3500 GT Spyder Vignale thread | Page 11 | FerrariChat
Discussion in 'Maserati' started by wbaeumer, Jun 19, 2008.
  1. wlemasters
    wlemasters Rookie
    Feb 28, 2006
    29
    Fallbrook, CA
    Bill LeMasters
  2. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    Thank you Bill, I can see a consensus beginning to be formed here.
    Smooth seems to have been used more often than not, and quilted very little or not at all.
    FGM
  3. awohlmann
    awohlmann Karting
    Jul 6, 2008
    162
    Austria
    Alfred Wohlmann
    I don't want to be fussy, but not both sides do have the diamond pattern. Only the right side has it. The left side - the cover of the place where the battery is located, does not have diamond pattern. It's the same material (like orange peel) but NO fleece below, and NO diamond pattern. Also the covers of the shock absorbers and the cover of the rear axle (from left to right), these parts are without diamond pattern.
    This is what I found on a VERY original (unrestored) one-owner car in Italy some years ago as well as on my #871, also completely original, when located in Australia.
    Wanted to say this just for those who intend to make a "perfect" restoration. :)
    Alfred
    PS: the fotos were made before restoration was completely finished. Now the black carpet is also fixed correctly.
  4. thecarnut
    thecarnut F1 Rookie Rossa Subscribed
    Apr 22, 2006
    3,274
    Atlanta
    The Car Nut
    On #504 the trunk material is exactly as Alfred describes it. The trunk on this car has never been restored.
    It is difficult to see in these photos but when you look at the high resolution version and zoom in you can see that the right hand side has the diamonds but not the battery cover nor the shock tops.
    Ivan
  5. eogorman
    eogorman Formula Junior
    May 10, 2005
    339
    Buhl, ID
    Eugene O'Gorman
    When I purchased my car # 101 1119 35 years ago the trunk still had the original small diamond pattern. My car did have the diamond pattern on both the shock covers and the battery cover. I think the problem we always face with Maserati is they did a lot of things different from car to car, and both ways are probably correct.
  6. TridenteFury
    TridenteFury Karting
    Sep 28, 2014
    78
    Not sure. On this 61 V.S. under the hood was plain, exactly like in Alfred's photo. (sorry no pic)
    The trunk however had the diamond pattern, but not on shock covers nor on battery cover. Here a very original, authentic untouched V.S., carpet is also totally authentic original.
    Ciao
    Carlito
  7. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    Here is an interesting photo showing the dif of my Vignale #1121.
    I cleaned off the tag and this is what I found. AUTBL00 46/13.
    And yes, both tires turn in the same direction. I my day we called this "positraction"
    Ciao,
    FGM
  8. awohlmann
    awohlmann Karting
    Jul 6, 2008
    162
    Austria
    Alfred Wohlmann
    I read it as "AUTOBLOC 46/13" (self-locking differential ? - ratio 46/13 also called 3,54 which was the standard ratio according to the Vignale manual - see side 4)
    Alfred
  9. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    Yes you are correct "AUTOBLOC"
    FGM
  10. wilde
    wilde Formula Junior
    Jan 12, 2009
    261
    France
    Lynx Eventer, one of my all time favorite car, pretty rare in United States ! Bill, do you know its production number ? 61 ???
  11. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    NEP likes this.
  12. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
  13. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,293
    Harriman, TN USA
    Michael Demyanovich
    Hello Frank...
    Looking great... But one question... From the picture it looks like there is no
    insulation material/carpet padding between the carpet and metal floor. Am I
    seeing that correctly?
  14. bella-donna
    bella-donna Rookie
    Feb 14, 2016
    45
    NEP likes this.
  15. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    Hi Bella-donna,
    I would be extremely thankful if you could please forward these Vignale spyder photos to me along with any other photos showing the car to:
    [email protected]
    Thank you very much for sharing them.
    Ciao,
    Frank Mandarano
  16. bella-donna
    bella-donna Rookie
    Feb 14, 2016
    45
  17. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    Thank you.
    I see you have cut a access panel for servicing the transmission.
    This seems to be a very good idea. Have you seen this done before?
    Ciao,
    FGM
  18. awohlmann
    awohlmann Karting
    Jul 6, 2008
    162
    Austria
    Alfred Wohlmann
    Hi Frank,
    if you intend to make the transmission cap without diamond patterns I would not cut an access panel. To maintain the transmission, for me would not be worth to modify originality. Maybe with the diamond structure the cap does not look so bad, but when using the plain leather I would not like to see an additional cover.
    This is only the point of view of a "crazy fool of originality"
    Alfred
  19. thecarnut
    Apr 22, 2006
    3,274
    Atlanta
    The Car Nut
    +1. There is not that much maintenance to be done on a transmission. The infrequent oil changes can be done using a hand oil pump.
    Ivan
  20. eogorman
    May 10, 2005
    339
    Buhl, ID
    Eugene O'Gorman
    The fill plug is on the right side of the transmission and the drain plug is in the bottom so I do no understand that plate on the left. On the S5-15 the bump in the transmission tunnel is for the shift plate and cover so no maintenance there. It may be the car has an after market transmission since it does not have the bump in the tunnel. certainly a little strange.
  21. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
  22. bella-donna
    bella-donna Rookie
    Feb 14, 2016
    45
    i am pleased with you, your great car and the works on the new carpeting.
    br
  23. bella-donna
    bella-donna Rookie
    Feb 14, 2016
    45
    NEP likes this.
  24. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    I love the color combination of this car. Beautiful simply beautiful.
    More photos of the seats please.
    FGM
  25. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    You may recall I had installed two smaller seats out of a Canadian Electric car call the ZEN.
    The smaller seats allowed me to stretch my legs out and was much more comfortable on long drives, for a guy my size.
    Note: how the backs recline more than the originals and are much lower.
    The original seats I am convinced were made for short Italian guys.
    So while doing the complete interior in new PAC1386 leather as specified on the build sheet of my car, I also re-leathered the ZEN seats to match. This is what they now look like.
    You will note I have had them done in the same style pleats as the originals.
    The leather came from Italy along with the pre thinned piping that was pre sewn.
    As I plan to drive the car a lot these seats work great!
    I mounted them on a sheet of Aluminum and attached the aluminum plate to the original seat holes, so they go in and out in 5 minutes.
