355 engine mystery | Page 2 | FerrariChat
355 engine mystery
Discussion in '348/355' started by fazzaz1, Feb 7, 2009.
  1. Rifledriver
    37,335
    Thats the way it always happens. In the past 2 or 3 years there have been several such threads here. All the same, no noise just a power loss. I have fixed many motors with a broken belt, all exactly the same, just a dead bank. No noise, no drama just an expensive repair.
  2. Rifledriver
    37,335
    Sorry for you trouble but your experience is why Ferrari went to 3 years on belts.
  3. hacker-pschorr
    hacker-pschorr Formula Junior
    Sep 27, 2006
    584
    Land of Lambeau
    What exactly failed on these? Everything was in working order and the belt simply snapped?
  4. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I would really like to see the hydraulic tensioners and tensioner pulleys to see if this was the cause of the failure.
    I just took off my belts ( I am doing a major service on my 355 in another post) and they were in perfect condition ALTHOUGH
    the left tensioner is leaching grease.
    I know the recommended service is to change the tensioner pulleys every second tbelt change but in my case, (according to the dealers service history) they were changed at the last belt change.......certainly won't be used again.
    So, did a tensioner pulley fail? And when was it last changed?
  5. Rifledriver
    37,335
    What does perfect condition mean? They still had all their teeth? Belts get hard with age and are less resiliant. Cant tell that by eye.
    Who says the recommendation is every other belt change? Ferrari never did.
    They weep grease the first time they get hot.
    Like I said, Ferrari says 3 years. This is why.
  6. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    #31 enginefxr, Mar 9, 2009
    Still had all their teeth? Unlike this?
  7. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    #32 cf355, Mar 9, 2009
    Actually the 'Ferrari DEALER' did say to change the tensioner bearings every other belt change on the 355 (although I intend to change my tensioner bearings with every t belt change).
    And only one of my two tensioner bearings weeped grease.....the other one is as clean as the day it was installed.
    As for the belts....there is no evidence of any wear of any kind, including missing or chaffed teeth, ect. ....although I do agree that rubber does harden with age.
    In any case, if it were my car, I would want to determine the cause of the failure.....and to that end I would start with the tensioner pulley and hydraulic tensioner.
  8. Rifledriver
    37,335
    Belts snap and actually break only very rarely. They just strip a few teeth off at the drive pulley. It is the same with most cars.
  9. Rifledriver
    37,335
    That was their opinion. It is not the policy of FNA or Ferrari Spa.
  10. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    In addition to the tensioner pulleys I am also replacing the hydraulic tensioners and waterpump even though they appear to be ok. They have been in the car for 14 years and owe me nothing.
    I also make sure the car is run regularly to prevent the problem that 'garage queens' have with tbelts shearing teeth, ect....even in the winter when I am unable to run the car on the highway I run the engine up to full operating temperature to 'excercise' the tbelt.
    I am a strong believer in preventative maintenance.
  11. hacker-pschorr
    Sep 27, 2006
    584
    Land of Lambeau
    I hate to sound repetitive, in the cases where the belt did snap, I'm assuming something else failed first (tensioner, bearing etc...) causing excessive stress on the belt causing it to snap.
    Most of the belt failures I've come across (non Ferrari) the water pump is the #1 suspect, followed by a siezed roller or tensioner. Since the 355 TB doesn't run on the water pump, that scenario is out.
    Were a lot of the failures due to bad bearings discussed in a different thread? Are there too many shops out there willing to simply slap a belt on?
    Is the timing belt supplier the culprit? I've come across non OEM Porsche belts there were garbage.
    Just the other week my local VW / Audi dealer told a customer changing the rollers and water pump during a 50,000 miles TB job was a waste of money. You cannot even trust the dealers anymore.
    Sorry if I'm beating a dead horse here. I'm awfully curious (as I'm sure a lot of people are) what the smoking gun is with fazzaz1's belt.
  12. Rifledriver
    37,335
    I try very hard not to work on the kind of cars that are not likely to have price shopper parts in them so I do not know if I have ever even seen a non OE belt in service.
    Most of the time I have seen a belt that was actually broken it was foreign object damage. Something got between the belt and pulley. Even then if it is a reasonably fresh belt the belt is plyable enought to survive. I have seen some pretty bad stuff happen to belts that were not lifed out already.
