355 cat replacing | Page 6 | FerrariChat
355 cat replacing
Discussion in '348/355' started by mpodgor, Aug 3, 2011.
  1. MRF40@yahoo.com
    [email protected] Formula Junior
    Jan 1, 2006
    563
    Planet Urf.
    like whut? Ralph??
    I have a set of 5.2's at my mechanics in Fullerton. I actually hope you produce the 2.7 set up because that's what I need for my '95.
  2. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Thanks for offering the 5.2's Ralph. I have a set of 5.2's but still need a set of 2.7's you got a PM!
  3. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Hey mpodgor (michael) Hows the car coming along running well? Having aftermarket cats should help reduce the temps in the engine bay and help with the longevity of the headers. I was blown away by how much damage the OEM headers go through under the factory heatshield! Have you done anything else to the car since the last mod?
  4. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    The cats seem to working OK. I just had some OBD codes trigger the CEL on. It relates to the #1 bank O2 sensors. Slow response. I reset CEL and am monitoring. I keep the OBD tester plugged in and it sits on the pass seat so I can do real time. But overall I'm happy. The real test will be the smog test next year.I'm hanging on to the OEM cats just in case.
  5. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Glad it's working okay. :) I've seen that code from the 02 sensor and it goes away after a reset... Not sure if it's the sensor itself. I had a similar problem happened to me when I replaced headers on my car and after a reset it hasn't given me a problem.
  6. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    Keep up the great work. I plan on replacing the garbage OEM headers this year. I need piece of mind. So get them mothers going.
  7. ndnbill
    ndnbill Karting
    Mar 3, 2009
    70
    Las Vegas
    William
    FYI--I just had a major on my 355-installed fabspeed headers and sport cats with secondary by-pass y pipe and capristo exhaust.
    It passed smog on the first on the starting sequence. I was pleasantly surprised.
  8. White Knight
    White Knight Formula 3
    Aug 22, 2011
    1,531
    Ogden, UT
    Todd S.
    That's a very nice setup you have.
  9. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,754
    I have some data (from a CFD engine simulator) that I could share with you.
    After looking at the factory, Tubi, FabSpeed, and the custon 348 header Ernie did a few months ago; the engine simulator said A) the exhaust tubes are too narrow, B) too short, C) exit the heads at the wrong angle (90 degrees rather than 73 degrees), and D) need proper merge collectors.
    The simulator indicates that the header tube sizes would be more optimal with more conventional American V8 tube sizes (1.75" OD rather than the 1.58" OD factory) and longer (by about 3 inches) finally the merge collectors need expansion cones to properly extract all the exhaust gass energy between the primary merge collectors and the secondary merge collector. The expansion chamber at the end of the header was pretty close to optimal.
  10. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Thanks Michael! I can't talk too much about it right now as I am not a sponsor but I will be one soon =)
    Thanks for your input Mitch! I ran also some numbers through an advance header design software and was surprised with what it recommends as well. I believe there's power to be gained over the factory headers. The merge collectors look terrible on the OEM headers! I am a firm believer in a properly built 4-2-1 header design. A well designed 4-2-1 header will produce better low and mid range power which is what most street cars see. On a 4-2-1 header design the primary and secondary lengths play an critical role in power production and where it peaks.... I personally like the long tube designed custom 348 ernie header but too bad we couldn't see a before and after dyno! =)
  11. Mitch Alsup
    Nov 4, 2003
    9,754
    This is not quite the case. Given 3 different header designs, a proper 4-1, a proper 4-medium-2-medium-1, and a proper 4-long-2-short-1 headers; all properly tuned for the same top end power band:
    The difference in the TQ curve is all down in the 2700-4300 range. The band from 4300 through 9000 (simulated) is indistinguishable (that is less than 1 lb-ft difference at any point.)
    The trick is that all three designs were properly optimized for top end power. Properly optimized means I tried at least 100 designs of each kind before declaring it the best I could do. One can optimize the 4-medium-2-medium-1 headers for more midrange at the expense of top end--but this does not HAVE to be the case.
  12. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,994
    Northeast U.S.
    Jim
    Hi Mike, I am looking to purchase some high flow cats in the near future and was wondering if you are happy with the prospeed cats on your car? Any issues? I am considering this brand and hyper-flow.
    Jimmy
  13. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    [Jimmy,
    So far so good. I've got at least 1K on them. Good sound. Yea I would approve. QUOTE=jimmym;141238379]Hi Mike, I am looking to purchase some high flow cats in the near future and was wondering if you are happy with the prospeed cats on your car? Any issues? I am considering this brand and hyper-flow.
    Jimmy[/QUOTE]
  14. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,994
    Northeast U.S.
    Jim
    Thanks Mike for the response.
    Jimmy
  15. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    [/QUOTE]
    Excellent =)
  16. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,994
    Northeast U.S.
    Jim
    Received my high flow cats on Friday from Prospeed. They appear to be made well. Brian was very good to deal with. Between the cats and Bradan's y pipe, all I need are some good headers and my exhaust will be done. Thanks Brian.
    Jimmy
  17. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    Thanks Jimmy! :) enjoy!
  18. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Picked mine up from Brian and they look top notch, installing this weekend
  19. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    How did it go? Hope it went well!
  20. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Sure did passed CA emissions with them and no CEL's, I added new 02 sensors also to give iut a good start :)
  21. Prospeed
    Prospeed Rookie
    Mar 2, 2010
    40
    Newport Beach
    Brian
    That's awesome! Congrats. =)
  22. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    #147 mpodgor, Apr 26, 2013
    Just a warning. Both Cats have failed. Maybe 3k on them. JUNK! Do not buy these things.
    Glad I save my OEM Cats!
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Just curious how did they fail,I have hyper flow from ricambi and there 5 years and 8000 miles. My only problem was check engine lights occasionally but seem to have that sorted now.
  24. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,994
    Northeast U.S.
    Jim
    Mike, did you contact Brian about this? These have a lifetime warranty on them, for what it's worth. I haven't installed mine yet, but will be putting them on with my new headers when I do my major sometime this year. Hope this is just a rare defect and will not effect all cats produced.
  25. schefdeh5
    schefdeh5 Formula 3
    Nov 2, 2008
    1,529
    U.S.A.
    Keep us up to date on this
