355 AC Compressor clutch won't engage | Page 2 | FerrariChat
Discussion in '348/355' started by carwhisperer, May 22, 2016.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    Perhaps there is some solder on the coil wires to the pins (cannot remember) but, if there are, the solders would be over the wire wound a few times over its terminal (the relay pin). This kind of solder will not fail like the solders in PC boards. Anyhow, I think relays are designed to withstand vibrations. A more common failures are due to corroded/burned pins and the respective sockets in the relay connectors.
    Qavion likes this.
