355 Challenge Grill from Exotic Auto Recycling? | Page 3 | FerrariChat
Discussion in '348/355' started by Dave rocks, Jul 23, 2014.
  1. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Yes I do all international next day also, only way to go
    Good deal
  2. Sally
    Sally Karting
    Jun 28, 2014
    76
    I just ordered mine today. Great guys there.
  3. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    Dave,
    Are you going to (or did you already) install yourself?
    If so, I'm really hoping for one of your superbly detailed DIY write ups.
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #54 Dave rocks, Aug 10, 2014
    Neil, yes, I did install yesterday and will create and post an installation guide in the next day or two
    Thanks for the compliment.
  5. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    Looks nice Dave.:)
  6. Badabing!
    Mar 30, 2014
    731
    NYC
    Looks sharp!
    Enjoy.
  7. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    Dave, did you take any engine bay temps before the grill installation?
    Just curious to see how much of difference it makes.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Jim, I did not take any readings prior. However, I did just get home from a ride and if it makes a difference, I cannot feel it. Seems just as hot as before.
  9. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I question the reality of any heat dissipation through a perforated panel, that at best is 75% steel/25% air, oriented horizontally behind the heat source with no air flow directed at it from in front of the engine or behind it.
    Now if you're driving hard in reverse maybe it might do something.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Bob, the fans do point in that direction. Even though I can not feel a difference when stopped, it must work when in motion. This part was for challenge cars so I think they had good reason to design it. Perhaps challenge cars have internal fans that blow out right behind the grill?, maybe someone with a challenge will chime in.
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Mount a couple thermocouples in the engine bay and see
    Seat of the pants analysis, muffler heat shield and the air boxes are in the way of any horizontal air flow out the rear of the engine bay, the "grill" is mostly solid steel with as I said maybe 25% perforation. Heat rises so it won't do anything when the car is standing still.
    If it was truly and effective location for a "grill", on the challenge cars they could have made that panel removable so that there was nothing there or made it as on open slat design like the front grill with a lot more penetrable area.
    I bet it is marginally effective at best if analyzed with sensors.
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Not sure how you arrive at 25%, it's greater than that.
  13. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    NO fans....very simple yet effective design based on fundamental laws of aerodynamics and thermodynamics.
    If I have a great enough pressure differential I can get a full grown cow to pass thru a hole the size of a softball or better yet I can drive upside down in a tunnel.
  14. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Calculation of open area - RMIG
    Go get three measurements and feed it into that formula. Round holes, triangular or rectangular pitch.
    Size of hole and the other two criteria for spacing and tell me what you get.
    My bet is it is less than 20%
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Bob, I don't need that. I'll draw the profile in my CAD system for 1" square and calculate the surface area.
  16. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #66 drbob101, Aug 11, 2014
    Anyone with a challenge grill, can you supply those measurements. Diameter of hole and spacing between holes and if oriented rectangularly or triangularly.
    Thank you
    Pulled this image of a CS grill. I think it is the same. My guess here here without a ruler is 3mm hole with 8mm between holes, triangular pattern. Using that calculator the open area is 12.8%.
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #67 Dave rocks, Aug 11, 2014
    I looked at a close up image. It's appears to be a triangular pattern, but it's not. It's not a symmetrical pattern in both axis so to speak. In the direction of the triangle patten it appears to be a ratio of 1 to 2. Meaning the pitch is 2x the hole diameter and that yields 22.7% from the formula.
    EDIT, it is a triangular patten that repeats.
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #68 Dave rocks, Aug 11, 2014
    Just measured the screen image by percentage and came up with 2 to 3.5 ratio. I'll measure the grill later. It calculates to 29.6%
    I first drew the 1 to 2 ratio and it was too great.
  19. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #69 drbob101, Aug 11, 2014
  20. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Bob, as I stated, I could not feel a different when stopped. That does not mean there was no difference when driving and I also did not check with any measuring device.
    In summary, we can argue all day long about percentages but I'll trust Ferrari and Pininfarina engineers that they knew what they were doing when doing the design.
  21. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    So we have 1 small panel that has the possibility to flow appx 30% under optimal conditions if blocking panels and heat shields are optimized. This one small panel is part several so at best a single % improvement in heat reduction.
    Trust Italian engineers? Maybe so but not after the bean counters and styling team add their 10 cents to the outcome.
    Why do I feel like a glass of milk?
  22. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,919
    Richmond
    Pete
    FFS, 20% of that panel is a huge amount of area for air to low through, especially compared to 0% with the stock panel. The % is inconsequential, but the area is, which that would equate to a pretty large single hole in the back of the car to let heat out (about 2x the size of a license plate). However, the small holes are better than a single large one as there's no need to funnel the air through a single hole, it can just go straight out without having to make any turns or have any ducting adding weight.
    You guys have obviously never opened your oven just a crack, have you? Maybe it's 3% of the area of the whole door but it sure lets a lot of heat out. Open it 20-30% and you'll let almost all of the heat in the oven out. You could open the door all the way and it wouldn't make much difference.
  23. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    Looks great, Dave. When mine is sitting at idle, I can literally feel the hot air coming out of my challenge grill if I'm standing back there.
  24. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    #74 308 GTB, Aug 11, 2014
    As the name of the part implies, it was designed for the F355 Challenge to increase ventilation of the engine bay.
    This is from the 1995 F355 Challenge Manual (Table 4: Body External Elements)...
  25. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Yes Pete and you open the oven with the crack at the top and the heat escapes up and out, not out and up. Very similar to opening the engine bay. If your oven had a panel on the front door and you opened it like a fireplace where the challenge grill is you would feel the radiant heat but not the release that occurs upward.
    Using the fireplace analogy, with no door or screen you enjoy the radiant heat. If you put a panel in front of the fire made up of challenge grill material you would not feel the radiant heat anything like with no material there. The heat from the fireplace mostly goes up the chimney.
    Its just conjecture without absolute testing of two vehicles under identical conditions. If you like the way the challenge grill looks then its your car and thats all that matters. I think that thinking the challenge grill is reducing engine bay temps is a fallacy.
