348 twin disk replacement issue ? | Page 2 | FerrariChat
Discussion in '348/355' started by 97 Spider, May 17, 2015.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    How do you know it isn't fully disengaging?
  2. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I fired it up and it grinds a bit trying to put it in gear(sitting still) then starts moving forward as soon as you start to let the clutch up.
  3. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Hmmm........
    Are the clutches facing the proper way? On my AP clutch plates one side is printed "flywheel side", and on the opposite side is printed "bearing side". Are they orientated the right way in the stack?
  4. fatbillybob
    Aug 10, 2002
    29,487
    socal
    Lack of disengagement implies wrong set-up height. It has been too long since I have worked on these. Is it possible the HE flange and bearing are designed for the single plate clutch? I do not think the OEM dual disk can be just removed and single replaced if the dual flange and T/O bearing are used. I don't have a WSM in front of me to see how those two units measure up.
  5. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    They are rebuilt discs and don't have any writing but are in there the way he diagrams and pictures show.
    I was told it was the same for both setups... but who knows.
  6. fatbillybob
    Aug 10, 2002
    29,487
    socal
    Could be, I'm just guessing because I can't remember. If they said it is the same then it probably is.
    Did the pumpkin go back in nice and passive with no force? It is possible to force the pumpkin in with the bolts pulling the pumpkin in and binding the guts. I always put the pumpkin in most of the way slide my hands up and rotated the clutch discs and that helped index the splines before pushing the pumpkin the rest of the way over the pilot bearing resistance. There are 2 shafts input and clutch. Does that make sense?
  7. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Yes it went back together really easy. After engaging the clutches on thier shaft I slowly turned the setup while giving it a little giggle and push and the input shaft slid right in.
    I really don't have the time but I'm going to make the time in the morning to pull it out one more time and see if I can figure this thing out.
  8. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Ok so this morning I said hell with it I'm going to take this thing for a drive and see if I can screw some more up. So I pulled my other cars out of the way and pulled it off the lift. I just got back from driving around the neighborhood for about 15 minutes. Whatever was dragging seemed to free up and now at a stop I can move it through all the gears with no grinding and the clutch started to engage a bit higher on the pedal.
    It still seems to be pretty stiff to push the pedal and much harder to get it into the gears when driving. The car has been down and out for a good 7 months so maybe it will loosen up at bit more and I also have the console all tore apart working on the ac panel connections and stickies so I don't have the gate on there. As I drove it it started to seem more like shifter adjustment issues then the clutch, but that seems weird because it shifted like a dream before I worked on the clutch.
    I'm debating on calling the clutch good and putting on the exhaust. I've got to say it sounds pretty mean with basically open headers but I'm pretty sure I'll catch something on fire sooner then later. :)
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    If you have full release of the clutch and the petal is in a good spot you should be good to go.
  10. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Thank you all. I think I'm going to roll with it a see how it goes. I'm going to try to get the exhaust on tonight and get some miles racked up on it.
    I just unloaded a freight truck with some goodies for another project (construction) so I really have a bunch of stuff I should focusing on but it's pretty hard to walk away from the car when it wasn't working out right. I think I might have pull a couple all nighters and try to get my cars up to par.
