350/400GT thread | Page 79 | FerrariChat
350/400GT thread
Discussion in 'LamborghiniChat.com' started by FredParoutaud, Sep 5, 2007.
  1. Olivier NAMECHE
    Olivier NAMECHE F1 Veteran
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    mistake
  2. rmolke85
    rmolke85 Formula Junior
    Mar 11, 2013
    748
    I meant the 2+2 cars. Still same chassis there too?
  3. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    yes still..., the same as Islero 2+2
  4. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    Mistake, Olivier
  5. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    please develop...
  6. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    Polo Storico will do that, I think. They are doing a great job. But you can ask the framebuilder, he is still on duty.
    The 400GT frame is more heavy than the 350GT. Same advance as the Miura.
  7. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    #1957 Olivier NAMECHE, May 4, 2017
    Ok that's all you have
    I have interviewed Marchesi he has confirmed me that exception of the body supports the structure frame is identical
    You have also to read the brochure specs and homologation specs... for instance width is identical at 1,73 m... lenght 4,46 m... for 350 GT, 400 GT, 400 GT 2+2
    I have interviewed Marazzi in Varese who also confirmed to have used the 400 GT 2+2 frame with a new body he has created...
  8. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    Only the last 11 cars have the new 400GT frame.
  9. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    please developp...
  10. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    Not my job. But 23 Interim is a fairy tale.
  11. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    #1961 Olivier NAMECHE, May 4, 2017
    not my job too... but if you want to argue, you need to feed us too...
    I have identified the 23x Interim...
    Among them, Gary Bobileff has restored 5x of them, frame is same, as I wrote there are slight différences in the structure to support body, as well as small differences in some other areas... but globally frame is identical, it is the 1st design conserve for the developpment of the range and in terms of sizes too !
    to illustrate here is a 400 GT frame...
  12. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    If you did identify 23 cars, please let us know the VINs
  13. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    you will discover these in my encyclopedia when it will be released...
  14. joe sackey
    Sponsor
    May 23, 2006
    57,331
    Southern California
    Joe Sackey
    :rolleyes:
  15. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    hé yes... that's how it is, and how it is progressing...
  16. Lel
    Lel Formula Junior
    Oct 11, 2007
    295
    #1966 Lel, May 5, 2017
  17. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    the front square sections yes, it was a 400 GT 2+2 modified to receive a Bizzarini body...
    but you can look in De La Rive box book they are pictures of the frame too.
  18. staatsof
    91,600
    Fuggetaboutitland
    Bob
    It's kind of early over here yet for popcorn but I'll go warm up a batch with some butter, salt and if this goes long enough we can even break out the bourbon too! :D
    I have to admit that I'm sort of fascinated about all of this murky early 350/400GT stuff and have never quite followed all of it. The very idea that Lamborghini had any hard standards on this stuff back then and kept meticulous records about it is hysterical enough all by itself! I can well beleive that Olivier has worked very hard trying to figure it all out. Too bad that the thread's starter is no longer with us because Fred was veritable fountain of information on this stuff. But we've got some other good folks here. Someone should drag Gary into this thread. Probably kicking and screaming ... :D
    Carry on ... :)
  19. Andrew R.
    Andrew R. Formula Junior
    Jun 27, 2005
    593
    Michigan
    Andrew
    This looks like the chopped up 400GT frame that was in California for sale a few years ago.
  20. Andrew R.
    Jun 27, 2005
    593
    Michigan
    Andrew
    Will Marchesi share the drawings? That would settle this discussion!
    I know that between the 350GT and 400GT, the mounting for the rear differential is not the same. (ZF versus Lamborghini rear-end) And yes, I know the switch over point is another topic.
  21. Lel
    Lel Formula Junior
    Oct 11, 2007
    295
    The mounting support for the transmission is different on cars with ZF-gearbox or Lamborghini-gearbox.
    And the trailing arms for the rear uprights are mounted forwards on two-seaters (big rear window) and backwards on the four-seaters (small rear window) and Isleros.
    But the chassis never had any round tubes!
    L-E
  22. staatsof
    91,600
    Fuggetaboutitland
    Bob
    Isn't Olivier saying that the round tubes modification were for a custom Bizzarrini body that was placed on that specific chassis? That's how I read it.
    And here's the link, Bogus Bizzarrini,
    Bogus Bizzarrini: 1967 Lamborghini 400GT
  23. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    I shared with Polo Storico, so ask them if you want a quicker answer...
  24. Olivier NAMECHE
    Aug 18, 2007
    5,079
    CANADA
    Olivier
    Thanks...
  25. Marcello
    Marcello Formula 3
    Sep 6, 2004
    2,244
    The Netherlands
    Marcel Wallenburg
    Or you can just check my 350 GT Register: 350 GT / 400 GT Internazionale | Ferrari - Lamborghini Register Nederland
    The cars that left factory as 400 GT are listed, and otherwise the cars are listed as 350 GT 4 litri, as in fitted with a 4 liter engine afterwards. I will not use the term Interim on either of them ;-)
    Ciao!
    Marcel
