355 dash instrument light bulb type/no.? | Page 2 | FerrariChat
Discussion in '348/355' started by hjp, Feb 10, 2016.
  1. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Interesting. The numbers I listed came from CEC Industries, the maker of the 2721 and 2722 bulbs on Memotronic's website. I converted the MSCP values given to lumens using the 4pi conversion. The 2 different values are pretty close for the smaller bulbs but off more than I would have expected for the larger.
  2. Qavion
    Qavion F1 World Champ
    14,663
    Ian Riddell
    I thought I may have escaped this fatal mistake after turning on my ignition a few weeks ago with one of the instrument panel harnesses not hooked up (when working on a seat belt warning light problem), but when I went for a drive today (I think the first since working on the car), the light didn't extinguish.
    Does it always blow up the module, or might there be some basic steps for getting rid of the light (e.g. battery reset, some kind of factory reset, etc)? I get the impression from other message threads on the forum that it is not always fatal.
    Cheers
    Ian
  3. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Out of ignorance, I did turn on my ignition 2 separate times while my cowl was out. Maybe I was just lucky but when I put everything back together, everything worked normally. Go figure?!
    Deadshort likes this.
  4. Qavion
    14,663
    Ian Riddell
    Seems I got relatively lucky, too. A battery reset did nothing, but my local independent Ferrari mechanic plugged his computer into my airbag diagnostic port and reset the airbag module (for free!). Fortunately, nothing was blown up.
    Access to the port is via a loose plug behind the passenger footrest (yellow harness = airbag)
    Cheers and sorry for hijacking the thread (*^ ^*)
  5. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Here's an update on the dash and instrument lights.
    I put the OEM incandescent bulbs with the OEM green socks back in my car, (3) 1.2W in the tach and (3) 2W in the speedo. The oil and water each had 1.2W with the OEM green socks and 2W clear for the idiot lights (these shine through red plastic built into the 2 gauges).
    In a completely dark garage, the speedo was noticeably brighter than the tack and both the small gauges were about the same as the speedo. The difference didn't "jump" out at you but was definitely there. I have checked three different 355 instrument light groups and found all had the same 1.2W bulbs in the tach and 2.0 bulbs in the speedo. Since there is a noticeable difference in intensity, I'm at a loss as to why Ferrari appears to have deliberately done this. For me, I don't like the difference so I'm going to replace the tach 1.2W with 2.0W to make them the same.
    I have not checked the lights in the 3 small gauges above the radio yet but expect them to be the same as the two in the cowl, 1.2W. If they turn out to be 2.0W, I will likely change them to 1.2 to match the others.
    As to the HVAC control unit in the center console, I have replaced the 3 LED's with 3 clear OEM incandescent bulbs. Unlike the other instrument bulbs that can be pulled out of their sockets, these are permanently attached to theirs. There were no visible marks on them either so I couldn't tell what their wattage rating was. I did check the light intensity though at the same time as I did for the others. These lights shine through a new overlay from Dave Rocks (which by the way, in my opinion, is better than the one I had from Hill Engineering). In my car, the intensity here was less than the other console lights and the left hand side was not as bright as the right (don't know why...bulbs are the same and the plastic diffusers appear symmetrical). It was definitely dimmer than the other dash instrument lights too but I don't think it needs to match those. In my opinion, its a bit too dim. So, I am now in the process of trying to find 2W bulbs that will fit in an effort to brighten it up. Don't know if 2W is larger than what OEM is but they are cheap so I'm going to try some if I can find them that fit.
    When I'm finished, I'll report back with the rest of my conclusions.
  6. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Here's my final update on the dash and console lights.
    Instrument cowl lights:
    1) Tachometer - Replaced the three (3) OEM 1.2W with three 2.0W. Reused the OEM green socks and black plastic bases. This now matches the speedometer light intensity and I like this much better. The bulbs came from Memotronics and are 2722 types. They come in packs of 10 at $4.99 each pack. These bulbs simply pull out of their bases for easy replacement.
    2) Speedometer - Retained the three (3) OEM 2.0W type 2722 bulbs with their OEM green socks and red plastic bases.
    3) Water Temperature and Oil Pressure Gauges - Retained the single 1.2W type 2721 bulb with its OEM green sock and black plastic base in both. Also retained the single OEM 1.2W type 2721 clear bulb and their black plastic bases for both gauge's idiot warning lights. If you need any of the 1.2W type 2721 bulbs, they are also available from Memotronics in packs of 10 at $3.99 each pack. These bulbs also just pull out of their bases for easy replacement.
    4) Instrument Cowl Warning Lights - There are 20 warning lights around the cowl, 4 on each side and 12 across the bottom (including the 2 turn signals). Stock, these are all 2.0W type 2722 bulbs in red OEM bases.
