348TS With Lightweight 355 body on eBay | FerrariChat
Discussion in '348/355' started by Raleli, Jun 9, 2005.
  1. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    THAT POS isn't even worth 20K
  2. f355spider
    f355spider F1 World Champ
    18,045
    Agreed, that "franke-ferrari" ain't worth spit. And who wants to buy someone else's problems? Passenger window doesn't work, and broken motor mount? What is up with this cheap owner? That window fix could be VERY expensive. A window regulator for a 355 is about $1400!
  3. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,140
    E ' ' '/ F
    Snike Fingersmith
    How is it any different than any other 348 > 355 conversion if it was repaired correctly? I'd put the value just south of an equivalent unmodified 348, for the right buyer
  4. Kevallino
    Kevallino Formula 3
    Feb 10, 2004
    2,257
    Mid-Ohio
    Kevin
    Note that it is a salvage title as well, so even as a 348 that will knock it down. You'd have to buy it to keep it I reckon. I had a passenger window problem on my car that was just north of $1K to fix so that isn't small beer and I never can quite understand how people put cars up for sale with "easy fixes" for the next guy.
    This car is worth more than $20K but much north of $30K ain't likely IMHO. I'd have it but then again I am a sick bastard.
    Cheers
    Kevin
  5. fatbillybob
    Aug 10, 2002
    29,021
    socal
    We should go on every car mesage board and everyone gang e-mail ebay to allow ebay to open viewing of bids under the top bid. Then we can bid 5000.00 bucks for a POS parts car like this and other buyers will get the message to say away. I would LMAO seeing the bid at 30K then dropping to 5K. There is a sucker born every minute.
  6. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    It looks okay on the low res pictures on the computer. the seller says the paint is okay but don't expect too much. It looks like the seller will not get their buy it now unless a real impulsive buyer comes along.
    BT
  7. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    Did anyone notice the burned (melted) spot on the center console. If he gets 43K for that bucket I want 80K for my 348. :)
  8. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    SALVAGE TITLE. Repaired correctly wouldn't include the veilside rear grill or the non working window or ABS light that Norwood couldn't turn off.
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  10. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Maybe he transposed digits! Yeah, that's it. He meant $34k, not $43k!
    Seriously, $34k for a Salvage Title, non-original, 348 TS with known problems such as window, ABS, center console, bent rims...that would be top Dollar retail for that particular car in my book...and I wouldn't pay it.
  11. Dino 208gt4
    Dino 208gt4 F1 World Champ
    Jun 24, 2003
    14,868
    European Union
    Roel
    Looks like a kitkar!! Especially the backside.
  12. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    17K is tops for this car. I bet Norwood couldn't turn out the ABS light because he wouldn't pony up the 3K or so o get it turned off
  13. rleander
    rleander Karting
    Sep 23, 2002
    115
    Winston-Salem NC
    Run Away, Run Away
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    He probably doesn't know how to check the ABS error codes...and he may not know that he can have the 348's ABS ECU rebuilt for $350 instead of paying $3,200.00 for a new one.
    But he sure knows that he wants top Dollar for a still-unfixed Salvage car.
  15. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    If the car was at Norwood I'm sure they checked the error codes, but probably right about the rebuild on the ABS ECU
  16. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    What is a "Lightweight 355 Body"? Is he talking about pieces from a Fiero conversion, or did someone actually produce body panels designed to reduce the weight of the 355? I've never heard of that.
  17. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    He's probably just saying that the 355 door panels, without the 348 exterior side rakes, weigh less than the 348 door panels. That's why the 348 Competitizione had them removed first, after all.
    If any of the other pieces are significantly lighter, I'd be surprised. Then again, based on so many other things in his ad/auction, that car may *have* kit-car parts on it!
  18. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    The rear is the veilside kit piece
  19. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    My gosh, how much could a "side strake" weigh? 3 or 4 pounds max?
