348TS | FerrariChat
348TS
Discussion in '348/355' started by fdekeu, Jul 4, 2016.
  1. fdekeu
    fdekeu Formula Junior
    632
    Belzium
    Frank
    I ve been driving the 348TS for some weeks now
    Because the weather is very bad lately I noticed the roof was leaking
    The rubbers seem OK
    I adjusted the latches
    Even taped the front and rear gap
    Keeps leaking
    Did a search here but did not find a lot
    Somebody has some experience in this area??
  2. FlxJet146
    FlxJet146 Rookie
    Apr 26, 2016
    4
    Brussels, Belgium
    Hi I live in the same country, not quiet lucky at the moment weatherwise indeed;
    Also drives the TS, not leaking, so cant really help but heard quiet a few times that rubber seals were probably the cause of these leaks.
    I try as much as possible not to drive while raining. only sunny and dry roads will do.
    What part of the country are you from?
    Alex
  3. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    I live in Singapore. It rains quite often. And sometimes when it pours, it really pours. I have a 348 TS but it does not leak - not even in the middle of the heaviest tropical downpours. I do remember my mechanic saying, however, that the seals on my targa top has been "upgraded" to the 355 seals. I am not sure what that means but I hope this will enable you to look further into this issue. Good luck!
  4. fdekeu
    632
    Belzium
    Frank
    Thanks for the replies
    Will inspect the rubbers again
    Alex: I live near Lier
  5. Kristafury
    Kristafury Rookie
    Apr 6, 2019
    2
    CHRISTOPHER COLIN FONG
    Hi CMNHO,
    Sorry for bringing up an old thread but I live in Singapore as well and was looking at a used Ferrari 348TS for sale. There were some concerns with the car and in particular, someone I was talking to at the mechanic's shop told me that 348TS' were notorious for their water leaks. I was just wondering if you were able to clarify which seals were installed and if you were able to provide some advice on a purchase/running of one in Singapore.
    Best Regards,
    Kristafury
  6. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  7. Kristafury
    Kristafury Rookie
    Apr 6, 2019
    2
    Hi Ferrarium!
    Thanks for the quick reply, I myself have had a look at the various threads but it is just that there are about 5 348's in Singapore (close to the equator so summer all year round, very humid and known for torrential rain) so when I read about CMNHO having a 348TS that was was able to withstand Singapore's weather I was wondering what kind of set-up he had with his car and I was just having a shot in the dark in contacting him as he doesn't seem to be online that frequently but having a local in the same situation would be much more convenient. :)
