348TS Rear Headliner Upholstery is Falling Off! Help! | FerrariChat
Discussion in '348/355' started by RandyT, Jun 15, 2022.
  1. RandyT
    RandyT Formula Junior
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    I'm trying to remove the rear headliner in my 1990 348 TS because the upholstery is falling down. I removed the dome light, removed the two screws inside the dome light, but I can't get the front edge of the rear section loose where the removable top "posts" go in. I can't figure out what's holding the front edge on. I don't see any other screws. There's no other screws on the outside of the panel as shown in other posts from F-Chat.
    If someone has done it before and knows, please reply. I only hope I don't need to remove all the upholstery behind the seat just to remove the rear headliner.
  2. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    steved033 and Mike Morrissey like this.
  3. RandyT
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    Mike Morrissey likes this.
  4. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    Your welcome.
    I did that job 8 years ago and its started coming loose on one side but cant bring myself to pull it all out again! LOL
    When I do it again I'll try and take some better photos :)
  5. mark348ts
    mark348ts Rookie
    Dec 8, 2022
    2
    Mark Donald Staszewski
    /Did you use new foam and if so where did you get it from? What size bit did you use to drill out the rivits
  6. RandyT
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    Hello mark348ts, I didn't redo it myself. I had a Ferrari upholstery expert do it in SoCal. I used a very small drill bit, maybe 1/8"?
  7. mark348ts
    mark348ts Rookie
    Dec 8, 2022
    2
    Do you remember the cost?
  8. RandyT
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    Around $400
  9. marknado
    marknado Karting
    Mar 4, 2021
    51
    New Zealand
    Mark
  10. User-C3
    User-C3 Karting
    Aug 29, 2018
    240
    Detroit
    Trevor
    I did mine and used new foam. Got the foam from Joann fabric. Pretty cheap and easy to find stuff other places as well. Its not a hard job, just a bit of a pain to get out and back in.