    Like all the other bulbs in my car, all but 4 of these had been replaced with LEDs. LEDs are polarity sensitive. If they are reversed in their sockets, they won't light up. You can't tell which way is which unless you mark them yourself. When my cowl was out, I inadvertently had rotated one of my turn signal LEDs the wrong way so the cowl had to come back out to fix it. Since most of these only light up when first started or are only used infrequently, I didn't see an advantage in LEDs here so I opted to replace them all with OEM 2.0W 2722 type incandescent bulbs in their OEM red plastic bases.
    4) HVAC Console Control Unit - Replaced the three (3) clear OEM Neo-Wedge type T-1 1/4 (W rating unknown...estimate 1.2W) bulbs/black bases with larger T-1 1/2, 2.0W Neo-Wedge bulbs/grey bases. These bulbs are rated at 14 volts so operating them at 12 volts should only add to their 7,000 hours of rated life. I am very pleased with the result. They now match the rest of the console button light intensity exactly and all HVAC markings are now lit up uniformly. The bulbs I found are made by JKL and are type DNW1-EW87/GRA. Unusually they have a T-1 1/4 base with a T-1 1/2 bulb. The bulb is not only slightly larger in diameter but also 3 mm taller (still allows 6 mm clearance below the plastic light diffuser). The overall light distribution and intensity is now much better. The base matches the OEM base perfectly except I did squeeze the circuit board locking tabs a tiny bit. Although they could be snapped into place as is, they were a very tight fit and this made them easier to twist into place. These came from Mouser at $1.16 each bulb.
    5) Three (3) Gauge Cluster (Clock, Gas and Oil Temperature) below the radio - I haven't taken these out yet because I am waiting to do it at the same time I replace the radio with a new OEM Sony unit (the radio has to come out to get at the gauges!?!?). These are now LEDs but I plan to replace them with OEM 1.2W type 2721 bulbs with OEM green socks just like the 2 in the main instrument cowl.
    I hope this clears up what OEM bulbs go where and what I believe are better sizes in some of the places.
    Shurik355 likes this.
  7. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    I need to make a small correction, add a caution and make 2 acknowledgements.
    First, let me say thanks to both johnk and Daverocks for their help with this. John researched the bulbs and where to get them and Dave provided some bulb information to both of us. Thanks very much guys. This is what Fchat is all about.
    The correction: The 2 clear idiot light bulbs in the water temperature and oil pressure gauges are not 1.2W. They are 2.0W. Everything else is correct.
    The caution: Sometimes a bulb didn't make good electrical contact with its plastic base. Either the bulb wires were slightly out of alignment (easy to bend them back), the base internal electrical contacts were bent too far open (twisted them back with a small stiff wire hook 2" x 1/8") or, in a few cases, the bulb wires were too short and when the bulbs were seated all the way into a base, they lost contact (reversing or replacing the bulb fixed that). So, moral to the story, be careful to check each bulb in its socket before you install it to make certain its working correctly. Some may not be making proper contact.
  8. Sheldon Rubin
    Sheldon Rubin Rookie
    Jul 10, 2006
    37
    Are the miniature T1.5 warning light bulbs removed by lifting them up from the plastic sockets? Or are they soldered into the sockets? I have a 1997 F355 Spider Euro Edition with standard shift. Most of the postings in this thread say that they can be removed. I modified a pair of surgical pliers but have found that the bulbs would not budge.
  9. Qavion
    14,663
    Ian Riddell
    Just looked at mine and they are the standard wedge type (push in to fit, no turning involved). The only metal on the bulb is the thin metal wires on the base, so if there is corrosion, it will only be between the metal wires and metal insert in the plastic holder.
    Persistence pays off. Wiggle them a few times from side to side.
    Cheers
  10. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The bulb pushes into a socket. The socket is a 1/4 turn into the board :)
  11. Qavion
    14,663
    Ian Riddell
    Thanks for clarifying my post, Dave :D ... I should have been more specific about what part didn't need turning.
    Are there any types of holders which have inbuilt LEDs or do all LED setups simply replace the lamp? I'm just wondering why Sheldon needed so much force.
    After becoming a victim of being too aggressive with lamp removal (glass breaking and cutting fingers badly), I discovered the experts use clear plastic (tubing slightly smaller than the lamp diameter) to push-fit over the lamp to help with stuck bayonette type lamps, but I'm not sure if this technique will work with wedge type lamps.
    Cheers
  12. alexpivo52
    alexpivo52 Karting
    Apr 5, 2014
    162
    Maryland, US
    Alex
    What is the 157491 Analog Clock bulb wattage by the specs? It has a black bulb socket hjp in the above stated 1.2W but in comparison to the Oil Pressure and Fuel Level Gauges next to (on F1) the clock illum is noticeably darker.
