3500GT, AM101-1886
Discussion in 'Maserati' started by Dalin, Jan 25, 2015.
  1. Portenos
    Portenos Formula 3
    1,679
    Seattle
    Carguytour
    #26 Portenos, Oct 11, 2016
    Are you sure it was a Lucas fuel pump.
    I am thinking it was originally fitted with two MONOFLUX fuel pumps, like the ones shown in the photos below.
    I have had these fuel lines made in Italy for my car #916 (see photo) but the fittings were very difficult to source.
    In the end I located the originals, at a very dear price.
    Ciao,
    FGM
  2. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    #27 Dalin, Oct 12, 2016
    This is exactly what the technical sheet says, see picture. The car was delivered with carburetors, my impression is that sometimes in the time when injection cars were already produced, they must have changed from Monoflux to Lucas pump, probably because Monoflux were too outdated and not that good anymore compared to what Lucas offered? Or was the Monoflux used all the time you think and someone just made a mistake in the technical sheet?
  3. Portenos
    Portenos Formula 3
    1,679
    Seattle
    Carguytour
    Does it say carburetors on the build sheet?
    It would be interesting to hear from others who actually have, as originally fitted, a Lucas low pressure pump.
    Regarding this particular question your guess is as good as mine.
    Ciao,
    FGM
  4. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    #29 Dalin, Oct 12, 2016
  5. Portenos
    Portenos Formula 3
    1,679
    Seattle
    Carguytour
    Very good.
    It seems yes your car was delivered with Weber 42 DCOE 8's.
    Now the only question is, Lucas low pressure pump, or typo.
    I have to believe its a typo.
    But its only a guess.
    FGM
  6. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    #31 Dalin, Oct 14, 2016
    OK, here comes the answer about Lucas fuel pump:
    This is the information I received:
    1961 --> 1 Lucas pump (plunged, inside the fuel tank) (model 2 F.P) + filter Fispa (model FN.376.R) external. (Configuration used mostly on the injection engine version)
    As shown in table 32 of the parts manual, fuel pump shall be plunged in a small box into the fuel tank. The proof stands in my technical data sheet, reading the whole text after "Lucas" it doesn't say "iniezione" as I first thought, but "ad immersione", which means... plunged!
    Problem solved, unfortunately only days after my new fuel tank was finished, so probably I will have to cut it again...
    The remaining question is now positioning of the fuel filter, most likely it was not under the rear wing anymore, but in the engine compartment? Can anybody with a GTi confirm/make a picture of?
  7. Tired of seeing this ad? Upgrade now
  8. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    #32 Dalin, Oct 19, 2016
  9. Portenos
    Portenos Formula 3
    1,679
    Seattle
    Carguytour
    Congratulations, the body looks very well done, and the engine looks simply beautiful!
    More photos will be very welcome as you progress.
    Ciao,
    FGM
  10. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    #34 Dalin, Oct 31, 2016
  11. Portenos
    Portenos Formula 3
    1,679
    Seattle
    Carguytour
    Those doors are not easy, but it looks like you have a very good feel for preparing them.
    Do I see al new fasteners?
    Great job and yes, everything must be fitted, then re fitted again and again together with the seals before paint.
    Ciao,
    FGM
  12. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    Thanks Frank! Always very encouraging to see your comments.
    Yes, the fasteners are new, unfortunately the originals were not usable. I will look after the visible ones to match the correct ones.
  13. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    #37 Dalin, Jul 5, 2017
    It's been some time since my last post, but plenty of things have happened. Well, I though the car would be finished by now back then, still a bit of work as every small thing takes much more time than I would ever imagine.
    So, what did we do since October? The car has spent 4 months in the paint workshop, returned in a beautiful Grigio Newmarket Metallizzato, great quality of work, took me some time to get used to the colour, but it looks more beautiful every day.
    Engine is now in, as are the windscreens, the ceiling and dashboard covered by upholstery, most of electrics done, chrome parts - greatly done - have just returned and being installed, most should be done within a few weeks before she finally goes to the upholsterer to finish the interior, then it's going to be just cosmetics.
    Most of the jobs are of very good quality, but man makes mistakes as well - the biggest fault of mine were an improper choice of companies refurbishing the instruments and the steering wheel - both left me speechless when returned, the guy making the steering wheel simply created a new totally different one, having lied to me about working on it for more than half a year, the instruments were done pretty fast by a company in England, but with a pretty poor result. Both have to be redone by proper experts. Man learns by making mistakes...
  14. Tired of seeing this ad? Upgrade now
  15. jjeffries
    jjeffries Karting
    Sep 4, 2012
    116
    Connecticut
    John Jeffries
    Great transformation for this handsome and gentlemanly car...a true aristocrat. I once owned, briefly, a rough 58 Alfa Touring Spider with steel hardtop. This car reminds me of it, just better. John in CT
  16. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    #39 Dalin, Jul 17, 2017
    A few more things in now, the dashboard almost finished waiting for the instruments to return.
    Radio in, need to source speakers.
    Antenna, placed at the back of the car, is Autovox electric type. Two wires, on of which closes the antenna when connected to +, supposed to be connected to + pole all the time. The other one, when connected to + ejects the antenna - does anybody have any experience how that should be connected? Is the antenna supposed to be operated by radio, or should there be a separate switcher? (there is no wire coming from the radio which might send + to the antenna, was thinking about some diode or something that would tell the antenna the radio was switched on?)
    Airbox, the later fiberglass type, was an incredible job to get in. No way it could be got into the car with the 3500GT long air horns already in, the solution in the end was to get the air horns out, then the airbox in (already with literally milimetres of space), then getting the air horns in one by one, screwing them to carbs while moving the airbox back and forward to get a little more space where needed. Is that the same for the older type metal airbox?
  17. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    More delays. All in except for a few things. The car in a trimmer workshop now, interior almost finished, trunk to be done in the next few days. Then a few chromed parts would be missing, a guy owning our workshop had his company closed suddenly for using environment unfriendly old technology. Thanks god it's winter starting here and the car not anymore in such a hurry - plenty of other work in the meantime...
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  18. Portenos
    Portenos Formula 3
    1,679
    Seattle
    Carguytour
    Spectacular!! You are doing a marvelous job! As you now know none of this is easy. I totally understand how you felt getting the cold air box installed.
    The color combination is very handsome. Thank you for posting the photos of the progress.
    Ciao,
    FGM
  19. Dalin
    Dalin Rookie
    Jun 3, 2013
    37
    Thanks Frank, you are always encouraging. I am learning to be patient, everything takes time. Hopefully it pays off, I made quite a few mistakes on the way that upset me and took more time to correct. Steering wheel still to be sorted out, one from 1960 3500GT has been borrowed, this car should have the white button type.
    Teaser of interior (almost) finished, few minor details to be fine tuned later.
    Winter is just starting here, so no more in a rush to get the car finished soon as I have more urgent work on another car.
  20. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    66
    Keith
    Excellent job Dalin, This will be one of the best 3500GTs on the road. The boot trim is amazing.
    Keith
  21. gtjoey
    gtjoey Formula Junior
    Aug 12, 2014
    267
    Can I applaud you .....When I go through these projects and everyone laughs,they never understand the what and why.
    Then when complete everyone wants it!
    Detail is wonderful, just a lovely car, enjoy it and please DRIVE IT!
    All the best
    GTJOEY1314
