355 F1 Engine is out! | Page 3 | FerrariChat
Discussion in '348/355' started by UConn Husky, Jan 14, 2008.
  1. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,275
    MA
    Jay, you need heat in that garage! Best investment I made!
    Based on your experience. How difficult to remove the injectors with the engine in the car? Doesn't appear to be much room to work!
  2. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,984
    MD and NE
    Robbie
    37 degress---It was a toasty 65 degrees in mine while doing the Hyperflows....:D:D:D
  3. UConn Husky
    UConn Husky F1 Rookie
    4,425
    CT
    Jay
    Goth - I need to stop somewhere, I'm not touching those TB's! The sway bar is OEM, I just had it stripped and powder coated to trick you guys into thinking it was new :D
    John - I'd say removing injectors wouldn't be alot of fun with the engine in. Plenums need to come off, so you need to remove all that central 'stuff' to get to the throttle body clamps. Personally I would always just wait for the engine out service and do it then.
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,631
    The Brickyard
    The Bad Guy
    So when are the belts coming off? :D Don't forget to find TDC first. You may even want to mark the old belts, cam & crank pullies before you remove them.
  5. UConn Husky
    4,425
    CT
    Jay
    #55 UConn Husky, Mar 15, 2008
  6. 285ferrari
    Sponsor
    Sep 11, 2004
    20,984
    MD and NE
    Robbie
    Those look great--Like brand NEW--:D
  7. UConn Husky
    4,425
    CT
    Jay
    #57 UConn Husky, Mar 15, 2008
    Engine mounts installed! New ones look slightly different, but still fit just fine. My old mounts were in fairly bad shape due to the header heat drying the rubber out. I couldn't find any instructions posted so here's the basic procedure:
    1. Remove nut and bolt extending through the center of the mount (24 mm; long bolt drops out the bottom)
    2. Remove three nuts holding engine brace onto engine
    3. Jack up engine carefully to lift it slightly off of the subframe
    4. Slide engine brace off studs
    5. Remove 4 bolts holding motor mount in place
    Installing the new mount was a bit tougher due to the slightly different design, couldn't quite lift the engine up far enough without it pulling the subframe with it. Nothing a little muscle couldn't fix.
    Next step to make sure this is my last engine mount install is to make some small heat shields to deflect that upcoming Fabspeed heat :D
  8. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    Cool pics mate. :):)
    That old engine mount was broken eh?
    Injectors were just cleaned?? Did they say what the spray pattern was like before they cleaned them?? They do LOOK like new now. ;);)
  9. ultgar
    ultgar Karting
    Nov 21, 2003
    126
    New Jersey
    Steve D'Gerolamo
    #59 ultgar, Mar 16, 2008
  10. fcmotorsports
    fcmotorsports Karting
    Feb 4, 2008
    103
    Garage
    michael
  11. UConn Husky
    4,425
    CT
    Jay
    Mount wasn't broken, just was dried and cracking.
    Injectors cleaned and calibrated, before 3 had bad patterns (some dripping), after all rated excellent
    fcm: that's not my lift, I did the 2 jack technique.
    ultgar: Great pics! Didn't check mine yet, hopefully will get to that in the next week or two...
  12. PAP 348
    Dec 10, 2005
    100,249
    Pap
    #62 PAP 348, Mar 16, 2008
    Ah, ok. This one looks like it has 'sagged' and is cracked where I circled it. :):)
    Good to hear about those injectors. Your 355 will run even better now. ;);)
  13. ernie
    Nov 19, 2001
    22,631
    The Brickyard
    The Bad Guy
    Nice write up Jay.
    Why not get the Fabspeed headers ceramic coated? Or do they come that way?
  14. UConn Husky
    4,425
    CT
    Jay
    Pap - yes mine are sagged and cracked; not a total failure yet, the inner metal cone was still being supported all the way around by rubber...but no doubt a good time to replace them.
    Ernie - I ordered mine naked and will have them coated locally. But in my opinion the thin 'ceramic' coating is more for cosmetic, it won't be nearly as effective as the stock fiberglass / heat shield combo.
  15. UConn Husky
    4,425
    CT
    Jay
    #65 UConn Husky, Apr 1, 2008
    Here's the motor mount heat shield, hopefully I'll never replace motor mounts again with these in place. I used 0.027" titanium sheet, and on the bottom side I stuck on some ultra high temp ceramic fabric furnace lining, rated to 2300F continuous duty! (stuck on with high temp silicone). Just a bit overkill, but had this stuff laying around.
  16. Fpassion
    Fpassion Formula Junior
    Jun 1, 2005
    599
    Jay hope it works out well, I am humbled by your courage. Shocked to see a timing belt and no chain with guides anyhow, time for Tubi or what ever sounds awsome:)
  17. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Sweet!! Will be interesting to see how they go. :):)
  18. UConn Husky
    4,425
    CT
    Jay
    #68 UConn Husky, Apr 2, 2008
    Valve covers done; wanted to powder coat for durability but my contact said he couldn't match the color exact - the only wrinkle red he knew of is a brighter shade. So thanks to DrFerrari I picked up some VHT wrinkle red paint, and it is a perfect match as far as my eyes can tell!
  19. 285ferrari
    Sponsor
    Sep 11, 2004
    20,984
    MD and NE
    Robbie
    Holy smokes--Those look new--Well done!!!!!!!!!!!!!! Did you tape off the lines and Ferrari or paint over then sand off??
  20. UConn Husky
    4,425
    CT
    Jay
    Thanks; Mine were in excellent shape, just a bit dirty. Degreased + scrubbed with soap for prep, only had a few small bare spots. This takes 3 coats, after each I partially wiped off the plug covers then when fully cured sanded off the rest with 600 grit paper. 800 or higher would be nice for a final polish, I may still do that.
  21. ernie
    Nov 19, 2001
    22,631
    The Brickyard
    The Bad Guy
    It's commin along great Jay! Keep up the good work.
  22. PAULSPEED
    PAULSPEED Rookie
    Jan 27, 2007
    35
    Guys like you make me
    want to buy a Ferrari.
    I wish I could see your face the day you start it up.
    Paul
  23. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Just go ahead and buy one Paul. ;);)
  24. PAP 348
    Dec 10, 2005
    100,249
    Pap
    They look awesome!! :):)
    Cant wait to do mine. ;);)
  25. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Exactly... you'll never regret it...
    Excellent advice from Down Under.
    Mike in Kuwait
