What type of car lift...? | FerrariChat
Discussion in '348/355' started by jevs, Jan 30, 2012.
  1. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    I was considering finally buying some sort of lift for my garage. I have just about every other tool to build a car, but for some reason I always found a way around needing a lift. Since I am buying a 355 instead of a 360, I have some extra money. Since I need to do a major on the 355 right away, I thought it would be a good excuse to finally invest in a lift of some sort.
    I have not had to drop an engine out the bottom yet. I have only had a couple cars where they recommend this, but I was still able to pull them out the top. Other cars that would have needed to be dropped, never had a need to do it (knock on wood).
    Anyway, I am wondering what type of lift would be best for servicing the 355 (4 post, 2 post, scissor)? Or can I get by with my good old jack stands and jacks?
    One limit I have is ceiling height. I have 10' ceilings, but the garage door opener hangs down too. I do have plans of building a bigger shop at some point though, so I want to move the lift there if I ever do and then the height won't be an issue.
  2. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    Even though I have a high ceiling (12'), I'm seriously considering a scissor jack. In the 355, not much needs to be worked on under the center of the car (just shift linkage and some pipes) and the big thing for me is they are portable. I have seen a few people bring them to the track which, considering I do some racing, is attractive. Not so much for the 355, but a few friends and I race a 944 in endurance stuff so a lift at the track would be a major benefit. The only thing is I'd have to bring my own 220v source as they can be tough to find at a track, but I have a portable generator so that wouldn't be a problem.
    I'm not sure how much your garage door opener hangs down, but I have a similar situation where they didn't put the mechanism close to the ceiling and I'd have to have it modified, but it's not too expensive to have that done.
  3. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I have a Mohawk 2 post asymmetric. My 355 has been on it for probably 3 weeks now as I slowly chug through the Dave Helms gold connector kit and some other maintenance. I love it. I have a 10 foot ceiling, and it is one of the lowest overall height lifts out there.
    There is plenty on a 355 that is accessed underneath that I think would be completely obstructed by a scissor lift. I am not even sure you could change the oil with one. Scissor lifts are portable and inexpensive, and they are great for suspension work or if you spend a lot of time prepping for the track - perfect for the type of thing bobzdar is talking about. But I don't think it would be nearly as convenient for doing a variety of work on a 355 as a 2 post lift. I can't see how you could possibly do a major service with a scissor.
    With a 2 post you will need a minimum strength/thickness slab (I think it is 8 inches). I did it when we were building the house, and the garage floor was poured to spec. If it is not up to it, you might have to re-enforce, and I don't know how difficult that would be.
    As for the garage door, I went with iDrive:
    http://www.wayne-dalton.com/DirectDrive.asp
  4. chas-3
    chas-3 Formula 3
    1,281
    Colorado
    Chuck
  5. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    I think with the lift points on the 355, a scissor lift would be forward of where most things are accessed from underneath. It would for sure restrict access to the center tunnel (shift linkage and hoses etc.) but everything from the firewall back should be accessible, but I guess it would depend on how much you can move the lift pads around. I plan to check one out in the next month or two, but yeah for sure if you can't do a major using one it would probably not be worth it even with the convenience of track use.
    The eagle mid-rise linked above is the one I plan to check out.
  6. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I will admit this one from Mohawk is less restrictive than I thought:
    http://www.mohawklifts.com/wp/consumer/browse-lifts/scissor-lifts/usl-6000/
    But keep in mind that you simply HAVE to have support at the back of the car to lift it safely. I have the rear arms under the engine sub frame all the way back at the rear wheels.
    My buddy's scissor is different and much more restrictive than some others.
  7. cgperry
    cgperry Formula Junior
    Nov 2, 2003
    506
    Chas SC
    Charles Perry
  8. Glen
    Glen Rookie
    Nov 21, 2003
    11
    Carlsbad, CA USA
    Glen Tokuhara
    #8 Glen, Jan 30, 2012
    I don't have a 355 yet but I do have one of these:
    http://www.ezcarlift.com/index.html
    I too have a low ceiling height in my garage and wanted something that was easy to store and also mobile. It gives pretty much full access to the center of the car too. It's a little expensive for what amounts to a large mechanical scissor jack but it's simplicity and ease of use are just what I wanted/needed.
