355 engine w/360 parts?? | Page 4 | FerrariChat
Discussion in '348/355' started by bcwawright, Mar 14, 2007.
  1. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    You are absolutely right.....I finally dug out the FIA GT rule book, and there it was concerning the restrictor.......
    Thanks for the help.....I will NOT be going this route as the whole objective in this project is max. hp with bullet proof reliability.....
    I am still puzzled with the absense of the AFM's..
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Maybe they are running MAP instead??
  3. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    That makes alot of sense...do you have any idea if it would be worth deleting AFM and using MAP?....this is not my expertise...lol
  4. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I think there may be a way out there. It should breath easier too :)
  5. fatbillybob
    Aug 10, 2002
    29,359
    socal
    ASk No Doubt. It could be that since racing street drivebility and emmissions is not an issue. Therfore, they can Alfa-N? Throttle position and RPM to sence load and they map the ECU based on that.
  6. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    My thoughts also.....but is the increase worth the cost?? Could you use existing 355ecu or would I have to go with aftermarket?
  7. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I think the goal would be to use the existing ECU :).
  8. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Who on this forum is the ECU geru.....I always get lost with the motronic system.....all my former race cars ran mechanical FI...that gives you an idea of how old I am...lol
  9. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Not my expertise either, but I've been doing some research on this so I can put open stacks on my 355 tbs. There's a guy who builds a box that will interpret the signal from a map so that your motronic reads it as a maf. The maps I've tested give voltage readouts backwards and in a narrower range than the maf on my motor. See my thread "355 throttle bodies on a 348" for the reference. IIRC, he gets about $400 for the box.
  10. fatbillybob
    Aug 10, 2002
    29,359
    socal
    Hey Plugzit, Gothspeed ,
    Are'nt those tubes Helmhotz trompettes?
  11. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Since you are much further ahead in your project than I am, do you think the MAP setup will produce hp gains worth the time and expense?
  12. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    That's what Imagonnado. IMO, the more controls and sensors you have, the finer the tuning, the greater the horsepower, but the mafs limit the possibilities. What I'm really going for tho is the look of old Hilborn injectors sticking out of the hood! (I'm that old too).
  13. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Yes, it looks like they were made to produce the fabled Conical Helmholtz effect, said to create a tornadic effect. By taking the outside airflow from the tornado, a high pressure ram effect is created thus obviating the need for turbo- or supercharging. The problem has always been sustaining stoichiometry throughout the curve. A moving chicane solution has been sought for eons using everything from transducers to gerbils. A change to Motronic 5.8 would seem to help, but even decimals on Motronic systems create a new problem that can only be solved by arithmetic. Your input would be apprecaited.
  14. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    No. The opposite actually.
  15. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    What's the opposite of trompette?
  16. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Show off....lol.......I was hanging in there with ya until I got to the "moving chicane" thingy.....Ima goin to have to GOOGLE this one...lol
  17. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Sounds like an awesome setup when you finish...........love the old Hilborn setup....then you get to put the tennis balls(dyed Rossa Corsa of course) in the stacks
  18. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    You got it exactly!
  19. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
  20. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Sounds like the ticket!! Are you going to pull the trigger?? :)
    Absolutely!! That way I can just put air cleaners at the inlets :)
    :eek: Plugzit!! You have gone mad!! It may be stemming from the aproximal overexposure of the 355 TB's to your cerebellum causing a cyclical disruption to your central algorithm processing intermediary :eek: whereby your modus operandi has been markedly amended to its exitant constitution :eek:
    So in summation you are screwed up and in severe need of an F355 as a counteractant :p :p !!!
  21. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Sorry if I scared you. Sometimes I have short periods of lucidity to screw up an otherwise gloriously insane day.
  22. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    :D :D :D
  23. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    :eek: Plugzit!! You have gone mad!! It may be stemming from the aproximal overexposure of the 355 TB's to your cerebellum causing a cyclical disruption to your central algorithm processing intermediary :eek: whereby your modus operandi has been markedly amended to its exitant constitution :eek: :p :p !!![/QUOTE]
    No wonder PLUGZIT is getting big hp gains....he's got Helmhotz Trumpettitus...lol
  24. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    LOL ;) :p
  25. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    #100 ferrarifixer, Mar 31, 2007
    Air flow meters can be removed with an ECU flash..
    you can then remove the filters and sensors which restrict flow so much.
    Mixture map is then dependant on pre set throttle position based programming and lambda readings.
    Here's an opened 360C air flow meter... note.. straight through.. no air flow sensor in the way, and the sensor terminals are simply folded flat out the way (looks like std from the outside).. You could always just fit a straight pipe.. but unless you have rigid engine mounts (360 Michelotto), you need the flexible tubes.
    also, here is a modified 360 Inlet manifold..
