348 vs 355 | Page 3 | FerrariChat
348 vs 355
Discussion in '348/355' started by wildcat767676, May 30, 2014.
  1. Chupacabra
    Chupacabra F1 Rookie
    3,587
    Behind a drum kit
    Mr. Chupacabra
    Sounds like the Spider has been the most loved. If you don't mind having a drop top, I'd say go with that one.
  2. wildcat767676
    wildcat767676 Formula Junior
    May 20, 2011
    531
    Gilbert, Arizona
    I had trouble on the test drive shifting into second and third gear, sometimes even 4th. Seemed to get better after 20 minutes or more. New clutch too and it didn't grab until near the top. Is this a sign of gearbox troubles or fairly common?
  3. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    The 2nd gear issue is definitely a common "cold running" issue and therefore nothing to worry about. As you noticed it improved as the car warmed up during the drive. A good solution is using Redline 75W90NS gear oil.
  4. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,193
    Adelaide, South Aust
    Steve
    True
    Unfortunately you then have to buy and put up with a 348. Lol!
  5. tbakowsky
    Sep 18, 2002
    20,079
    The Cold North
    Tom
    If the clutch didn't grab until near the top..then either it's not a new clutch, or they used a lousy rebuild.
  6. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    Yeah thought it was odd because I drove a 94 spider the same day with a fresh service and all gears were smooth, clutch normal. The only problem was the car felt slow and un exciting compared the other. Maybe spiders aren't as quick? Maybe the stock exhaust held that one back? It did have 4 times the mileage...
  7. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,289
    Worcester, England
    Phill J
    The 348 is renowned for having no 2nd gear for the first few miles of driving and 3rd to 4th shifts at that time take a determined effort to complete - You get used to it after a while.
    The good thing about the 348 is that the engine is so torquey that the traditional cold Ferrari 1st to 3rd shift isn't a problem at all, the car will deal with it without batting an eyelid (In fact, the last time I took My car out for a drive I realised quite late in the drive that I was still shifting from 1st to 3rd long after the car had warmed up and 2nd became available!).
    The other thing I have found is that is that 1st gear seems to be almost ridiculously short geared! Once the car has warmed up, it almost feels as if 2nd gear should really have been 1st gear.
  8. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    Ok whew! I was worried this was the gearbox self destruct issue to watch out for I heard somewhere on 348's. My GT4 shifts into second cold no problem... So odd.
  9. Steve355F1
    Aug 26, 2011
    17,193
    Steve
    Mate, just buy a genuinely good car (348 or 355, preferably 355 :)) and be done with it.
    Ignore the rubbish posted by people who bought a cheap ****box and then complained endlessly when they couldn't fix it with a couple of spanners and a pair of scissors.
    Buy a good, well maintained one, keep it well maintained and you'll never look back.
  10. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    Well said
  11. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,289
    Worcester, England
    Phill J
    With My 348, from cold it's not even a case that its hard to get into 2nd, it simply isn't there! - It almost feels as though there is a metal bar across the 2nd gear gate stopping you.
    A few miles down the road and you can just about ease the car into 2nd gear.
    And then once everything has warmed up fully, you can select 2nd with no issues whatsoever!
    The thing that gets Me is that if BMW made a car with which 2nd gear wasn't available from cold then there would be an international outrage about a poor quality gearbox!
    With Ferrari though, even though it's a far more expensive car than a BMW, the lack of 2nd gear from cold is simply accepted as being a trait and quirk of Ferrari gearboxes, and is deemed as being somewhat normal!
  12. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    On an old top gear richard hammond was driving a 1970 daytona to monaco and when he set out on his trip he commented and said " being a ferrari you cant select 2nd gear when not warmed up or it , kinda explodes" . Guess its always been like that , adds to the ....... Charm . Lol. I have to say tho, my 348 slides right into second cold if the revs are over 4000. No fuss.
    " serenity now "
  13. sherpa23
    sherpa23 F1 World Champ
    10,021
    Rocky Mountains
    Bastuna
    I have a Daytona and it seems to shift just find into 2nd when cold. As does my 550. I think it's only mid engine cars that have that issue.
  14. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    This car didn't shift into second or third though for a while.
  15. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,289
    Worcester, England
    Phill J
    Whilst 2nd gear has a reputation for being a bit petulant when cold, shifting into third shouldn't be a problem.
    It is a fact with older Ferrari's that you have to be quite forceful and positive with your gear changes compared to other manufacturers such as BMW (you're not going to get far trying to flick through the gears with just two fingers in an older Ferrari - It's a very "manly" gear change [When I first drove a Ferrari, the gear change felt like it needed the same effort that you see people use to manually change the points on railways! :D ] ).
    However, at most you should only need to "convince" the gear to engage, you should never have to force it!
    If 3rd gear is as difficult to engage when cold as 2nd gear is, then I suspect something is not quite right.
  16. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    I'm having it inspected tomorrow with the PPI so we will soon know! :)
    Clutch and major was done 7 years ago but only 1500 miles. Hard to think it's the clutch but it doesn't grab until near the top... No slip at all though!
    What would you expect to offer for a low mileage TS in need of a major these days? I'm thinking $35-40k from my research...
  17. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    Any thoughts? Deciding today! 😳😳😳
  18. Dazzling
    Dazzling Formula 3
    Nov 18, 2010
    1,133
    Adelaide
    Darren
    What happened?
  19. Ferrarimondial348
    Ferrarimondial348 Formula Junior
    Nov 29, 2012
    532
    Scottsdale, AZ
    Stephen
    He purchased the car. See previous post.
  20. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    Absolutely love the car!!!!
  21. Dazzling
    Dazzling Formula 3
    Nov 18, 2010
    1,133
    Adelaide
    Darren
    Well done, didn't see the new thread!!
  22. wildcat767676
    May 20, 2011
    531
    Gilbert, Arizona
    [​IMG][​IMG][​IMG]
  23. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,245
    Huntsville, AL., USA
    Andrew
    Very nice! Congratulations! :D
    All the best,
    Andrew.
