News
355 Engine Codes
Discussion in 'Technical Q&A' started by cbrody, Jul 30, 2006.
  1. cbrody
    cbrody Rookie
    Nov 1, 2003
    35
    Southampton, NY
    Chris
    Guys,
    I'm getting codes P1448 & P1451 from a 1997 355 Spider. Does anyone know the def. of these codes and possible causes?
    Thanks,
    Chris
  3. trentw
    trentw Karting
    Jul 25, 2005
    93
    Ho-Ho-Kus, NJ
    Warren Trent
    P1448 - Catalyst bypass flap circuit - malfunction
    P1451 - Secondary air pump circuit - short to ground
  4. cbrody
    cbrody Rookie
    Nov 1, 2003
    35
    Southampton, NY
    Chris
    Thanks for the def's.
    Anyone know the possible causes of these or what to check?
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    You are the man! I have got my 1997 F355 down to the last code p1445 something about the secondary air, though not entirely sure.
    My electric blower motor runs fine and I have vacuum going to the plastic valve right next to it. I guess I should check to see if it is opening.
    Does any one have any info on the exact code definition or what to check??
  6. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,317
    Make sure the filter material is not clogged up...there was a recall on that...make sure yours has been taken care of.
  8. trentw
    trentw Karting
    Jul 25, 2005
    93
    Ho-Ho-Kus, NJ
    Warren Trent
    P1445 Catalyst Temperature (Vescovini) - range/performance issue
    Check the wiring
    Check the Vescovini ECU functionality
    Check the thermocouple functionlity
  9. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Vescovini?? Is that the thermocouple ecu or the O2 sensor ecu?
    Thanks for the help!
  10. trentw
    trentw Karting
    Jul 25, 2005
    93
    Ho-Ho-Kus, NJ
    Warren Trent
