Series 1 gt4 front coolant hose replacement | FerrariChat
Discussion in '308/328' started by guygowrie, Dec 17, 2011.
  1. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    Searched the forum but i couldnt find the right tips.
    I am replacing the 1 1/2 inch coolant hoses leading into and out of the radiator, and the two short sleeve hoses just before the coolant lines into the chassis.
    the top 90deg hose can be reached from the top.
    I have removed the access panel under the car which means i can get to the two short sleeves, one sitting on top of the other.
    However, the lower sleeve hose connecting the bottom of the radiator can only be accessed from below (you can see it from above but i'll be damned if i'll have the leverage to get the old one off and a new on on).
    to get access you need to remove the fibreglass nose panel under the front bumper - do the experts agree with that or is there another way?
    This requires removal of the front bumper - done! (gosh, they are heavy!)
    drilling out rivets on the trailing edge of the panel under the car - done
    drilling out rivets at the front of the panel after removing the grill - tick
    Finally, drilling out about a 6 rivets each side running fore to aft along the seam between the fibreglass panel and the front metal valence.
    Here i have a challenge - access to those rivets is very difficult. Even if i remove the lower wheel arch panel (put car on mounts, remove wheel, remove access panel) i still dont have a drill that is going to neatly go into that space to drill out the rivets. Even a dremel doesnt work (you end up grinding fibreglass before rivet head).
    I want that panel off so i can that hose and to make some repairs to the panel itself.
    Sorry, i've written a lot there but can anyone suggest the right way to attack this?
  2. GT4 Joe
    GT4 Joe Formula Junior
    Oct 19, 2010
    833
    Dana Point, Ca.
    Joe Williams
    Sounds like you're doing the right steps. Check or search Dr. Kanaga's threads - he just replaced his radiator, hoses, and added drain petcocks to the tubes.
    As for the lower valance rivets, seems that an angle head attacment on a drill or dremel could get access. I wanted to remove mine to do some fibreglass repairs and repaint it, and was looking for a game plan. PITA, but if you have everything else out of the way, just keep plugging away. If you damage the flange where the rivets are, could this be repaired leaving the outside of the panel and paint intact? Just my 2 cents.
  3. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    thanks, i will try and proceed then - there is probably an tool attachment made for this!
    I can see it wont be that hard to replace the rivets in due course but get them out - pita!
  4. thecarreaper
    thecarreaper F1 World Champ
    18,054
    Savannah
    Taking off the bottom panel helps, but i stand in the front well after removing the spare tire tub and change the cooling and heater hoses.
    Cut the old ones off with a razor knife and split them open.
    Remember to slide the hose clamps on BEFORE you wriggle on the new hoses. :)
  5. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    I got mine off without removing the spoiler.
    The AL tubes at the front are clamped together right at the chassis making things tough to take apart. Take that clamp off first. Get the 2-hoses that are stacked off 2nd. CUT THEM OFF if you have too. You're not going to use them again so who cares. I've noticed with virtually every hose job I've ever done on any car that the hoses have a tendency to 'stick' to their mating surfaces making the twist method of removal difficult at best. Why beat yourself up when a good knife will do the job you need.
    Now cut off the front hose.
    Now you have a lose AL tube making re-install of the front lower hose fitting much easier. Do not clamp it down. Now install the hoses that go under the chassis. I found I had to sort of jam it in sideways and work/bend/twist to get it all going.
    Because everything is connected, it's actually easiest to disconnect everything at the back, take out the bend around the engine AL lines, then loosen the hoses at the back giving things up front much more free play. But if you're not messing with that, don't worry about it.
    It can be done, but it's a pain. But not as much of a pain as removing the spoiler.
    If you do remove the spoiler, you have to kind of force it off.
    To re-install, put it out in the sun for an hour or so to heat it, while your car stays cool in the garage. I got mine to slide back on in about 30-seconds all by myself. Was actually sort of stunned how easy it was.
  6. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    Thanks for the tips. I am sure the last person installed the new hose without taking the spoiler off - the screws on the clips were facing up. (must remember to do the same so its top out is an option next time. If i stood in the spare wheel well i would go THROUGH it ! It is already holed at the base and on the repair list.
    Taking the hood off would also work well from an access POV.
