348 Wheels on Mondial 3.2--Warning-PLEASE READ!!! | Page 2 | FerrariChat
Discussion in 'Mondial' started by JoeZaff, Oct 13, 2008.
  1. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    I agree, which is why I used the H&R bolts, even though they were not as pretty as the factory bolts. The extra 3mm offers great security
  2. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    OK- It's official, to use all of the available thread in the front wheel hub, the front bolts MUST be 58mm long. At 58mm, the bolt sits just about flush with the hub (maybe sticks out less than a 1/2mm). The front 348 wheel bolts so commonly used at 55mm, are simply too short for the mondial. Will they work? Sure, but they use far less of the available hub thread and, given the stress put on the front wheels, I would not feel comfortable relying on so little thread.
    As for the rears, I assume 55mm is fine as it gets about 8 1/2 turns. However, I have not looked behind the hub to see if there was any more available space.
    If I can figure out how to sync my phone with my laptop I will post a photo.
  3. caporasobmw635
    Aug 4, 2022
    1
    Adelaide
    Great information. Where did you buy the proper wheel bolts?
  4. Sigmacars
    Sigmacars Formula 3
    1,194
    The rule with any bolt size is 1 1/2 of the DIA
    To be engaged for maximum strength
  5. moysiuan
    moysiuan F1 Rookie
    4,075
    Canada
    This all suprises me as 348 wheels appear to have been used on Mondials for ages. To think people were/are using unsafe lug bolts is just a reminder that when one deviates from the OEM parts you need to be very thoughtful.
    You can paint the HR bolts a satin black and they will probably look quite good. As long as they are the right length, and for a fair price the appearance has to be a secondary consideration.
  6. JLF
    JLF Formula 3
    1,703
    You can get those hill engineering bolts for an ok price. About 20 dollars each. They have all sorts of sizes.
  7. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    Well said.
    Whatever wheel (or wheel + spacer), the bolts shall simply protrude by 22mm, which is a bit more than 1.5DIA (21mm), and it is the amount the stock bolts protrude from the stock wheels. By the way 1.5DIA equals to 14 turns (as pitch is 1.5mm).
    Anything less than that is risky and not recommended, despite working.
    So the best way is to check bolts protrusion and, if not 22mm, purchase new bolts that are longer accordingly (e.g. if they protrude by 17mm you will look for 5mm longer bolts).
    On the other hand more than 22mm could be dangerous for interference of the bolts ends with some fixed hub component, so I would recommend to carefully check that, or cut bolts that are protruding by more than 22mm to measure.
    andrejwolk1975 likes this.
  8. Sigmacars
    Sigmacars Formula 3
    1,194
    You are right I should have said 1 1/2X DIA
    MINIMUM to get Maximum
  9. Carmelo Cesar Laise
    Oct 24, 2019
    6
    Buenos Aires- ARGENTINA
    Carmelo Cesar Laise
  10. Alden
    Alden F1 Rookie
    3,366
    Central Florida
    I think all the information you need about wheels and bolts is contained in this thread, what else do you need to know, also, your attachments either can't be seen or make no sense.
    Alden
  11. Carmelo Cesar Laise
    Oct 24, 2019
    6
    Carmelo Cesar Laise
    Thanks!!!! Great!
