News
355 air bag module
Discussion in '348/355' started by jjtjr, Sep 4, 2017.
  1. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    389
    Vermont
    john truskowski
    Just wondering if anyone knows where to procure an airbag module for a 95 355? It started with an occasional air bag light on, but would go right out. After several attempts to get codes out, no luck. When pin 1 is grounded, the light just gets a little brighter, but no flash codes. Have good power and ground, so I'm betting a bad module. I just cant seem to locate one. Thank you in advance. John
  2. taz355
    taz355 F1 Veteran
    Silver Subscribed Owner
    Feb 18, 2008
    5,270
    Indio Ca/ Alberta
    Grant
    Can you show a pic with identifing pin 1. Was too scared to guess.
    I could not identify fromthe wsm with 100 percent confidence.
  3. Dave rocks
    Dave rocks F1 World Champ
    15,969
    Orchard Park, NY
    Dave Lelonek
    How do you know you need a new module? Has anyone connected an SD to it?
  4. Qavion
    Qavion F1 Rookie
    Feb 20, 2015
    3,669
    Ian Riddell
    The WSM shows pin 1 on the left with the connector clip on top. Was there something which made you doubt that, Grant?
  5. tbakowsky
    tbakowsky F1 World Champ
    Professional Ferrari Technician Consultant
    Sep 18, 2002
    15,035
    The Cold North
    Tom
    Now please do not take my word for this. However, if I remember correctly, it is very possible the airbag ecu used in the 355 is the same as a Ford probe from the 90's. However I may be mistaken. I could be confusing it with something else.
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,270
    Indio Ca/ Alberta
    Grant
    I cant confirm without looking but from memory (not as good as it used to be) I thought if you matched up the clip the spaces between the 3 pins and single pin were opposite.
  7. jjtjr
    Aug 29, 2016
    389
    Vermont
    john truskowski
    It was the one with the pink wire
  8. jjtjr
    Aug 29, 2016
    389
    Vermont
    john truskowski
    I do not have access to an SD, so I'm assuming that the light going on and off (which is not normal, it should go on when it detects a fault and stay on). And not being able to get flash codes, leads me to this conclusion.
  9. plugzit
    plugzit F1 Veteran
    7,223
    Redondo Beach, CA
    Bruce Bogart
    You looking for a "Crash Sensor"? I have one available. Send me a PM if that's what you need.
  10. Julia
    Julia Formula 3
    1,578
    Omaha
    In terms of numbers of cars that have survived, I surmise that Probes are more rare than Ferraris. :) Parts availability might be better, though.
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,270
    Indio Ca/ Alberta
    Grant
    I looked some up on the internet but they dont look exacly the same. Can not confirm or deny this.
  12. Dave rocks
    15,969
    Orchard Park, NY
    Dave Lelonek
    The light going on / off could be a short.
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,270
    Indio Ca/ Alberta
    Grant
    Maybe the bulb is faulty?
    Turn off the master battery cutoff and switch bulbs with another light.
  14. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,716
    F683
    Broken or damaged airbag clockspring making intermittent contact, perhaps? Had any work done on the steering/front suspension recently?
  15. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,270
    Indio Ca/ Alberta
    Grant
    My understanding is the system checks for a bulb, and each airbag. If the clockspring did screw up i think it would throw a permanent light.
    This is why something seems weird. Maybe light is jumperd, seen that.
  16. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,716
    F683
    The system would not know if the clockspring had intermittent contact or the wire leading to the clockspring. Not sure what you mean by the light maybe being jumpered...
  17. jjtjr
    Aug 29, 2016
    389
    Vermont
    john truskowski
    I am thinking that any fault that is detected during an ignition cycle would result in a solid light, and definitely not be intermittent during the same ignition cycle. And because of the intermittent nature of this, I believe the module is defective. There may be other problems, but with a good module I will be able to diagnose it.
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,270
    Indio Ca/ Alberta
    Grant
    Some owners have jumpered the power wire from another source to make it look like the airbag light and system are functioning. No one I know on here thinks thats a good idea.
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,270
    Indio Ca/ Alberta
    Grant
    I know it does because it check all three functions when you first turn on the key. Once the system is on than it may not check but I can not confirm or deny the second statement.
  20. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,716
    F683
    Where does the clockspring get the power that flows through it? It gets it from some wire in some wiring harness. The point is, the system would not know if there is intermittent contact in the wiring leading to the clockspring or the clockspring assembly itself.
  21. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,716
    F683
    How does that make the airbag light go off and on intermittently?
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,270
    Indio Ca/ Alberta
    Grant
    It wont it will stay on once sensing a faul which was why I said it could be jumpered or a faulty bulb,
  23. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,716
    F683
    If it's "jumpered," to hide a fault, why does the light come on (original poster says the light comes on)? If the bulb is "faulty," why does the light come on? What is your definition of a "faulty" bulb?
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,270
    Indio Ca/ Alberta
    Grant
    He also said it gets brighter when he tries to reset using factory pins.
    Likely getting intermittent power from another circuit.
  25. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,716
    F683
    Wish I had thought of that.
