News
355 electric connector
Discussion in '348/355' started by darrenliu, Apr 8, 2010.
  1. darrenliu
    darrenliu Formula Junior
    Jun 24, 2008
    440
    Melbourne Australia
    Darren Liu
    #1 darrenliu, Apr 8, 2010
  3. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,271
    Hugh G. Rection
    Looks like cam position sensor to me. Check the parts diagram to be certain. Three conductor, yes? Male side would be easiest to just get a new Bosch cam position sensor. For the female side, talk to Dave Helms, he carries all the various tools and parts to fix them.
  4. darrenliu
    Jun 24, 2008
    440
    Melbourne Australia
    Darren Liu
    yes, it is 3 pin connector. I think i've been driving my car with this plug disconnected. Female side looks OK, just the male side. The cable is quite short.
  5. darrenliu
    Jun 24, 2008
    440
    Melbourne Australia
    Darren Liu
    Can someone please help finding this part on the parts diagram. Thank you.
  6. eric355
    eric355 Formula Junior
    984
    Toulouse (France)
    Eric DECOUX
    #5 eric355, Apr 9, 2010
    This is the connector of the left bank knocking/detonation sensor. The sensor is bolted on the engine block (in the center of the V) between cylinders 6 and 7.
    Definitively not the cam sensor or throtle potentiometer, they are both on the right bank on the 5.2.
  8. f355spider
    May 29, 2001
    17,271
    Hugh G. Rection
    #6 f355spider, Apr 9, 2010
    +1, I was just studying this on the Ricambi America site parts diagrams this morngin, and there is only one cam position sensor on the 355 (sorry, my car was not around for me to inspect and many V8's have two...my BMW does)
    http://www.ricambiamerica.com/parts_catalogs.php?M=FE&P=&V=diag&I=1449 it is clearly the knock sensor. The quick fix would be to replace the knock sensor. Can't find the specific drawing that gives the part number for the knock sensors, but you can clearly see them in the above diagram.
  9. darrenliu
    Jun 24, 2008
    440
    Melbourne Australia
    Darren Liu
    Excellent guys, thanks for your help. Looks like the male connector is part of the wire harness that goes back to the ecu. I will have to cut the cable, and install a new male 3 pin amp connector.
  10. f355spider
    May 29, 2001
    17,271
    Hugh G. Rection
    #8 f355spider, Apr 9, 2010
    To do the job correctly, you need to have the pin removal tool, so you can cut the pins off right where they meet the wire, to conserve wire. I would plan on replacing the boot, since they are all marginal at best, even if it is not yet cracked or torn. You will need the pins, and new connector, as well as the special double crimp tool. Contact Dave Helms for all the stuff. It is a small investment to have the stuff, and then you can fix virtually any connector in the engine compartment! ;)
    Actually, upon further inspection, it looks like the male pin side is the knock sensor cable. There is no rubber boot on that side right? I would simply order a new knock sensor rather than bother repairing it.
  11. darrenliu
    Jun 24, 2008
    440
    Melbourne Australia
    Darren Liu
    Thanks D
    It is the knock sensor side, there's not rubber boot. Does anyone know the part no. and cost?
    I was thinking of repairing the plug as follows:
    Remove the cracked plug, and expose the pins
    Prepare a new male amp connector with lead and 3 spade plugs
    Connect the spade plugs to the exposed pins, use heat shink to cover the connection points
    connect the male plug to the female plug
    What do you do think?
  13. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,860
    Mount Isa, Australia
    Pap
    Just strip them back and solder them. **** the plug off! :eek::eek:
  14. darrenliu
    Jun 24, 2008
    440
    Melbourne Australia
    Darren Liu
    Yeah, never thought of that!
  15. f355spider
    May 29, 2001
    17,271
    Hugh G. Rection
    Sourcing the parts and tools is a pain. Dave Helms has them, but it would be much simpler to just get a new knock sensor.
  16. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,732
    F683
    No outback fixes allowed here! (unless you're in the outback)
  17. lndshrk
    lndshrk Formula Junior
    Nov 7, 2003
    753
    SLC, Utah
    Jim Conforti
  18. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,860
    Pap
