355 dyno with raised rev limiter? | Page 2 | FerrariChat
Discussion in '348/355' started by INTMD8, Dec 8, 2009.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,499
    Southlake, TX
    Rob Lay
    #26 rob lay, Dec 10, 2009
    I haven't had the 355 C to 9k except probably in the heat of racing. This gets to 8.4k though. This is a little more power than most 355's, but that's what will happen when Risi spreads a little Maranello dust on it.
  2. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    I was never doubting Brian i was asking HIM questions, i find his first hand knowledge very interesting. Being that HE and only HE was the only one i have ever heard say that the 355 engine has been tested up to 10,000rpm, and all with the standard engine. So i am interested in his factual opinion. Unless you yourself have personal experience like Brian in knowing the 355 can rev to 10,000rpm with out modifications.
    I am just interested in facts thats all mate, we all have opinions.
    Oh and your highlighted quote is what you said, not Brian.
  3. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Out of interest mate, what are your engine specs? And has your RPM limit been raised, if so are you using a reprogrammed ECU? If you have used RPM above 8500rpm, what did you experience performance wise? Was it beneficial? Sorry for all the questions:)
  4. Rifledriver
    37,310
    #29 Rifledriver, Dec 10, 2009
    I have no opinion about the lifters. Ferrari's opinion was that is what they were designed for.
    My opinion is that if you do not like changing timing belts, burning out headers, rapid valve guide wear and a host of other rapid wear and broken parts issues, doing 10,000 rpm is probably not a good idea.
    But then again being rude to Terry is probably not a very good idea either, he was expressing an opinion and passing on information. If you don't like it don't read it.
  5. tazandjan
    39,364
    Sambo- I lost your train of thought, mate. I think I may have overlapped one of your posts while you were asking Brian a question. I believe you and I are in agreement and not much opinion is involved. You asked me a question, so I answered it.
    Sounds like we were both hot-rodders in the 1970s. Also 1960s for me. Mine were various 60s Corvettes, small and large blocks, some with solid lifters, and some with Crane and other hydraulic lifters.
    Andrew- I know of a chain conversion for the 308 series, but not for later engines. I am not sure you would gain enough average HP to make the cost worthwhile. By the time you paid for the conversion for later engines, you could have bought a 430 engine with chains and more HP.
    Based on what Brian said, you could probably raise the rev limit on the engines and just change belts more frequently. Way more frequently, like they do on race engines.
    Taz
    Terry Phillips
  6. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #31 sambomydog, Dec 10, 2009
    God this is hard work Brian:( First thanks for the response. Secondly i had no intention of being rude to anyone, how do you see it that way?. He was saying that what he wrote was what you said (at the end) and i simply pointed out to him it was what he said and not you.
    There's something bloody weird in translation about the English language:(
    Thanks for your opinion anyway for what it worth.
  7. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #32 sambomydog, Dec 10, 2009
    I did not mean to disrespect you in any way mate. I also see it as a misunderstanding:)
  8. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    Rifledriver,
    Is there any record of what kind of power the engine was putting out at 10,000RPM? Or was there a target they were looking to try and hit?
    Jim
  9. tazandjan
    39,364
    Sambo- Do you have a 355 or work on them? Your profile does not say.
    Brian- Thanks. After getting banned for ripping off someone's face last month, I am now more circumspect in my replies. Let me know if I misquote you at all. Sounds like raising the rev limit probably causes more problems than just belts.
    Taz
    Terry Phillips
  10. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    Wow, 10k RPM with a 355 engine would have to sound amazing!!
    Interesting that the belts were the weak link and they decided to keep them and reduce the rev limit...
  11. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,230
    Huntsville, AL., USA
    Andrew
    Taz/Terry,
    Thanks for the thoughts - it makes interesting reading. :D
    All the best,
    Andrew.
    PS: Do you prefer to be called Taz or Terry? :confused:
  12. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #37 sambomydog, Dec 10, 2009
    My personal 355 spider of 8 years plus, has nearly 100k miles on it. And i work on my own cars mate.
  13. tazandjan
    39,364
    Sambo- Thanks. Sounds like a Ferrari being used like it should. No SD2/3 for me, so harder to do my own work. Any photos?
    Andrew- Taz is fine. Most of my friends call me that.
    Taz
    Terry Phillips
  14. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #39 sambomydog, Dec 10, 2009
  15. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,827
    Lake Villa IL
    Just to add a bit to the lifter discussion, hyd lifters were never really a problem, the problem is valve control.
