355 dyno with raised rev limiter? | Page 3 | FerrariChat
Discussion in '348/355' started by INTMD8, Dec 8, 2009.
  1. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,827
    Lake Villa IL
    Valvetrain high speed video certainly is interesting to see.
    I'm suprised the 355 runs a dual spring for how little mass it needs to control.
    Do you have the specs on them as far as ID/OD installed height seat/open pressure and rate?
  2. UConn Husky
    UConn Husky F1 Rookie
    4,425
    CT
    Jay
    #52 UConn Husky, Dec 11, 2009
    Here's the valve spring data from the WSM, Vol 1.
    Just to translate a bit in case it isn't obvious, 'L' is length in mm, 'N' is force in Newtons. Wire diameter is 3.3 mm on the outer, 2.2 mm on the inner. These are TINY little springs thanks to the small valves they need to control.
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,827
    Lake Villa IL
    Nice, thanks for posting that.
    Translated into numbers I'm more used to looking at (if I'm reading it correctly)-
    1.13in installed height- 64lbs seat pressure
    .76in open height- 156lbs over the nose
    Is cam lift .370in?
    Any diagrams showing spring/retainer outer diameter and valve stem diameter?
