355 cat replacing | Page 5 | FerrariChat
355 cat replacing
Discussion in '348/355' started by mpodgor, Aug 3, 2011.
  1. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Yes, we found that loosening the rear diffuser makes it easier. Hope you didn't get beat up too much by your car! You saved a lot of money doing it on your own though great job =)
  2. pchop
    pchop F1 Rookie
    2,675
    Usually NY often elsewhere.
    #102 pchop, Nov 19, 2011
    Here's a video of how my car sounded with Stock Cats and Prospeed Cats - I already have Tubi on the car, hence the difference is subtle. However, my car definitely rev's much happier. There's also a nice deep bass sound which you can't really hear from this video.
    http://youtu.be/c0VVVQxaOLM
    Btw, if you see an ad on the video and is interesting or relevant, please click on it. :)
    Btw, I, too have a cracked passenger side CV boot:
  3. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    This is off topic but I was wondering what the demand was for a high quality custom header for the 355? I know they go bad often and my friends 355 header basically collapsed on itself! I was thinking of building a small run and testing different lengths and sizes and tri y vs 4-1 on the dyno. I know fabspeed makes a nice 4-1 set but not sure if its worth building. What are your thoughts guys?
  4. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,634
    VA
    Brendan
    I think the biggest hole in the market is for a high quality, affordable 4-2-1 design header. It must also include heat shielding like the factoy and Tubi units. There would be a significant market for this design at a reasonable price.
  5. plugzit
    plugzit F1 Veteran
    7,812
    Redondo Beach, CA
    Bruce Bogart
    Quite a few competitors out there.
  6. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Thank you for your feedback. I also believe the 4-2-1 design or Tri Y as some would call it would be ideal for the 355. I believe Ferrari only built 4-2-1 headers for their V8's until the 458. The low to mid range would gains would be excellent on a properly designed 4-2-1 header for a lightly modded 355.
  7. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Do you know who else makes them for the 355 besides fabspeed? Anything high quality will cost money. I prefer to use 321 stainless steel but that depends on cost and if it will come out to be affordable. Thanks!
  8. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    Capristo and Tubi. They are both significantly more expensive than the Fabspeed. If you can beat the fabspeed price with good quality (and good dyno results meaning equal or better than stock), I think you will get plenty of business.
    Define affordable?
  9. pchop
    pchop F1 Rookie
    2,675
    If your set of cats is any indication of quality, when my header goes, you have a buyer :)
    P.S. - I hope I didn't just jinx'ed myself.
  10. ClydeM
    ClydeM F1 World Champ
    12,281
    Wayne, NJ
    Clyde E. McMurdy
    Same here.
  11. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Thanks for your input. I would definitely look to produce a quality product and more power if I plan to design and build it. I wouldn't have it any other way as that will be the main focus. As for being affordable I believe the fabspeed price point is about right considering design time, material costs and labor. But I won't know till I start building it.
  12. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    #112 f1karting, Nov 22, 2011
  13. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Thanks guys... I hope you didn't jinx yourself either! Still don't understand why Ferrari went cheap (as far as design/longevity) on the materials on the factory head! =( Oh well time to go the drawing board and improve on it. =) Happy Thanksgiving to all of you! Cheers!
  14. race850i
    race850i Karting
    Jan 6, 2010
    132
    Germany
    Themis
  15. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    I've seen those before. They are made in China and are not real metallic catalytic converter cores like the hyper-flow's, fabspeed's, or prospeed high flow cats. They are test pipes that have a resonator on them. If you read carefully it says test pipe high flow. If you're looking for test pipes than that would work. Just heads up! =)
  16. race850i
    race850i Karting
    Jan 6, 2010
    132
    Germany
    Themis
    Thanks for the answer.
    This is what i thought,the Seller does not clarifies if the Item has a Cat inside or if its empty.
    I just wanted to clear this because if they were Cats they are very cheap!
  17. pchop
    pchop F1 Rookie
    2,675
    Not that there's anything wrong with things that's Made in China...just things that are cheaply made regardless its of country of origin...right?
  18. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    You are correct! I love apple products and they are built well and last forever and they're made in China =) Just be careful though cause I've seen some of the lower grade stainless steel from China and other places and their standards of materials are not up to par with the US or Europe.
  19. race850i
    race850i Karting
    Jan 6, 2010
    132
    Germany
    Themis
    What conserns me is not only the quality of the produkt but the fitting as well.
    The rear side is a the flange too and this could be a problem if not fit 100%.
  20. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Hi Guys! I was wondering If anyone had a driver side factory header good or bad I could borrow for test fitment? I would only need it for 1 week and I will pay for shipping to me and back to you and in original condition. Also let me know if you have a 2.7 or 5.2 header. I already have the passenger side but missing the driver side header. PM me if you guys have one. Thanks! I can give you a great discount on our first batch built. =)
  21. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Thanks for getting back to me guys I appreciate it. The project is underway. =)
  22. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    How are those headers going?
  23. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Hi Michael! Happy holidays to everyone! It's going along really well. I am still looking for a local 355 for doing before and after dyno testing but we have already built the jig and designed our header and are planning to complete the project and have a completed header by the 2nd or 3rd week of January. The header was designed using a proven engine/header design software. We are also looking at incorporating a heat shield with the header but first things first we want to develop a properly designed 4-2-1/tri-y header for the 355 and go from there! I'm really excited about this project. =)
  24. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    That's great news. I was hoping someone would come up with a 4-2-1 aftermarket header.
  25. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    I'm glad there is great interest in this. I believe there is some positive design advantages with the 4-2-1 header... more horsepower and torque in the lower to mid range power band is important for a street/road course car. In some instances if a 4-2-1 header is designed and built correctly it can also match a 4-1 headers top end in power. It's more expensive to build because it requires more merge collectors and varying pipe sizes but I think it will all be worth it. =) Happy New Years everyone!