    Fluid is incompressible so the only loss of net lift/duration due to a hyd lifter will be if there is any air in the oil that can be compressed.
    As far as lifters pumping up that can only happen when valve control is lost. For instance if springs are too light or cam profile is too aggressive the lifter can loft over the nose of the cam. On it's way back down the constant load on the lifter is lost and it 'pumps up' to take up the slack. Otherwise, the lifter cannot "pump up" on it's own as that would mean oil pressure would have to overcome valvespring pressure +whatever amount it's leveraged. (a pushrod motor with 200lb seat pressure and 1.6 rocker arms would mean the lifter is seeing 320lbs on the seat)
    Of course their are plenty of possible valvetrain problems as well that plague a pushrod motor but are eliminated with overhead cams.
    I frequently build cars with LS series pushrod V8's, hyd lifters, twin turbos, 1150+rwhp and 7800rpm.
    Anyway, to get back on topic, if a 355's valvetrain can sufficiently control the valves up to "X" rpm (say 10k as Rifledrivers example) without loft our bounce, then the hyd lifters should be no problem whatsoever.
    I'm not certain I would be comfortable spinning one to 10k on a regular basis but if a dyno test showed a peak at 8.5k with a nice smooth taper (no drastic drop) to 9k or 9.2k than I would roll the dice and try shifting it there.
  16. tazandjan
    39,364
    Sambo- OK, now I am jealous.
    Taz
    Terry Phillips
  17. Rifledriver
    37,310
  18. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,230
    Andrew
    Ok, Taz. :)
    All the best,
    Andrew.
  19. rob lay
    Dec 1, 2000
    64,499
    Southlake, TX
    Rob Lay
    I don't know exactly, completely stock, but probably just really tight and blue printed on the specs. Only real performance besides blueprint would be the Challenge exhaust.
    I don't think there is much more for power after 8,200 or so. Sometimes I do go higher if trying to pass or hold someone off and a shift would be slower in long run.
  20. F355Bob
    F355Bob Formula 3
    I had my engine rebuilt by Gary Sharpe(enginefixer). I have a chip out of a challenge car and reline is 9000. I hit the rev limiter often in 3rd and 4th gear at Road America this fall and the car was still pulling at 9000.
  21. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,827
    Lake Villa IL
    If you make it to the chicago area I'll dyno the car if you like.
  22. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,763
    If you look at the workshop manual you will see that after a fraction of a millimeter of lift, the oil inlet to the lifter is cut off, so it cannot pump up on the overrev. In fact, it can only pump up when it is sitting within spitting distance of the base ring on the cam. The problem on these lifters is that they can pump down at high revs and loose a small quantum of both triminig and lift. Not exactly what you want at high RPMs and full throttle.
    Given the shape of the curve supplied by gothspeed, it is likely that there is little extra power (not more than 5RWHP), but a big increase of the area under the curve as the power holds near 300 HP for most of another 1000 RPMs.
  23. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,827
    Lake Villa IL
    Anything is possible but I assume that statement is just speculation?
    Not sure how much oil can bleed back down (with the oil inlet in lifter blocked off) in a matter of milliseconds but I doubt it's signifigant.
    Even if there was a very small amount of net lift/duration lost at the valve due to the hyd lifters but it didn't greatly effect power than I'll still stick by my first statement that a shift point higher than 8500 would be beneficial in terms of acceleration. (With the downside of increased wear as others have mentioned)
  24. F355Bob
    F355Bob Formula 3
    There is a dyno in Mosinee Wisconsin, so this spring when I get the car out, I'm going to dyno it.
  25. UConn Husky
    UConn Husky F1 Rookie
    4,425
    CT
    Jay
    In most OEM engines the fuel cut speed is set by valve control and valve spring stresses. This is all a function of spring design (inner / outer assembly in the 355), valvetrain masses, cam profile and rpm. It certainly is possible to have another component that is the 'weak link' as Brian said the connecting rods were, but most often it's valvetrain control. This is why the F1 cars got rid of coil springs completely and went to a gas spring, to have a much much higher natural frequency.
    Also I can say for sure the 355 spring (outer spring at least) is relatively highly stressed, I have a broken one out of a challenge car. It broke in just pure high stress fatigue, absolutely no problem in manufacture or materials.
    After all the data and high speed video I've seen of valvetrains doing a wild dance above redline, no way would I take the 355 into that territory.
