355 engine w/360 parts?? | Page 6 | FerrariChat
Discussion in '348/355' started by bcwawright, Mar 14, 2007.
  1. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Don't have one here at the shop yet.....but have one on hold.
  2. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    Oh, the back cut angle on the rear of the plenums, just like the ones I fabricated for my 348.
  3. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Dave is that a cooling collar??? I have not seen this two piece design..is it metal or plastic?
    Sorry about that Phil....I just got off the phone with Dave who is doing some glass work for my engine bay cover...lol
  4. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Back cut angle is definitely not stock......like it.......what is the purpose of this design??
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    I just got my 360 exhaust manifolds :D :D . Time to open the box!!! :)
  6. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    PICS!!!!!!.....gotem installed yet..lol
  7. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Phil...I thought there was a black box added to the CH car which was MAP...or atleast Michelotto had developed one for the N spec cars...
  8. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    LOL :p....... Dude, you know the work has just begun :eek: . There will be some serious jigging and mocking going on this weekend ;) .
  9. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    No... the back cut angle is stock... it was done to ALL 360's upon introduction of the spider model... it makes no difference to performance... it's done for clearance to the roof mechanism!
  10. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Nope... there is no MAP sensor on Michelotto... and nor 360C. All programming for engine is within the standard ECU's.
    Step 5 360 GT engines have Marelli management but require cable operated throttles, and I "think" they have a MAP sensor.
  11. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Give me a holler-I'd like to see that done.
  12. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Cool......post plenty of pics.....best of luck
  13. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Phil is that a cooling collar?? I now see the reason for the angle at front of plenum cover.......but nowhere do I see this was offered in a 2 piece design like yours.....hmmmm
  14. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Ok, you got me :eek:. I was trying to sound 'gung-ho' ;). So far they are only out of the box. :D
    I will be using them to make a jig. So maybe later I can make a 4 into 1 configuration to dyno the differences of the stock 4 into 2 into 1 .
    Will keep you posted when the cool stuff starts happening :). I will keep that offer open Plugzit :) :D .!!
  15. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    So your telling me that you can disable the AFM's or remove them completely and make all changes necessary by reworking the factory ECU??
    Sounds complicated and expensive.......that being said I am starting to think like Group77 and considering the engine as 2 4cyl's sharing a common crank....there is some pretty trick stuff on the market for the HO high revving Japanese engines.....they do MAP conversions all the time with great success.....prices are very reasonable, and with laptop control you can make needed changes without burning chip after chip.
    I am open for all suggestions....my ideas are not set in concrete, and any help in the design will save me from alot of headaches(and money) down the road.
    Many thanks Phil....always look forward to your comments.
  16. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Been there many times......got something out of the box and just stared at it for days......sometimes I wished I had stared a little longer....especially after I turned it into junk..........lol
  17. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Ok Phil I give....if inlets are at stock height you've either lowered the engine or the stacks are shorter.....
  18. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    #143 gothspeed, Apr 3, 2007
    Here is the pic you requested ;). What is the controversy here :eek: ?
  19. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    No controversy.....just shows the mechanical TB's and linkage.....this would be the way to go for the 355, seeing that the 360 is a fly-by-wire setup that requires the 360 ECU and pedal assembly.
    Many thanks for the post Goth
  20. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Niiiiiiice (insert Borat voice :eek: ) !!! So will you be converting the stock 360 TB's to 'mechanical' linkage or will you be going with larger 'aftermarket' versions :eek: ??
  21. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Decisions,decisions,decisions......I like Group77's TB setup...I am not sure if his will bolt to ferrari plenum cover, but the plenum cover can be refabed to accept just about anything....I am at this point trying to figure out how the engine is breathing thru the longer runner at low rpm and transitioning to short runner at high rpm....if that is even how that sucka works??
    "Ima Bout To Loose My Mind..Up In Here".......lol
  22. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Hang in there man! This is for the greater good of all our 355's :). We have to keep those 348 guys at bay :eek: !!
    Do you have pics or a diagram of how the cross flow runners are configured??
  23. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Those 348 guys have it made.....atleast Michelotto showed the potential of that engine.......I don't believe anyone really took the 355 to those same limits...maybe the cost was prohibitive or at the time they were viable race cars other mfgs had far superior cars within the rule book limitations.
    I may even revert to 2.7 OBD1 if I have to...lol
  24. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Don't you have emissions requirements?? There are 5.2 ecu tuner guys out there...... I hope so at least :(
  25. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    I am NOT goin to tolerate this anymore.......that Daniel at Ricambi just sent me an obscene picture(really sick).....these 348 guys are gettin way out of control and now with the help of one of the sponsors who's name I will withhold(RICAMBI AMERICA) has proceded to use illegal parts in an attempt to make there cars look faster than a 355........there is no limit to how low than can go...........now Daniel, please,please,please let me have one of those...yes Ima beggin.................lol
