News
348 Transmission leak
Discussion in '348/355' started by CrestSpeed, Jan 12, 2019.
  1. CrestSpeed
    CrestSpeed Rookie
    Jul 25, 2015
    12
    Wausau, WI
    Larry
    Looking for some direction on a small transmission oil leak.
    The oil is weeping from the small plug on the front of the trans.
    See photo (plug is on the lower left side, with a small drop of oil on it).
    It leaks about 5 drops a week. My question is can I remove and clean this plug
    to stop the leak?
    LJS Image Unavailable, Please Login
  2. yelcab
    yelcab F1 Veteran
    Nov 29, 2001
    9,641
    San Carlos, CA
    Mitchell Le
    Step back a bit and take a bigger picture. I want to know the general direction of the "plug"
  3. S-T48
    S-T48 Formula Junior
    500
    Stevenson Ranch, CA
    My guess is the leak is not from the plug, but it makes its way there. You would be surprised how oil travels. Likely its the backplate... I see some residual there...
  4. CrestSpeed
    CrestSpeed Rookie
    Jul 25, 2015
    12
    Wausau, WI
    Larry
  5. Wade
    Wade Two Time F1 World Champ
    Rossa Subscribed Owner
    Mar 31, 2006
    28,951
    East Central, FL
    Wade O.
  6. Wade
    Mar 31, 2006
    28,951
    East Central, FL
    Wade O.
    Or from the top of the motor, e.g. the cam covers.
  7. yelcab
    yelcab F1 Veteran
    Nov 29, 2001
    9,641
    San Carlos, CA
    Mitchell Le
    Are you sure that stuff is gear oil?
  8. CrestSpeed
    CrestSpeed Rookie
    Jul 25, 2015
    12
    Wausau, WI
    Larry
    Ok, just checked the plug. Yes, the trans oil is weeping out the plug threads. No other signs of oil from anywhere else. I can wipe the plug clean, then wait and the oil reappears. Also the Allen head thread is stripped round. I tried to tighten the plug bit no results.
    Can I just get a new plug and replace this one? Or is this plug holding something in the transmission in place?
    LJS
  9. Ferrarium
    Ferrarium Formula 3
    1,833
    Central NJ
    Eric
  10. Wade
    Mar 31, 2006
    28,951
    East Central, FL
    Wade O.
    #10 Wade, Jan 13, 2019
    Looks to be on the Intermediate Plate, and possibly Item #44
    https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/348-group/348/gearbox-differential-housing-and-intermediate-casing.html
  11. CrestSpeed
    CrestSpeed Rookie
    Jul 25, 2015
    12
    Wausau, WI
    Larry
    No, it's not the drain plug. I just changed the trans oil then noticed the leak it's from the small plug at the front bottom of the casting. Review first photo.
    Thanks for you input.
    LJS
  12. Ferrarium
    Ferrarium Formula 3
    1,833
    Central NJ
    Eric
    I'm no expert but if its the bolt Wade posted try torquing then all, but I suspect if its that bolt its probably gasket issue and oil by passing and working it way out the bolt hole. Not sure a new bolt will do anything different. I hope I'm wrong of course. Dig into parts diagrams different ones will have different angles. Should reveal some answers to what it is. May be a simple fix.
  13. CrestSpeed
    CrestSpeed Rookie
    Jul 25, 2015
    12
    Wausau, WI
    Larry
    Yes, that's the plug (10269550 PLUG).
    Can this plug just be removed and replaced with a new one? Will the Trans oil pour out?
    LJS
  14. Wade
    Mar 31, 2006
    28,951
    East Central, FL
    Wade O.
    Since it's already "stripped round" seems that someone made previous attempts to tighten it (or stripped when trying to remove).
    Hopefully someone here will add from their experience - plug removal. From the parts book, there doesn't appear to be any spring-loaded surprises within. ;)
  15. CrestSpeed
    CrestSpeed Rookie
    Jul 25, 2015
    12
    Wausau, WI
    Larry
    Ok, maybe I'll try my Dremel and cut a slot to use a flat screw driver?
  16. Wade
    Mar 31, 2006
    28,951
    East Central, FL
    Wade O.
    I'd try an easy-out first (i.e screw extractor).
  17. CrestSpeed
    CrestSpeed Rookie
    Jul 25, 2015
    12
    Wausau, WI
    Larry
    Good plan! I have a set. Any idea if the oil will pour out if I remove the plug?
    Thanks,
    LJS
  18. Wade
    Mar 31, 2006
    28,951
    East Central, FL
    Wade O.
    New territory for me so I don't know. Never seen or heard of anyone pulling this plug before either (not that it hasn't been done, of course).
  19. Ferrarium
    Ferrarium Formula 3
    1,833
    Central NJ
    Eric
    I think in the diagram for oil pump and what not it shows that plug. I believe I remember seeing it when I was having all my tensioners updated as the pan had to be dropped and I was buying all the replacement rings and what not.
  20. CrestSpeed
    CrestSpeed Rookie
    Jul 25, 2015
    12
    Wausau, WI
    Larry
    Thanks everyone for your direction and help. I was able to use an easy-out to loosen then tighten the plug about 1/2 turn in.
    Hope this works to stop the leak, if not, I'll replace it with a new one.
    LJS
  21. CrestSpeed
    CrestSpeed Rookie
    Jul 25, 2015
    12
    Wausau, WI
    Larry
    Under the car tonight. No leaks!!!
    Wade likes this.
  22. Ferrarium
    Ferrarium Formula 3
    1,833
    Central NJ
    Eric
    Awesome news keep an eye on it.
