Buy
355 AC air recycle motor Questions
Discussion in 'Technical Q&A' started by 355Aloha, Mar 27, 2004.
  1. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    119
    Honolulu Hawaii
    John N
    AC Recycle Motor
    The AC recycle door motor gear got broken putting back the AC box, so I bought a new unit.
    I put the new unit in and the recycle air door goes to recycle air mode only. I cycle the switch it only stays in recycle mode.
    When I remove the Motor from the cycle door and watch is the motor, it runs in one direction and never stops.
    Does anybody know how this unit works and why this is happening.
    THANKS
  3. zan
    zan Formula Junior
    Nov 15, 2002
    537
    Boston
    Mark M
    The motor needs to be connected to the door to work properly. If not it will run continuosly, when the the door reaches the end of travel it stops the gears in the motor, the ecu senses a load change then cuts power.
    After installing, try disconnecting battery to reinitialize the ecu that might help.
    Mark
  4. malibumk
    malibumk Karting
    May 14, 2002
    167
    Malibu, CA
    Mike Klein
    John:
    I keep telling you that you need the books to work on the car effectively.
  5. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    119
    Honolulu Hawaii
    John N
    Mark Thanks
    I turned of the power at the switch, leff off for 60 seconds, turned switch back on.
    Started AC, let motor stay in locked posistion for 30 seconds. Motor still wanted to run.
  6. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    119
    Honolulu Hawaii
    John N
    I have the shop Manual through Vol 3 H-108.
    Is there other sections beyond that?
    The other problem is No SD-1 exist in the state of Hawaii.
    Does any one have a SD-1 i can rent ?
