348ts battery charging/jumping | FerrariChat
Discussion in 'Technical Q&A' started by rogerm2450, Mar 25, 2005.
  1. rogerm2450
    rogerm2450 Rookie
    Mar 25, 2005
    6
    Harrisburg PA
    Roger Morgenthal
    I have a newly acquired 1992 348ts that needs either a jump start or preferably battery charging after sitting in the garage for a while--perhaps the battery is old and should be replaced, but that's not the immediate issue. I read the owner's manual that came with the car and downloaded the one from the Ferrari Owner's site, but I still am not sure where in the engine compartment to connect a charger or jump cables. The battery lives in the left front area, so it makes sense that there must be somewhere in the engine compartment to do these things. I would appreciate any help you could give. Are there any good books that one can use to learn more about maintaining and servicing Ferraris? I really don't see a lot of helpful troubleshooting information in the official manual.
  2. f355spider
    f355spider F1 World Champ
    18,055
    There are tons of threads on batteries, jump starting and battery tenders. There is a search function in the upper left hand corner of the page.
    Here is a post I made on battery tenders...
    http://70.85.40.84/~ferrari/forum/showpost.php?p=134446870&postcount=5
    If you get the battery tender, you will never have to jump start your car again. If the battery is more than four years old, I would go ahead and replace it. You need a size Group 34R.
  3. BULL RUN
    BULL RUN Formula 3
    Dec 18, 2004
    1,684
    In the engine compartment there is a battery bus on the right side, it's near the fender on top easy to spot. connect charger positive to it and negative to a good ground. That's it. BTW there are other alternatives to battery tender, I use the charge cube. works great. www.quickchargestore.com.
  4. tclark
    tclark Formula Junior
    Jun 4, 2004
    604
    Mechanicsburg, PA
    Tom Clark
    Hey Roger,
    Nice to see another 348 owner in the area. I'm in New Cumberland.
    Welcome aboard! Absolutely get yourself a battery tender.
  5. rogerm2450
    rogerm2450 Rookie
    Mar 25, 2005
    6
    Harrisburg PA
    Roger Morgenthal
    I appreciate everyone's comments, and a battery tender is on order. It's nice to have a resource like Ferrari Chat!
