355 Brake Disk upgrade | FerrariChat
Discussion in 'United Kingdom' started by basher, Aug 11, 2004.
  1. basher
    basher Karting
    Jan 19, 2004
    204
    Fraser B
    Anyone done this ? Was hoping to get drilled disks and some fast road pads to improve braking a little.....did look at Brembo brake upgrade (F50 brakes) but at £4k i think not at the moment...disks only really needed as i dont track the car that often.....
    Any ideas .....esp on alternatives as no doubt Ferrari will want about £4k per corner or some silly astonomical number......
    Thankyou
  2. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Doesn't Verdi offer a Fiorano brake upgrade?
  3. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    are you sure you aint a shareholder in verdis he he he
  4. Boxer 512
    Boxer 512 Formula Junior
    468
    London, UK
    Seb King
    You could go for the 355 Challenge barkes ?
    Or I know AP do a racing upgrade for the 355 too, not sure of cost though ?
    Seb
  5. 355fiorano
    355fiorano Formula Junior
    Oct 21, 2003
    781
    London
    Philip
    To be honest I don't think the fiorano breaks are that much better than standard. They are just drilled discs. i still find them a little weak vs the over overall car performance expectation. The one thing I cn say however is that they have never faded on me after some repeated hard use at Nordschleife and especailly Spa. I have heard that std 355 breaks fade during track days. If that is the case then that is the only advantage and if you are going to splash some cash you might as well go for something with more impact i.e. bigger discs.
  6. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,837
    East Yorkshire
    Justin Kenyon
    Tarox are from Italy and are excellent. They do ceramic discs as well.
  7. MarkCollins
    MarkCollins F1 Rookie
    Jul 2, 2002
    3,202
    South England
    Mark Collins
    I always used std discs but upgraded pads, I used Pagid fast road (cheap from QV!) which were good but the extra friction caused extra heat and warped discs, had them skimmed and they were OK. I subsequently used Raichem pads which was kind of halfway between std and the Pagids.
    Personally I wouldn't go for drilled discs, they more cosmetic that functional and frequently crack from the drill holes, I'd be more inclined to run with grooved discs which help to keep the pad face clear of glazing.
    I've not used Tarox discs but it might be worth talking ot Mick at QV London, he wasn't overly complimentary about them having fitted many to various Ferraris
    btw I have a set of nearly new std discs for sale if anybodys interested
  8. CharlieUK
    CharlieUK Karting
    Jun 30, 2004
    99
    London
    Charlie
    I am also looking to upgrade my 355 brakes (discs/ pads), as I find they fad quickly. I understand Basher has just fitted an upgrade. Has anyone else done so. If so, what have you had done? Recommend it? What cost? Who did it?
    Thanks.
  9. velocityengineer
    velocityengineer Formula Junior
    Nov 8, 2003
    492
    Globally
    Eric Dahl
    Hi guys,
    Girodisc has just become a sponsor for Ferrarichat, and I wanted to introduce the product to those who may not have seen it.
    Girodisc is a engineering company that produces racing brake systems and components. It was formed by myself and Martin Meade. Among other things I was an engineer for Brembo and Martin was an engineer for Porsche for years.
    We have OE replacement sized two-piece discs for most modern Ferrari models. the discs are lighter and cool better than the OE parts. They also cost less is most cases!
    Have a look at the website for lots more information. www.************.
    Below are some pictures of the two-piece F355 front and F360 replacement discs.
    The Girodisc F355 front is 5.6 kg, vs. 8.6 kg for the OE unit.
    The Girodisc F360 weighs 6 kg, and the OE unit is 8.1 kg.
    Both cars lose significant amounts of rotating and unsprung mass and gain ability to cool faster and resist fade longer.
    We tested the 360 rotor on the track in competitive events several times and found no problems, and the performance of the rotors to be exceptional.
    We will also have 360 Challenge rotors available at months end after we do a validation test at a track event on the 25th.
    I look forward to answering questions and working with the Ferrari community to provide braking solutions for Ferraris as well as many other vehicles.
    -Eric
  10. velocityengineer
    Nov 8, 2003
    492
    Globally
    Eric Dahl
    Also to clarify,
    The 355 rear will be offered currently as a slotted one piece OE rotor.
    We have been researching and prototyping two-piece rear rotors for the 355, but we are not satisfied with the product, and we will not sell a comprimised product. the dimensions of the 355 rear rotor leaves little space between the hat section and the caliper, and the hat walls would currently be thinned unacceptably to fit the mounting hardware.
    If we can find a two-piece solution we will post the news here.
    Stay tuned.
    -Eric
