3500GT Barnfind | Page 10 | FerrariChat
3500GT Barnfind
Discussion in 'Maserati' started by mfletch, Jan 8, 2009.
  1. velocetwo
    velocetwo F1 World Champ
    Dec 11, 2006
    12,545
    Left Coast
    Love the patina, what a great car! Congratulations!
  2. awohlmann
    awohlmann Karting
    Jul 6, 2008
    159
    Austria
    Alfred Wohlmann
    Hello,
    On my 3500GT Touring, 59 I use the LODGE 3HLN spark plugs, as recommended in the Maserati user manual. They work great. Any bad experiences with these plugs in the forum?
    Alfred
  3. mfletch
    mfletch Formula Junior
    Nov 3, 2008
    480
    #228 mfletch, Dec 12, 2010
    I didn't have any trouble installing the cables in the tube (a little silicone spray really helped). I left plenty of extra wire to make the lengths perfect. I am having trouble figuring out how to attach the wires to the plug boots and crimped ends on the cap side. The translucent plastic pieces adapt the wires to the plug boots, so there isn't a large gap.
    Ivan, thanks for the response. The chrome tube looks exactly like the pictures of the restored cars that I have seen. My car did not have the original tube, so I don't have anything to compare it to. It had lots of rubber debris stuck to the inside of the tube...it appears that it might have been an original tube that was refinished.
    Alfred, thanks for the plug advice.
  4. 3500 GT
    3500 GT Formula 3
    Nov 2, 2008
    1,479
    Gentleman Racer
    #229 3500 GT, Dec 12, 2010
    ........ I am having trouble figuring out how to attach the wires to the plug boots and crimped ends on the cap side. The translucent plastic pieces adapt the wires to the plug boots, so there isn't a large gap...........
    ....Mark there is a crimping tool used to attach the contact ends to the wires. You can get them at a NAPA and most decent auto stores. I think that's all you need!
    Did you get your parts from Jacques @ Maseratisource???
    ~Ciao!!!
  5. mfletch
    Nov 3, 2008
    480
    Trev, thanks for the info. I bought them from Jacques. He has been a pleasure to deal with.
  6. mfletch
    Nov 3, 2008
    480
    #231 mfletch, Jan 12, 2011
  7. 3500 GT
    3500 GT Formula 3
    Nov 2, 2008
    1,479
    Gentleman Racer
    #232 3500 GT, Jan 12, 2011
    Hey Mark!! Did you note what the WHITE lettering on the rear of your differential was?
    I believe those were factory markings, denoting the gear raito, and or limited slip diff.
    My car has them,....I will be reproducing any factory marking in a restoration, so I just thought I'd ask what you are doing.
    I hope you took a photo BEFORE the lettering was removed!!! :) Also, not a slight,...but the brake line should not be painted red on top of the diff.
    Ciao and best!
  8. thecarnut
    thecarnut F1 Rookie
    3,230
    Atlanta
    The Car Nut
    Interesting, as I have not seen that lettering before. On my car there is a tag with the diff ratio. The tag is attached to one of the lower cover bolts. I noticed this diff does not have a tag. Does yours have a tag? Perhaps the painted letters were used on differentials with non-standard ratios.
    Ivan
    Ivan
  9. mfletch
    Nov 3, 2008
    480
    #234 mfletch, Jan 12, 2011
    Hi Trev, just to show how ignorant I am about such things....I never noticed the lettering until you pointed it out. I did take several pictures of the differential, prior to cleaning it. It appears to read 18 or 1B with a line under it. The previous owner told my brother and I that the car had optional gearing. He called them "Alpine gears". I would be interested in seeing pictures of other cars that had the white lettering, if anybody has seen it before. I am going to paint the brake line with a brush tomorrow. Thanks for the info.
    Hi Ivan, my differential has a tag on the top bolt. It is visible in the second picture. I will try to read it tomorrow and post the info. It never occurred to me that the white letters were original or meant anything. I wouldn't have guessed that the shocks were green and the differential was orange, if it wasn't for you.
  10. redfred84
    redfred84 Formula Junior
    Dec 24, 2010
    735
    SF Bay Area, USA
    This thread is great. Wish I knew of it when I first acquired my own barn fresh 3500 (but this one was stored OUTSIDE of the barn!).
    As for the new plug wire kit w/loom, I found the chrome loom to be an exact copy of the unit on my car. Not sure if my car had it's original loom, but it still had the original tires on it, so I would presume the loom to be accurate,,,,,,,,although my plug wires were black, and not the proper green.
    Lacing the looms was a chore, but one I could do in the confines of living room of the house (love those "clean" jobs). I found that new boots to be slightly different than the original, and very loose fitting; but they seem to work. I had to fish 2 additional ignition wires through my loom to accomadate the Pertronix electronic ignition installed in my distributor (I highly recommend their system, especially built for our 6 cyls cars). I am still on my original new plugs that I test fired, and dialed in the engine with, after 3 years of "spirited driving". I thank the Pertronix system for the longevity of the plugs.
    Many Thanks, RF
    AM 101-1512
  11. mfletch
    Nov 3, 2008
    480
    RF, thanks. Please feel free to post pictures here of your car. I would love to see them. The wires were fun to do...I'm not too sure that my wife appreciated me doing them on the kitchen table. I know that she did not appreciate me doing the final assembly of the Webers there.
