355 cam phase sensor error symptoms | Page 2 | FerrariChat
Discussion in '348/355' started by taz355, Oct 5, 2021.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Video is too large from ipad
    Bot on 5 volts it seems to match
    Ground was wrongly attached to back of plug bracket for sensor.
    reinstalled in correct place. I missed it when I fixed the head last winter
    would jumping the ground to negative in engine bay help
    Likely won’t hurt so I will try it
    then off to check wiring to ecu
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Only think different would also be the cam trigger as this cam is off a 2.7 engine
    Not sure that should make a difference but they are different parts and do look different
    As I noticed when installing
    Mostly look the same but not necessarily the same material
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Jumping directly to ground did not clean up the signal
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Continuity is good between sensor and the ground which was reinstalled in its correct location
    I have the new sensor installed
    Will install good working old one and see if wave is the same
  5. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    Wow that’s a live scope been alone time since I work with one of those can see the setting but correct me if I’m wrong. I see
    —— No delay —-
    ——- DC coupling—-
    ——-volt scale 5v —-
    ——-pos slope —-
    ——-trigger mode auto ——
    ——- time base of 5ms (but was only on the pic 1&2 looks like it changed on others ?)——-
    what I can’t see is
    —— trigger level (aka voltage that starts the trace) ——
    But what I do see is the the top trace is “ugly” to me is it possible to take a high/low reading of the voltage will it’s “on” to see how far the wave is floating this probably looks like that do to the cleaning
    Just like the ground and power supply the signal return has to be smooth
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    If you are talking about #17,
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I don’t know exactly how to use the scope as have had it for a long long time
    Yes correct on settings but don’t really know some of them
    Don’t know the trigger voltage but if adjust down to much it cuts out with no visual.
    the lead is set to 1 instead of 10x but it does not clean up the signal if on 10x
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I think the ugliness of the top trace is due to the gouges in the trigger.
    Maybe I should polish it some more
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    not sure what your asking John
    the parts look to be the same shape but maybe different materials
    The new one looks to be solid brass the old one is not
    At least from memory I think
    yes I am calling that the trigger that the sensors sees
  11. johnk...
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    Just pointing out that they have different part numbers based on engine number. Would suggest there are differences. On the other hand, you said that the car ran fine for 3 months so what you is probably OK.
  12. Qavion
    Qavion F1 World Champ
    14,674
    Ian Riddell
    Why is the voltage so high? You have 5 volts/division. The wave seem to be close to 15 volts in post #33.
  13. m.stojanovic
    m.stojanovic F1 Rookie
    3,331
    Serbia - Niš
    Miroljub Stojanovic
    The "on" and the "off" lines of the sensor output square wave signal are not directly produced by the trigger (the reluctor attached to the camshaft) acting on the Hall element so irregularities in the trigger will not cause the ripples. The trigger, as it passes the sensor, will cause analogue change in the sensor's internal permanent magnetic field, this will cause analogue change (a sine wave) in the Hall Element output voltage which will, when it reaches a certain threshold, cause the Schmitt Trigger to switch "on". The sine wave may have ripples in it but they will not affect the square wave (on and off) output of the sensor (see pic below).
    The ripples in the square wave shown on the scope are probably due to not very clean DC voltage in the car's electric environment and the high sensitivity of scopes that picks up even tiniest disturbances in it. A bench test using a battery will probably show a clean square wave.
    A typical example showing how the Hall Sensor operates:
    Otherwise, the trigger has to be made of ferromagnetic material in order to cause change to the Hall sensor's magnetic field so it cannot be made of brass.
    taz355 and Qavion like this.
  14. Qavion
    14,674
    Ian Riddell
    I'm having flashbacks to your engine meltdown. Wasn't there some debate on which codes referred to which sensors? Can you recall the code you're getting now?
    We seem to be getting off-track with noisy waveforms. If they are at the right amplitude and frequency, I'm sure the ECU can handle them.
  15. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I am thinking it has to do with one of the buttons
    I did not calibrate it and if I adjust the button I can change. The screen
  16. johnk...
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    Let me summarize: 1) You had a CEL for cam sensor. 2) Replaced sensor and once warmed up the car ran fine for 3 months. 4) Now it has problems. 5) As of today, cam sensor appears to be giving the correct signal and there is no CEL.
    Conclusion: The cam sensor is not the problem. Look elsewhere.
    INRange and taz355 like this.
  17. 26street
    Jan 30, 2021
    473
    Mark k
    The first said you had a cel with cam phaser codes and you replace it after the warmed up it ran fine but now runs rough all the time
    I agree that it’s time to look pass the sensor and phaser for now go back to the basics if there’s no cel on check fuel delivery and spark and how do the plugs look
    If you have a cel on what is the code or codes
  18. fatbillybob
    Aug 10, 2002
    29,468
    socal
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    i am thinking it’s not related as well after discussing with you guys.
    I actually used the old sensor all summer and car was mostly working.
    I will be checking plugs and coil. Maybe under high load something is not working
    new sensor was not installed until I saw the wave form and was hoping it would clean it up.
    could be a slow deteriorating of plugs maybe or coil.
    Will check
    Plugs on bank 2 look perfect. Will be checking bank 1
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    no I did not replace it, but after the engine warmed up the car worked all summer
    will get back to everyone after lunch
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    New plugs
    New coil pack
    old plugs looked good
    as John said think it’s unrelated
    cleared the cam sensor code went for a drive and no code yet.
    I remember once the hall sensor on the f1 transmission broke because I hit it on a speed bump and I am thinking it gave a similar error. When accelerating
    It would be jerky.
    going to check it and the wiring later this week.
    Thanks for all the help so far
    Need to find the post I had about 5 years ago
    although I did not hit it maybe the wiring is faulty from the engine out service.
