News
355 cam follower/bucket wear
Discussion in '348/355' started by Carmellini, Aug 14, 2019.
  1. Carmellini
    Carmellini Karting
    153
    Leo Johns
    should I assume that the hydraulic lifter system on 355 engines mean there is never a valve lash adjustment necessary? do the cam followers or buckets wear and eventually need replacement?
  2. yelcab
    yelcab F1 Veteran
    Nov 29, 2001
    9,517
    San Carlos, CA
    Mitchell Le
    Correct. You never adjust the valve lash. However, you may need to rebuild/replace the valve lifter bucket if it/they ever fail leading to ticking noises.
  3. Carmellini
    Carmellini Karting
    153
    Leo Johns
    so its a binary issue? how common is it for a bucket to fail? age or mileage issue?
  4. GerryD
    GerryD Formula 3
    May 5, 2010
    2,351
    North of TO
    Guido
    On a 355 we serviced this past winter....5 needed replacement.
  5. Carmellini
    Carmellini Karting
    153
    Leo Johns
    so they are replacement items......how do you determine replacement?
  6. yelcab
    yelcab F1 Veteran
    Nov 29, 2001
    9,517
    San Carlos, CA
    Mitchell Le
    I have actually not met one that needed replacement yet, but I know they are out there. You remove the cam shafts, push on the lifters, if they give at all you need to replace them or rebuild them.