    Thanks for the information on the Petronix ignition. It sounds like a great upgrade.
  12. eogorman
    eogorman Formula Junior
    May 10, 2005
    337
    Buhl, ID
    Eugene O'Gorman
    Redfred
    I believe some of the cars did come from the Factory with black wires. I have seen three 3500s with black wires and I believe they were all original. The black wire also has Cavis on it. It depends on what they had on the shelf the day your car was built.
  13. 3500 GT
    3500 GT Formula 3
    Nov 2, 2008
    1,479
    Gentleman Racer
    Hi Ivan,...my diff. does not have a tag, but it does have paint markings on the rear and side of the diff. My car is has every option you could get, so I would agree with your theory that white markings would indicate specific raito. Or they could be build numbers etc. But I'm thinking they relate only to the diff. raito.
    ~ Trev
  14. 3500 GT
    3500 GT Formula 3
    Nov 2, 2008
    1,479
    Gentleman Racer
    ...my 36,000 mile car has original Cavis black wires! Depends on what was in stock on that day.
    ~ciao
  15. redfred84
    Dec 24, 2010
    735
    SF Bay Area, USA
    Ah, thanks for input on the wires. Glad I saved them. The car also came with a spare roll of the black wire, enough to do an entire car. I'll have to check if it has the writing though.
    I just flushed out the trans & rear end oil in an effort of preventative maintanance. Everything looked fine, just like it did when I flushed it out when I first got the car.
    However, this time, I loosened the rear wheel cylinders (drum rear) and let them flop around a little. Before I had them tightened up, and my emergency brake bound. Now that I've examined the springs under the self locking nuts that retain the rear wheel cyls, I've decided to leave them a little loose to let the wheel cylinder "float", and self center.
    Any comments on this?
    PS. We're thinking of a drive on Super Bowl Sunday out West here. A group of young, spirited Melee drivers usually gather for these events. More as the info filters in.
  16. lavaux
    lavaux Karting
    Jul 18, 2009
    124
    Cully, Switzerland
    Wilfried Vogel
    So, there is a Pertronix for the Marelli 6 cylinder twinspark? Are there two separate circuits, one for each coil? Have you had any problems in adjusting the timing? Is the timing made for both plugs at the same time or separately?
    Lavaux/Wilfried
  17. redfred84
    Dec 24, 2010
    735
    SF Bay Area, USA
    Pertronix made up a dual system for our distributors. One for each coil. The timing seems spot on, and I have not had to make any adjustments. I highly recommend this ignition, as it is a simple conversion, and is barely noticed from original. One may still keep the old points in the trunk for a back-up system also.
    Can anyone coach me on how to post photos here? Pehaps off line to me direct may be best?
    <[email protected]>
    Thanks, RF.
  18. mfletch
    Nov 3, 2008
    480
    Hi Wilfried!
    RF, if you reply to this thread, left click on manage attachments. Left click browse and that will allow you to browse the photos in your hard drive. Double click on a photo and select upload. The pictures will post when you submit your reply. Good luck.
  19. redfred84
    Dec 24, 2010
    735
    SF Bay Area, USA
    #244 redfred84, Jan 17, 2011
  20. lavaux
    lavaux Karting
    Jul 18, 2009
    124
    Cully, Switzerland
    Wilfried Vogel
    Hi Mark!
    Thanks redfred for your info!
    Wilfried
  21. lavaux
    lavaux Karting
    Jul 18, 2009
    124
    Cully, Switzerland
    Wilfried Vogel
    Hello redfred,
    I have just gone through the very extensive Pertronix catalog, but found only a system for the V8 Maseratis.
    Where did you buy the system for 6cylinder dual spark, what is it called, and how much was it?
    Wilfried
  22. redfred84
    Dec 24, 2010
    735
    SF Bay Area, USA
    Hello Wilfried,
    I actually sent my distributor to them for the development of this unit. I believe I worked with Mr. Marvin Grebow at Pertronix <[email protected]> or 909-599-5955. Hopefully Marvin will be able to help you obtain this unit.
    Actually, the unit is a "pair" since we use a double ignition. Their ignition kits are usually around $150 each, and this dual unit was reflective of that cost (around $300 I believe). It is an easy conversion, and saves dealing with sensitive contact points, and I believe these electronic units prolong spark plug life. I use Pertronix on most of my cars; '33 Ford with 350 V8, '67 Silver Shadow.
    All the best, RF.
  23. lavaux
    lavaux Karting
    Jul 18, 2009
    124
    Cully, Switzerland
    Wilfried Vogel
    Hello Fred,
    Thanks for this valuable info. I will contact Marvin to see, if he can send a kit for me to install. Living in Switzerland I do not take the risk to ship MY distributor to the US.
    All my cars (8 now) are equipped with electronic ignition: I started with Lumenition for the first few, then went to Pertronix. (less expensive, easier to install and no external, additional box)
    Wilfried
  24. mfletch
    Nov 3, 2008
    480
    #249 mfletch, Feb 9, 2011
  25. carnutz
    carnutz Karting
    Aug 11, 2008
    115
    Martin, the correct fan for your 3500GT is a four bladed fan. The six bladed fan was used on the GTI, but the face of yours looks weird. There shouldn't be any holes in it except the one for the mounting bolt which should be a reverse thread.
    Larry
