News
348 wheels
Discussion in '348/355' started by GiulioP, Nov 22, 2020 at 8:43 AM.
  1. GiulioP
    GiulioP Karting
    Jun 12, 2019
    69
    Giulio Palazzo
    Hi everyone. Need to know if the OEM 348 wheels/rims are the same thru out the entire model run for all 348 models. Or does the offset or something change?
  3. bjwhite
    bjwhite F1 Rookie
    3,856
    Seattle, WA
    Brian White
    Offset changed around the 1993 model year. I would say late 1992 production dates but I am unsure as to the exact month. Certainly all Spiders and GTS/GTBs got the new wheels, that's for sure.
  4. GiulioP
    GiulioP Karting
    Jun 12, 2019
    69
    Giulio Palazzo
    Thanks for the heads up. There's a brand new, never mounted rim for sale near me that i want to buy as a spare. Are there numbers/markings i should look for?
  5. Meister
    Meister F1 Veteran
    5,275
    Duluth, MN
    The Meister
    Yes each has a separate part number because of the direction design of the wheels they are 4 specific part numbers. Ricambi America used to have very detailed parts diagrams but I've heard they had to take those down.
    Some time on google or ebay should vet out the part numbers
  6. Meister
    Meister F1 Veteran
    5,275
    Duluth, MN
    The Meister
    my spider numbers are
    LF 136531
    LR 156244
    RF 136542
    RR156242
    Numbers are on inside of the wheels
  8. GiulioP
    GiulioP Karting
    Jun 12, 2019
    69
    Giulio Palazzo
    Thanks!
  9. GiulioP
    GiulioP Karting
    Jun 12, 2019
    69
    Giulio Palazzo
    Not sure I can see mine while on the car.
  10. Ferrarium
    Ferrarium F1 Rookie
    2,798
    Central NJ
    Eric
  11. Ricambi America
    Sponsor Owner
    136542 R.H. FRONT WHEEL RIM 7 1/2 J X 17
    136531 L.H. FRONT WHEEL RIM 7 1/2 J X 17
    136547 R.H. REAR WHEEL RIM 9 J X 17- Not for USA and CDN
    156242 R.H. REAR WHEEL RIM 9 J X 17- Valid for USA and CDN
    136538 L.H. REAR WHEEL RIM 9 J X 17- Not for USA and CDN
    156244 L.H. REAR WHEEL RIM 9 J X 17- Valid for USA and CDN
    Meister likes this.
  13. Michael_Davis
    Michael_Davis Karting
    130
    Orlando
    Michael Davis
    Is that the same across all the model years?
  14. Ricambi America
    Sponsor Owner
    You have a USA Spider, right? It would originally use 156244 and 156242 in the back. The fronts would be 136542 and 136531, as posted by @Meister
  15. Michael_Davis
    130
    Orlando
    Michael Davis
    Yep! Not so much asking for myself, as I have my OEM wheels out in the shed, but was thinking more about the whole Brotherhood.
  16. Meister
    Meister F1 Veteran
    5,275
    Duluth, MN
    The Meister
    Not really my business, but if you buy a single wheel it would only be for one position on the car. Fronts and rears can be mounted and work on either side but will appear backwards if not on he correct side