    But I wanted to repair that nose so I persevered. In the end I managed two top rivets reaching in with a drill from the front. Then I used a hacksaw blade on one of those blade holder saws and went down the gap between the fibreglass and metal panel, cutting the rivets.
    Almost no damage to the glass or metal on the way and it dropped out nicely.
    Glad to report very little rust under there, just some minor surface rust and one crossbar under the headlight with a hole. a quick scrape and some por 15 and it will be good for some years.
    The nose cone looks like sh*t - I've drenched it in degreaser to prepare it for sanding then glassing. I may then take it too a body shop for a neat job (and get the series one grille powdercoated black while I am at it).
    I am assuming a low satin black is the right finish on the nose panel?????
    Hope to get on to those hoses tomorrow - good tip on the knife...i will reach straight for the dremel cutting blade!
  7. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    btw GT4 Joe, what colour is your gt4 and is that original? I think mine (sn 10402) was originally a burgundy and was changed by the original owner to silver with boxer pants.
  8. GT4 Joe
    Oct 19, 2010
    833
    Dana Point, Ca.
    Joe Williams
    Guy,
    Originally Rosso Rubino Metalizato, changed to Rosso Bordeaux (?) about 1981 ish.
    10080 Feb 1975.
    Did you buy the one in the Temecula area?
  9. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    Indeed I did and trucked it over to CT. In all honesty I took a flyer when i bought it - it had been in someones hands a long time (since 86 and he was the 2nd real owner), was/is cosmetically dog eared but was mechanically used in the good sense, so everything works. It had a nice continuous history documentation wise which i think is a bit unusual for gt4s and looks good from 10feet. It hasnt been glossed up every 3 years and then shunted to the next owner if you know what I mean.
    For its faults it has turned out to be a very honest car (eg popping that nose cone off didnt expose a rust nightmare!) and I'm slowly getting my feet wet freshening it up with the aim it should be driven. So refurb, not restore!
    I havent regretted buying it (well, except when I had to pick it up from a drop off point when it arrived..it started raining, the heater was on, it was summer and i couldnt work out how to shut it off, it started running on less than 8, reverse decided to disappear...)
  10. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    #10 guygowrie, Dec 17, 2011
  11. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    #11 guygowrie, Dec 17, 2011
  12. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    #12 guygowrie, Dec 17, 2011
    the nose panel off, few holes needing a patch of glass - i may let a bodyshop get this is proper shape while I Por15 the inner panel area.
    Tomorrow I hope to start on the hoses.
  13. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I did this without removing the bumper. Why did you have to take it off?
    Also the seam between the lower fender edge and belly/spoiler was held on with clips (and a small C-clamp!) on my car. I never looked at the parts book to see what was original.
  14. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    Hi brian,
    the bumper obscured the visibility and access into where the rivets were - even though I ended cutting most of the rivets from the bottom I first had to find out what was holding it on (rivets!) and where they were.
    What kinds of clips held the nose panel on? photos? Being a 37 year old car its quite possible that the rivets on mine are not the original fasteners.
    I may stay with the rivets - easier to put in than to take out using a swivel headed rivet gun.
  15. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    My bad, I completely missed that it was a GT/4 not a GTB. Sorry.
  16. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    np Sean and your tips were very valid and useful. Will post a photo when i get home of the sleeve hoses before the chassis tubes - ugly..
    Got them on finally, but have a small leak again at the front one but think mainly as i didnt have the right extension to get the lower rad hose clamp tight (rotated them so they were top 'accessible'. I had to make a slightly longer sleeve on one hose to get a good seal. Broke one clip installing (tip: buy a few more clips than needed/Buy more hose than needed).
    Bleeding was interesting. i ran the car at idle late last but it was so cold that it took forever to click the themostat over and when it did the temperature plunged. All of the saved fluid when back in (filtered first) and some water to top up what was spilled. Bled well enough and will repeat that a few times.
    Water started warming up to temp again so I took it for a test drive - ofcourse after idling for 1/2 hour or more it then decided to run like **** - its happened before and seems a result of being off the road and not been driven hard. Fouled plug etc.
    The temp also went down very low, like it was just started.
    I crapped myself as i thought that something catastrophic had happened...returned home and the motor was not a smoking, flaming mess. Coolant still in the system. OK...
