350/400GT thread | Page 32 | FerrariChat
350/400GT thread
Discussion in 'LamborghiniChat.com' started by FredParoutaud, Sep 5, 2007.
  1. Olivier NAMECHE
    Olivier NAMECHE F1 Veteran
    Aug 18, 2007
    5,098
    CANADA
    Olivier
    it was grigio St Vincent instead of blue now... with senape interior, engine #0707, delivered 15/11/1965 to Kaplan
  2. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #778 P400, Nov 25, 2010
    Anyone able to confirm the color scheme for 1966-68 Armstrongs used on Lamborghini?
    Many restorations tend to make them look like Koni, which we know is not correct.
  3. kc023515
    kc023515 Formula Junior
    Dec 5, 2007
    600
    Belgium
    Kevin Crauwels
    Olivier, are you sure about the delivery date? As far as I know only 2 or 3 400GT2+2 were delivered in 1965. All other were delivered in 1966 and later.
    Probably the delivery date is 15/11/1966
  4. Olivier NAMECHE
    Aug 18, 2007
    5,098
    CANADA
    Olivier
    That's my birthday... you are right, my apologies it is correct 1966...
  5. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #781 P400, Dec 3, 2010
    What is the purpose of VN-02209 and RN02210?
    They indeed look like a small machine screw and split or plain washer, but for what purpose and how many?
    thanks
    Craig
  6. FredParoutaud
    FredParoutaud Formula 3
    Jun 9, 2004
    1,455
    Darned good question, Craig. Is it a grease fitting? Is it to evacuate moisture? Is it for balancing? No idea.
    But again, it's amazing how a few hose-clamps can be used to dial the whole mess in. :)
    Fred
  7. FredParoutaud
    Jun 9, 2004
    1,455
    I think that's right, Craig. In fact, is that my photo? I took one like that of Robert's 400GT #517 a few years ago, after Bobileff restored the shocks.
    Fred
  8. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #784 P400, Dec 3, 2010
    Going for heat and more leverage. I have not had much luck with WD40 and the like. It would seem an acid spray would be better for rusty nuts. Anyone have experience with this?
    Also I am going to have to narrow a box end wrench head to fit this space. Only space for 24mm(15/16") open end at this time.
  9. rightnwrong
    rightnwrong Rookie
    Dec 1, 2010
    6
    Is that a vintage 2NA? It looks like vintage.
  10. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #786 P400, Dec 4, 2010
    A slightly narrowed, 24mm box end (ring spanner) allowed a more confident level of of force and the rotoflex nuts came right off. Some moderate cleaning was done before picture taken. Quite a "nose" on the pinion that engages the rotoflex.
    Craig
  11. ApexOversteer
    ApexOversteer F1 Veteran
    Feb 15, 2007
    5,968
    Smoky Mountains, TN
    T.A. Bell
    #787 ApexOversteer, Dec 4, 2010
  12. FredParoutaud
    Jun 9, 2004
    1,455
    I'm pretty sure that's a factory photo (green car with female hanging out)
    Many, many factory photos featured women in them. In fact -- maybe all?
    I guess two things going on, psychologically speaking.
    1 - Guy wants woman in photo. Can get that with a 400GT 2+2
    2 - Woman (wife or girlfriend of guy) wants excitement in her life. Can get that with a 400GT 2+2
    (What would Freud say?)
    Fred
  13. FredParoutaud
    Jun 9, 2004
    1,455
    #789 FredParoutaud, Dec 4, 2010
    Craig, I'm not sure what to say about your "rear end" experiences.
    Except that I had no real problems getting mine out, or back in. Of course, that was 25 years ago, and I was a lot younger...as was the car.
    (I wonder what Freud would say about this?)
    (Maybe "any nose that is long enough to write 'Lamborghini' on it, is quite a long nose indeed")
    Fred
  14. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #790 P400, Dec 5, 2010
    The pinion nose will not allow the differential to drop straight down and out as the three rubber mount points will allow......so you need to remove the two forward "wing mount" bolts to allow removing the front crossmember, then you can drop the diff rear and pull to the rear to allow this pinion nose to pull free from the driveshaft.
  15. staatsof
    96,256
    Fuggetaboutitland
    Bob
    #791 staatsof, Dec 5, 2010
    Craig, what Gary Bobileff suggested to me for my driveshaft vibration is that assuming the donut isn't bad you need to shift that ball ring's position so that it rides on a spot in the bushing that's not worn. Now that you've posted these pictures I can what he means. Maybe a combination of that and better balancing?
    Bob S.
  16. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #792 P400, Dec 5, 2010
    This breather is topped with a dome which will not allow even the thinnest standard 17mm wrench to fit. It requires a sheet metal type open end, which even with a thousand tools, i dont seem to have a set of sheet metal metrics or standard (11/16) open ends. I have searched my cheapest motorcycle tool kits, still nutin.
  17. P400
    P400 Formula Junior
    535
    east coast
    Craig
    Bob, looks like you could space/shim it forward maybe 1/8". Is there a renewable bushing in the driveshaft? This is lubed only when disassembled/assembled?
  18. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #794 P400, Dec 5, 2010
  19. Olivier NAMECHE
    Aug 18, 2007
    5,098
    CANADA
    Olivier
    Owner's book says :
    1. check & fill in to level every 5.000 km
    2. every 20.000 km replace fluid by new one
  20. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #796 P400, Dec 5, 2010
    I recalled the chuck tools that are supplied with air tools or porting tools usually are sheetmetal. 30 seconds later the very first chuck tool i located was 17mm, perfect!
    Simple design sfogo of 4 holes shrouded with a metal cap, screen crimped in bottom. Cap appears zinc plated with red paint. no gasket
  21. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #797 P400, Dec 5, 2010
    Thanks Olivier, Is this differential the same casting/mechanicals as Islero?
    What is the special gear S 90 for differenziale and guida steering box?
  22. Olivier NAMECHE
    Aug 18, 2007
    5,098
    CANADA
    Olivier
    Islero has the same mechanical components to 400 GT 2+2, only bodywork and interior were changed.
    Making a comparison between 400 GT 2+2 & Islero owner manual, both explanations look similar.
    Regarding fluid, that's what it seems...
  23. P400
    P400 Formula Junior
    535
    east coast
    Craig
    #799 P400, Dec 6, 2010
    Anyone have additional photos of the drive train for 2+2?
    check out the
    1) air cleaner stickers
    2) differential vent (early/late?)
    3) marelli condensor position
    4) inlet snorkle paint on air cleaners
    5) routing of spark wires
    6) different texture (from the rest) of oil fill cap
    7) ac hold down knobs
    8) swirl pattern on fuel hoses
    9) ?
  24. FredParoutaud
    Jun 9, 2004
    1,455
    I hope so Craig, because that one doesn't have the various black colors I would expect to see re the block and valve covers. I think there were a number of cosmetic changes as production continued...but I don't know that for a fact.
    Fred
