355 Berlinetta cracks | Page 2 | FerrariChat
Discussion in '348/355' started by PAR8HD, Jan 4, 2008.
  1. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    #26 PAP 348, Jan 5, 2008
    I dont know Chris. :):)
    My car had a major done every 3 years from new. (I have complete service history from new) Car had last major in September 2004. I bought car August 2005 with no cracks on buttress. Over a year of my ownership, driving the car hard a lot, cracks appear LH buttress. So nearly 2.5 years after the major, the cracks appear. That tells me the engine out major has NOTHING to do with cracking the paint on the rear buttress. These cars flex, which is what causes this. The guy from who I bought the car from even told me they are suspectable to cracking from hard use and when it does happen, it needs to be spot welded to beef the area up to stop it happening again. This guy was the second owner of the car since the late 90's , was 55yrs old and drove the car like Miss Daisy. (He actually owned 4 348's, among other Ferraris) :):)
    Another reason why I know these cars flex is........the same side the cracks have appeared, my engine cover has been flexing/twisting and hitting the body chipping the paint off there. I have a feeling that this is only happening on that side, is because the little street track I normally power hard through has mainly hard RH turns. The car always flexes that way, causing the paint to crack and engine cover to twist and chip my paint.
    I went outside and took some more pics. I am not too concerned, as I will get it fixed one day soon. My friend has been too busy to do it for me. :):)
  2. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I just went to the garage and checked my rear bonnet and there are no marks of any kind in the areas your car has paint chips.
    The Ferrari dealer who has serviced my car is adamant about the cause of the paint failure at that panel and my paint did indeed crack after the first service in the same areas that your paint has failed.
    My car has been most aggresively tracked as well and the paint cracking has not returned.
    Now I do however have the 355 coupe which is the stiffest chassis of the bunch......the targa models I have driven could be made to twist going into a steep incline driveway (could hear the hatch shifting) which could certainly account for more paint cracks in that model. As well I recall reading that the 355 has a stiffer chassis than the 348 and this may contribute to the particular paint failure in your car.
    In any case, I agree that the cure is to re tig (which reinforces) the weld, spot paint and its fixed for good.
  3. PAP 348
    Dec 10, 2005
    100,249
    Pap
  4. Derek Trotter
    Derek Trotter Formula 3
    1,790
    Cambridge, UK
    When I originally bought my 355B at a year old, there were no signs of C pillar cracking. A year later and after no engine-out work, cracking became visible. At 3 years old, I had it repaired and understand from the current owner that it needs to be re-done every 2-3 years :-(
  5. millemiglia01
    millemiglia01 Formula Junior
    Oct 9, 2004
    250
    the north shore li
    amante
    Do you remember what the fix ran you with paint and all?
  6. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    The cost was added to the major service which cost around $7,400. ......so the repair was less than a thousand dollars.
  7. PAR8HD
    PAR8HD Karting
    Mar 31, 2007
    75
    Shoreview, MN
    Harold J. Hitchcock
    This is getting more and more interesting. I can certainly see flex being the main cause of the problem. But short of putting in something to add some strength I don't see how this would not happen again. A re-tig would only be a repair, if the area is weak then sooner or later it will crack again. Sounds like an issue you exchange for the enjoyment of hearing those 8 cylinders behind you.
  8. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    RE: 348's, I kind of still trying to determine from this thread if TBs have as much of a cracking problem as TSs. Anybody seen enough of this problem on both to say for sure? Thanks.
  9. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,621
    Gates Mills, Ohio
    Jon
    Interesting question. TSs might have a sort of 'flex expansion joint' in the roof seams, whereas the TBs might be transmitting all that force to the C-pillars. Or it might not matter.
    I'll pay more attention the TS/TB distinction from now on.
  10. UConn Husky
    UConn Husky F1 Rookie
    4,425
    CT
    Jay
    This problem is not all it's cracked up to be :D Sorry, couldn't resist.
    I have a paint crack on my passenger side c-pillar (GTB). At first it bothered me, now I don't even notice it. I may fix it in a year or two...
  11. PAP 348
    Dec 10, 2005
    100,249
    Pap
    100% correct mate! :):)
    TS are not as prone to it, because the open roof 'absorbs' the flex so to speak. :):)
    TB not as lucky. Ferraris flex and the TB/GTB crack the paint around the rear buttress. :):)
    +1. :):)
    Mine has been that way for over a year now. Couldnt be bothered with it just yet. :):)
  12. 355
    355 F1 Rookie
    3,643
    Toronto
    Frank
    #37 355, Jan 7, 2008
  13. PAR8HD
    PAR8HD Karting
    Mar 31, 2007
    75
    Shoreview, MN
    Harold J. Hitchcock
    Well, that certainly wraps up all further discussion in the matter!
  14. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1000..... if it happens, fix it.......sounds like a normal maintenance thing IMO.... :rolleyes:
    .........now those pics are a case where crack 'does not' kill...... :D
  15. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    764
    Vermont
    john truskowski
    So this problem occurs on the spiders too?
  16. WATSON
    24,064
    WI
    Wow. 10 years old almost to the day. Cool.
    The spiders do not have that buttress, so, no.
    Dave rocks likes this.
  17. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    o_O
    Obviously he's referring to butt cracks, not buttress cracks.
  18. WATSON
    24,064
    WI
    Oh. I missed that...
    hahahahahahahaha
  19. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    It’s a choice ;)
    I passed on a 355B because of the buttress cracks, and a couple other reasons.
    So buy a spider and you can toss $1000s at the convertible top, to get it working properly .......like I did.
    Also spiders are worth less than a B car, so in the long run ........
    Cosmetic stuff is just as speedy as the mechanical stuff.
    f355spider likes this.
  20. f355spider
    f355spider F1 World Champ
    18,059
    I followed the same thought process as you, and ended up with a spider. Its definitely a crap shoot. Other than topping up the fluid and replacing the elastic straps, I was lucky to never have issues with the top during 10 years of ownership with my F355 Spider. I had plenty of the usual stuff to throw money at though...crumbling catalysts, failed exhaust manifolds, sticky interiors buttons and switches, failed throw out bearing that leaked out all the clutch hydraulic fluid, leaking shocks, failed catalyst ecus, failed shock actuators...the list goes on...but all that stuff comes with 355 ownership.
    I think in retrospect, I would have preferred the F355B and deal with the buttress cracks, get it fixed if it happened, and move on. (spot welding from underneath where the fender meets the C pillar, then repaint the car). I have to admit that at over half the F355Bs I drove or inspected had the cracks to some degree...that kinda scared me off.
  21. Enzojr
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    Agree, thinking back the B car I looked at in the Seattle area was a 95, and yellow in color.
    It had cracks all the way down on both sides.
    It also had the carbon fiber seats (so now I am crying in my soup)........Waaaaaaaa
    I am convinced driving it a lot, and racking up big miles (coming up on 43,000) keeps stuff from wearing out (?) and breaking ;)
    And being single I can lie to everybody about how much I spend on it.
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I have a 99 no cracks so maybe only the early cars were bad. I do know early cars needed reinforcing at shock towers
  23. f355spider
    18,059
    It is entirely possible Ferrari figured out the problem and added additional welds to the fenders where they meet the C-pillar and body. Only a back to back comparison would tell for sure.
  24. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The cracks are very thin, hairline. Often very hard to see unless you go looking for them. The bigger issue is water penetration that will cause problems with the paint.
  25. jjtjr
    Aug 29, 2016
    764
    Vermont
    john truskowski
