355 cats | Page 2 | FerrariChat
355 cats
Discussion in 'Technical Q&A' started by bst1, Dec 24, 2006.
  1. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Wow!! It looks killer!:D :D
    Well the dimensions would include mouting points in relation to inlet/exhaust locations. Too difficult over email and such.
    How much lighter was the capristo vs the stock?
  2. bst1
    bst1 Formula 3
    1,055
    MARYLAND
    BARRY T
    I didn't weigh them, but just by lifting, I'd say about 15 pounds less than stock. The cats are about half the weight of stock, another 15 pounds savings for the 2. Guessing 30 pounds total savings more or less.
  3. bst1
    bst1 Formula 3
    1,055
    MARYLAND
    BARRY T
    You can measure your stock 355 mufflers pretty easily by removing the airboxes and main heat shield.......should be about 13 nuts, 2 simple clamps to undo.....about a 5 minute job. As you can see by the photos, you can see the whole muffler that way.
  4. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    True! But that is why I wanted to buy one. So that my car will not "undriveable" for any amount of time ;). I will keep looking on ebay. Congrats on your screaming system!! :)
  5. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    Makes sense since the 355 isn't down all that much on power from a 360. You may have picked up a few HPs with cats. I know my car is completely different with test pipe as opposed to cat in place. What a difference in size by the way.... you'll soon have a new respect for your car now that you've modded it! Congrats it looks sweet!
  6. Limeade
    Limeade Karting
    Mar 20, 2006
    127
    Quick question, why in the world would CATs be going bad on a car with only 7800 miles on it?
  7. f355spider
    f355spider F1 World Champ
    18,055
    They are Italian (made by Ansa) and the ceramic cores are not secured very well within the stainless steel casing. The core comes loose, rattles around inside until it starts to crumble apart. Both of mine were previously replaced at round 24k miles, and I recently had the right side go at 41k miles. Wasn't too bad; core was loose, but not crumbled yet...but it was bad enough to throw a CE light. Also the pre-cat O2 sensor had a bad heater. I was able to find two excellent, used (14k miles) 355 cats from another F-chatter for a great price and got my car fixed fast and inexpensively. I will eventually have my bad right side one, fixed at http://www.millercat.com/index.html Brian Crall (Rifledriver) has told me these guys can do a great job cutting open an Ansa cat and installing a new core, and it will work fine. I believe they only charge around $400 or so.
  8. bst1
    bst1 Formula 3
    1,055
    MARYLAND
    BARRY T
    Hopefully I won't be asking the similar question:
    "Why do the manifolds go bad with only 8500 miles?"!
    By improving backpressure with new Hyperflows and Capristo's I hope I have lowered the risk of the poorly made inferior material manifolds from blowing.
    Was noting the Tubi manifolds are expensive and hard to come by, and the NAP have no heat shields and may toast the alternator and other wiring!
    Maybe Kevin needs to work on some shielding for his headers! Opinions are still mixed on ceramic coating being enough of a heat shield (see Rifledriver comments).
  9. f355spider
    18,055
    I seriously doubt it will help much. The real problem is too thin, and incorrect material for the exhaust manifolds. Don't forget that one other option is QV London. They have an exchange program and will send you a rebuilt set for around 900 pounds, plus deposit. They replace all the tubes with a higher grade ss and one gauge thicker. They retain a stock look as they reinstall the original heatsheilds. They also install the CO test ports too, which many aftermarket exhaust manifolds omit.
  10. bst1
    bst1 Formula 3
    1,055
    MARYLAND
    BARRY T
    I understand NAPerformance does something similar, is in the USA and is in the same ballpark price-wise. Kevin?
  11. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,685
    LA & OKC
    Kevin
    Don't do header repairs anymore, I was using the guy for repairs that did the fabrication and we can't keep up with the regular headers so it didn't make sense to compete with QV (especially since they do an amazing job) while hurting the market I was originally trying to focus on.
    Regards,
    Kevin
  12. MufflerMan
    MufflerMan Formula 3
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
  13. dlstipp
    dlstipp Rookie
    Sep 20, 2007
    15
    Wichita, KS
    Darrell L Stipp
    I found my right cat totally empty and the left with a large chunk that just is breaking apart. I had heard the sound of a heat shield rattle and decided to upgrade to hyperflows and the X-Ost just to take care of the potential. When I disassembled everything to remove the muffler and cats I found after removing the empty right hand cat that the inner axle boot has failed. These inner boots are very close to the cats. Their close proximaty and the high heat of a failing cat contributes to the boot failure problem.
