4.2" of ground clearance--which is about as low as a road car gets--most are closer to 6".
    Stock, a 348 is going to have a compliant suspension--are you sure the springs and shocks are original ??
    Secondarily, a 348 uses 17" tires with 45% sidewalls, are you still on 17" rims ?? with near stock tire sizes and sidewall heights ??
    But:: Your mechanic is wrong, the 348 suspension can be tuned in all sorts of ways, more-or-less understeer-or-oversteer, higher or lower ride height, faster or slower steering--mostly it just costs money, time, testing, and effort. Factory settings are pretty good as a starting point.
    Also note: Pre-Specialé 348s have the older 348 suspension whereas post-Specialé have (essentially the F355 suspension). The older suspension wants a driver with more verve (more power on turn exits--slower in, faster out).
    ChoonHound likes this.
  4. A348W
    A348W Formula 3
    Jun 28, 2017
    1,838
    North Wiltshire, UK
    are you sure you are at stock ride hieght; as per the figures in the manual?
    roads in the uk are dire and I only bottomed out a few times and the “pot hole” were scary size!
    if the roads are that bad, you could increase ride height a bit. it will compromise handling; but a tradeoff maybe worth it. (ride height on my 355 is slightly higher on front due to french speed bumps; does affect the handling but its all a compromise!)
  5. Mitch Alsup
    Nov 4, 2003
    9,630
    The figures in the manual are not to the first thing that contacts the road surface !
    They are to the center of the chassis side lower rear A-Arm bolt.
  6. TSF355
    TSF355 Rookie
    Jun 30, 2024
    24
    Tom
    If the suspension hasn’t been touched in 35 years it’s well overdue for a rebuild.
    Mitch Alsup and ChoonHound like this.
  7. fcar200
    fcar200 Rookie
    May 28, 2022
    2
    B M
    I appreciate everyone's feedback, and it's definitely helpful to understand that the 348 suspension is capable of more than I'm getting!
    I will definitely ask my mechanic about a rebuild. In addition to shocks and springs, is there anything else that should be refreshed? Bushings etc?
    Anyone have experience with SCALE Suspension? https://scalesuspension.com/product/fr02-as/ Their 348 kit looks pretty reasonably priced and supposedly matches "OEM comfort level". I guess given the low cost I could have these installed and see if I like them before deciding to get the originals rebuilt?
  8. ChoonHound
    2,055
    Saint Michaels, MD
    Lucas
    Anytime the color of the springs is the primary choice your suspension provider offers you should take that as a sign you’re buying something for a teenager. That stuff looks like crap. Get your factory stuff fixed.
    ps, anytime I’ve put coil-overs on a car I’ve regretted it. They will never ride smoother than a good pair of Bilstien shocks and a nice set of lowering springs.
    Ob917 likes this.
  9. Ob917
    Ob917 Karting
    237
    Carlsbad
    OB
    Typical Chinese suspension product. Anything worthwhile for your car and better than factory will be much more expensive.
  10. ChoonHound
    2,055
    Saint Michaels, MD
    Lucas
    Now this… THIS… could be interesting… ;)
    https://www.ferrarichat.com/forum/threads/nose-lift.704116/
    (tho I doubt it rides plusher… if only we knew someone with experience….)
  11. Ob917
    Ob917 Karting
    237
    Carlsbad
    OB
    The factory dampers are built just like any other coilover setup. Its all in the valving and spring rates, nothing wrong with a coil over design. Ive used lots of super high quality coilovers that a set of bilstiens cant compare to.
  12. Ob917
    Ob917 Karting
    237
    Carlsbad
    OB
    Haha yep. They are very plush actually when in a soft setting. But getting the ride height tall enough might not be possible, maybe they can be speced with a longer spring.
  13. ChoonHound
    2,055
    Saint Michaels, MD
    Lucas
    Of course not, just sharing my experience with aftermarket coils I’ve had before. From KW to BC. Not inherently bad, but the ones I’ve had, the way they were setup, etc… I would have been better off with springs and dampers. Just sharing my experience.
    Ob917 likes this.
  14. ChoonHound
    2,055
    Saint Michaels, MD
    Lucas
    Right, so if compliance, travel, and cost are a concern I am guessing you would suggest rebuilding the OEM?
  15. Ob917
    Ob917 Karting
    237
    Carlsbad
    OB
    Yeah, that would probably be best. Just my opinion tho. My old factory stuff was pretty good. Matbe the OP just needs a better mechanic ?
  16. ChoonHound
    2,055
    Saint Michaels, MD
    Lucas
    Agree. If your mechanic isn’t feeling what you’re feeling get a new mechanic. Probably just doesn’t want to deal with it.
    Ob917 likes this.
  17. A348W
    A348W Formula 3
    Jun 28, 2017
    1,838
    North Wiltshire, UK
    My point is; check the car is at stock
    settings. 348 bottoming out with stock settings; the roads must be dire!
    Ob917 likes this.
  18. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,726
    Central NJ
    Eric
    After settings ride height with not much of a difference in ride, I had my shocks rebuilt and replaced the springs with factory ones, I had to search quite a bit. The car felt showroom new. The old shocks loose nitrogen and the oil has long since broken down. It was a definitely a different experience driving than before I did that. I am in NJ.
