348Tb engine bay connector | FerrariChat
Discussion in '348/355' started by marc556, Mar 8, 2016.
  1. marc556
    marc556 Formula Junior
    590
    Wiltz (Lux)
    Marc Foyen
    #1 marc556, Mar 8, 2016
    Dear all,
    I need your help as soon as possible.
    My 348 has to go to Ferrari for Ferrari Classiche certification and before I must change a connector.
    My car is in France (900 km of my home) so I don't know exactly what connector I need.
    I speak about the 9 pin connector fitted close to the rear left shock absorber.
    Could you tell me the dimension between the 4 fitting screws and the connector diameter?
    thank you so much.
    Marc
  2. bosshog8
    bosshog8 Formula Junior
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    Dimension between the 4 fitting screws = 25mm centerline
    Connector diameter = 20mm
  3. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    thank you so much.....
    do you know the diameter of the cable from the engine?
  4. bosshog8
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    The cable from the engine is sheathed in a non-split corrugated loom material and is 11mm.
  5. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    I try to find a part as close as possible to the original, but I don't find it....
    I want to use a water proof connector especialy the one fitted on the frame..
    If someone of you has the solution...it should be nice!
  6. m.stojanovic
    m.stojanovic F1 Rookie
    3,288
    Serbia - Niš
    Miroljub Stojanovic
    #6 m.stojanovic, Mar 13, 2016
    I just bought Amphenol 9 pin Connector MS3106F 20-16S / MS3102A 20-16P. The bad thing is that it is not original (crappy) connector. The good thing is that it is military grade and has two pins thicker than the others, one of which I will use for the high current starter solenoid wire.
  7. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Nice find, Miroljub. Thanks for the info.
    Does anyone have the pin-out for this connector? I know I've seen it here before but I'm sick of trying to find it via the search function. :(
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #8 Wade, Mar 14, 2016
  9. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    That helps. Thanks, Wade.
  10. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Very good information!
  11. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    I just bought a new oe connector and pins/shells for it, its about 15eur hole lot.
    Its AMP cpc connector
    182645-1
    206705-1 (The half with a flange)
    Dont know if it helps anyone
    Pangea likes this.
  12. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thank you for the info, Jesse.
  13. m.stojanovic
    3,288
    Serbia - Niš
    Miroljub Stojanovic
    #13 m.stojanovic, Jul 13, 2016
  14. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Good stuff. Thank you.
  15. m.stojanovic
    3,288
    Serbia - Niš
    Miroljub Stojanovic
    #15 m.stojanovic, Jul 17, 2016
    To further complete the info:
    - The terminal Pins & Sockets come as Tin, Zinc or Gold coated (Gold, of course, is better)
    - The shown terminal Pins/Sockets for the 9-Pin Connector are also good for the Door Harness Connector
    - The alternative (Cannon and AMP) military grade connectors are what I am installing at present; the wires are soldered to the pins/sockets (more reliable connection); the connectors are fully waterproof
    (also see the attached pdf files)