    My guess is that with the low revs, very cold outside temp and no bumper/front nose panel then the engine wasnt going to get to temp. At least thats my take but quite disconcerting to see an engine sit at 90 just fall to 60deg and stay there.
    anyone had a similar experience??
  17. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    #17 guygowrie, Dec 20, 2011
    here is what the internals of one of the pre chassis sleeve hoses looked like.
    Hoses are all in. Broke one clip on installation. needed to resize on sleeve to get a seal and now tweaking up the clips to stop small drips now that I have the right socket extension.
  18. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    Holy crap, that's some serious corrosion there... How did it look like in the pipes? Have you run at least some rad flush in the system to get the calcification out? With **** like that in the hose, there's bound to be more like that in the rest of the system.
    What thermostat is in the motor? If it's the correct type and/or at least working properly, it should hold the engine at a steady temperature, even on a cold winter day.
  19. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    Hi Peter,
    thanks for your comments.
    The corrosion was limited to the 2 sleeving hoses just before the alu thru chassis pipes. Inlet/outlet to radiator, adjacent hoses and alu pipes were super clean.
    it was clear that the 2 sleeving hoses had not been changed in a long time and so there was a lot of buildup there. I suspect that the rad has been rebuilt before as it was in excellent shape.
    the small leak that got me to change the hoses wasnt at those sleeving hoses, but I'm glad i replaced all the hoses at the front.
    Water temp: i agree, the thermo should keep the engine at a somewhat stable temp..
    I'm not sure about the thermostat but cud there be an airlock around the thermostat? or temp sender?
    I have the old type housing ie no bleed valve. I would have thought a drive where the car is going through a number of steep inclines/declines should have been enough to dislodge most airlocks. Eventually I'd like to convert that housing to the one you showed in your post.
    Perhaps changing out that thermostat is a simple place to start. off to the parts reference thread to see if there is a napa option (or is a 308 thermostat very particular?)
  20. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    i've gone ahead and ordered a tstat, gasket etc. reading other threads it sounds as if the tstat is on the way out (opens but then the spring is loosing the strengtht to close again.
    Now i wish i had put radiator drain taps on my coolant pipes so i could empty the cooling system a bit, but will just do it from the radiator i guess.
    will busy myself with other tasks till they arrive...
  21. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    If you're just changing the Tstat, then you don't need to drain the entire system, just open the drain on the engine block and let it go for a while and the level will be down enough to change the Tstat out.
    Make sure the little air bleed hole on the Tstat is up at the top when installing.
  22. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    thanks Peter.
  23. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    While i am doing the t-stat i am replacing the small sleeve hose from the t-stat housing to the alu down tube, and the two hoses going to the header tank (which was a new alu item from superperformance).
    As i dont have the tool to remove all those carb trumpet nuts to get the airbox off, I'm replacing these with the airbox on. I''m all thumbs but the access is quite sufficient so far.
    Struggling to remove the t-stat housing and have posted a separate help note on Dr Kanangas T-stat change thread.
    While I'm at it... I have dealt with the corrosion under the header tank - a scrub up and some por-15. The finish is too glossy but it looks much better than before and the I sleep better knowing its not festering any longer.
    Front grill is off at a powder coaters.
    front nose piece is in the basement awaiting repairs
    fibreglass air scoops are primed and awaiting some more paint
    a new access panel has been made locally to replace the tired old one.
    fan blades have been given a clean
    Once the t-stat is in, its up on the stands to replace a clamp on the front hoses for the right size and to eradicate a drip hopefully with a bit of tightening.
    this all started with a intermittent leak from a front hose...once done 7 main hoses will be changed (still some left), a tstat and a bunch of other stuff. luckily its winter..
  24. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    #24 guygowrie, Jan 1, 2012
  25. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    new tstat is in, with new surrounding hoses, new header tank back in. Long drive on the weekend and all was well...until further leaks from the chassis coolant sleeve pipes front and back, and a drip from the lower rad sleeve pipe.
    thinking about it I was wondering why the leaks started now and my thinking is that once the new header tank was installed (the previous had a pinhole) the whole system is now properly pressurised and is now finding successive weakest links.
    Will let you know when all leaks are eliminated.
    (yes, i have considered the super duper coolant hoses commonly mentioned, however, i can see now that any work on the cooling system (or work requiring hoses to be taken off) usually means you need to cut the hoses, so for now i will go with Napa grade rad hoses).