    Teeth can and do strip off just from being old and hard. They can also strip off from failures but most I have seen there was no failure of any kind except the belt and those belts have never been new belts.
    All I can say is I hate to work on cars for free and my own Ferrari belts get changed when Ferrari says to do it. I have been working on these cars since near the time they went to belts and I can say from direct hands on experience their policy is a good one.
  13. UConn Husky
    UConn Husky F1 Rookie
    4,425
    CT
    Jay
    OUCH! sorry to hear, hopefully the damage isn't too pricey. I too would love to see pictures of how it failed and any info on the tensioner condition just to learn a thing or two.
    While it's out...for the exhaust manifolds I went with Fabspeed headers ceramic coated, so far so good. Just need some extra heat shielding (especially on the alternator).
  14. hacker-pschorr
    Sep 27, 2006
    584
    Land of Lambeau
    There are 3-4 available for the 928.
    http://forums.rennlist.com/rennforums/6126300-post12.html
    I guess it's reassuring you are not seeing new belts breaking! :)
    I'm not disagreeing with the service recommendation, just curious that’s all. I change the TB on my 928’s every five years, they are not even valve benders.
    What are the odds fazzaz1's car had one of the "bad bearings" installed? Just thinking outloud.
    http://www.ferrarichat.com/forum/showthread.php?t=217149
  15. Rifledriver
    37,335
    I change them mostly because I have no desire to have any vehicle in the garage that I can't at a moments notice get in, twist the key and drive to the other side of the country and back. I just cannot stand not having that degree of confidence in my vehicles and good recent timing belts are part of that.
    We are all just guessing at this point. Anything is possible.
  16. fazzaz1
    fazzaz1 Karting
    Nov 4, 2003
    89
    Mississippi
    Sam Scott
    Latest news is 7 bent valves on side where belt broke,3 intake and 4 exhaust. Belt apparently simply broke. Significant valve guide wear, especially exhaust which led to replacing all valve guides on both sides. Also water pump seepage(29,000 miles). Exhaust manifolds ok. My car was built in Aug. 1997 and apparently has old valve guides. Thanks for the interest.
  17. zero
    zero Guest
    Apr 24, 2007
    776
    #42 zero, Mar 23, 2009
    What about the piston damage? Is that it just bent valves??? No damaged heads, pistos ect? Do you have any pictures? The more the better please:)
  18. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    While some damage is possible it's typically mostly cosmetic. The valves take the brunt of the crash.
  19. fazzaz1
    fazzaz1 Karting
    Nov 4, 2003
    89
    Mississippi
    Sam Scott
    Finally learned that cambelt broke because tensioner seized. Replaced all valve guides, all exhaust valves and three intake valves. Car finally finished and runs great. I apreciate all the interest. If you must replace a fan as I did, be sure to go to the Fanman's site and get it for fraction of Ferrari cost. I checked numbers and earleier threads on here are exactly correct.
  20. zero
    zero Guest
    Apr 24, 2007
    776
    #45 zero, Apr 28, 2009
    Glad its all back together mate:) Although more photos of this rare event would have been good:( No pictures at all of the event/work/dammage.
    So because your tensioner seized, does that mean that your tensioners were not replaced during your last belt change?? I wonder how old they were.
    If they were changed they would last a lot longer than 3 years, what bearings were used on the tensioner?
    Maybe the last owner bought cheeper tensioner bearings, also to keep the cost down to the fraction of the cost of Ferrari standard;)
  21. hacker-pschorr
    Sep 27, 2006
    584
    Land of Lambeau
    Awesome - good to hear she's back on the road!
    +1,000,000,000,000
    I asked in a previous post when the last belt change was. He said he purchased the car in 2003 with 26,000+ miles and it just had a fresh major.
  22. zero
    zero Guest
    Apr 24, 2007
    776
    I just dont know, something dont sit right with all this.
  23. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Maybe the owner bought OEM Ferrari parts and had to deal with that!
  24. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    So much for the so called "Ferrari Standard".......I believe that to be somewhere between "crap" and "more crap" with a non-return policy....lol
  25. zero
    zero Guest
    Apr 24, 2007
    776
    So then ifthat was the case, and the belt was changed within 3 years or 30k miles. Then should Ferrari not have pick up the bill?