    If portability is important to you, I can tell you that it breaks down and can be loaded into a truck in 15 minutes or less. It fit into the back of my wife's Mercedes wagon easily. Here's a picture of my BMW on it... I find working on a creeper under the car is easier if it's not at full height.
  9. Gearjammer
    Gearjammer Rookie
    Aug 3, 2010
    20
    Sooke, BC
    Rod J.
  10. Dave Monk
    Dave Monk Karting
    Apr 23, 2010
    213
    SW Virginia
    David Monk
    That's the one hands down! I have one and would recommend it to anyone. You can set it up in about 5 minutes and tear it down in the same and roll the components out of the way. I got it from garagesupply for about $1900 shipped a couple of years ago. I did my major with it, no problem.
  11. autowerks9
    autowerks9 Formula 3
    BANNED Rossa Subscribed
    Sep 1, 2009
    1,161
    North Wales, Pa.
    David S.
    #11 autowerks9, Jan 30, 2012
    I have this Snap-on mid rise lift. Works great with a low ceiling. Scored it used off of Craigslist for $600.00. Low cieling of 8'9" and only 4" off the ground.
    David
  12. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    How is that Danmar Maxjax portable? From what I can see it looks like you would have to unbolt it from the floor each time you want to move it? Is it just portable because it has wheels to move it once you unbolt it from the floor?
  13. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    Its portable because you move it out of the way when you are done with it. Yes, its bolted down when you are using it but the rest of the time its off in a corner of the garage not in the way. And I already asked on another post here and yes it will lift the car high enough for a 355 engine out, so mine gets here Wednesday morning :)
    I also have a scissor lift and I doubt you could do a engine out with it too much of the lower half of the scissor in the way.
  14. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
  15. Glen
    Glen Rookie
    Nov 21, 2003
    11
    Carlsbad, CA USA
    Glen Tokuhara
    4-post lifts are great for car storage but are cumbersome for suspension work. And not very portable.
  16. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    Not concerned about portability really. What about if you have the jacks as in the combo I Linked to?
  17. Glen
    Glen Rookie
    Nov 21, 2003
    11
    Carlsbad, CA USA
    Glen Tokuhara
    Those jacks would help but the main ramps will still be in the way. Yes, it's better than no lift at all but IMO, if you need storage space get a 4-post, for service a two-post is better. If space is a concern, there are many compromise options available. For me, I compromised on the mechanical one I posted above and for me it works great and I have no regrets.
  18. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    I have a 4 post lift. It it is 100 times better than no lift even for suspension work.
  19. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    Im not sure if my floor is strong enough for a two post lift? It is at least 4" thick with fibermesh mixed in with the concrete (they said 4000psi). They drilled rebar into the footings hung out a foot or two just to tie it to the footing, but did not put a full rebar matrix in the floor. They claimed the fibermesh mixed in with the concrete is all they ever do with rebar tied into the foundation or footings. I wish I would have made them do a full rebar mesh, but they talked me into doing "the way we always do it". If this is not strong enough, I am not sure what would have to be done to make it strong enough.
    Think this is strong enough?
  20. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    I also did some measuring. I have about 100-3/4" (8' 4-3/4") from floor to bottom of garage door opener and 116" (9' 8") from floor to ceiling.
  21. Dave Monk
    Dave Monk Karting
    Apr 23, 2010
    213
    SW Virginia
    David Monk
    #21 Dave Monk, Jan 31, 2012
    You're good. For the maxjax you install 10 anchors (drill and then install) 5 for each post. These anchors stay in the floor and you just roll the maxjax over them and install the 5 bolts each and you are good to go. Your concrete is plenty strong with a 4000 lb mix and the fiber mesh. The main thing they want you to do is be a few inches away from the exterior walls so you have enough concrete span. Another nice feature of the maxjax is you can get extra anchors and have multiple lift areas, such as another garage.
  22. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I believe 4000psi is more than enough, don't they require 3000psi and 4 inch concrete?
  23. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    the maxjax is so tempting for me altough, I would like something that can lift more weight That way I could work on the 4x4 when needed.
  24. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    #24 jevs, Jan 31, 2012
    The only thing that scares me is that if the fibermesh concrete breaks, there is nothing to hold the cracked piece in....at least rebar could keep the chunk of concrete in place if it cracked.
  25. jevs
    jevs Formula Junior
    Oct 13, 2010
    477
    Missouri
    I agree on the weight thing also, I would like to be able to lift a quad cab diesel truck. I think they are about 6.5k lbs?
