355 F1 Engine is out! | Page 5 | FerrariChat
Discussion in '348/355' started by UConn Husky, Jan 14, 2008.
  1. UConn Husky
    UConn Husky F1 Rookie
    4,425
    CT
    Jay
    The engine won out, did excellent in the 25 mi. run despite the 96F heat. Passed lots of roadies along the way :D But now I've got the bug, I'm tempted to get a road bike now and stretch out for longer runs...
  2. UConn Husky
    4,425
    CT
    Jay
    #102 UConn Husky, Jun 10, 2008
    And back to 355 updates...passenger side radiator is replaced. It was much tougher to remove than install for some reason, and more difficult than the 348 it seems. Space is tight with the air intake hose directly overhead and the gas filler line blocking the AC lines when you try pulling the radiator out. I went with a new radiator, silicone hoses, and replaced the thermostat switch just because they seem to go eventually anyway.
  3. Ferrari Fanatic
    Ferrari Fanatic Formula 3
    Apr 2, 2003
    1,317
    SoCal
    Good work on the Mountain Bike. I did the same thing, went from MTB to road. 5 years later it has been awesome. I average 10 charity rides per year and was blessed enough to do 4 bike tours through Southern France...But then I don't have my engine out either :) I don't know how you do it all.
  4. UConn Husky
    4,425
    CT
    Jay
    #104 UConn Husky, Jun 10, 2008
    Yet another 'while it's out' project, replacing a failed inner CV boot. I started a separate thread to figure out how to do this here:
    http://www.ferrarichat.com/forum/showthread.php?t=200436
    I first ordered some Porsche 930 CV boots but they really didn't fit the 355 well; both ends were quite a bit smaller than the stock boot. They might have stretched, but I didn't want to risk it. So I went with the aerodynamic boot from Pegasus:
    http://www.pegasusautoracing.com/productdetails.asp?RecID=5549
    This fits well, except you have to remove the cap from the halfshaft side of the CV joint also. The rubber boot side was again smaller than stock, but did fit over the shaft. I need to pick up a CV boot clamp tool, using pliers isn't working too well.
  5. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,983
    MD and NE
    Robbie
    By the time your done it will be better than NEW!!!!! :D
  6. mparz
    mparz Rookie
    Jul 25, 2005
    10
    Upstate NY
    Mike Parzych
    Did you have a leak in the radiator that forced you to change it? I pulled my 355 engine this weekend and saw evidence of a leak on the passenger side... now need to dig in and hoping it's just a loose hose.
  7. UConn Husky
    4,425
    CT
    Jay
    I had what looked like a small leak, plenty of corrosion at the bottom of the radiator. No fluid leaking that I could see, but wanted to do this while the engine was out (and never hurts to improve the 355 cooling system)
  8. UConn Husky
    4,425
    CT
    Jay
    #108 UConn Husky, Jun 25, 2008
    So the last major step was the reason I took this thing out in the first place, replacing belts and setting timing. I checked timing using the WSM technique with a dial indicator measuring valve lift. It turns out it was pretty close as is, but not spot on (i.e. more than one pin off on the cam gear). Since this is all new to me...I just couldn't stomach the chance of reinstalling the engine and having it not run perfect. So for this crucial step I enlisted the help of Dr_Ferrari on Fchat, Jim of Pocono Sportscar. I couldn't be happier with the experience, learned a ton and can't get enough of his stories about test driving new F40's!
    First pic is of the setup for measuring TDC, used a plastic rod through the spark plug hole, centered through a wrench on top. I used the same basic setup for measuring lift, except with an angled pin on the end of the dial indicator to contact the bucket and avoid the cam lobe.
  9. UConn Husky
    4,425
    CT
    Jay
    #109 UConn Husky, Jun 25, 2008
  10. 285ferrari
    Sponsor
    Sep 11, 2004
    20,983
    MD and NE
    Robbie
    Almost there!!!!!!!!!!!!!!!!
  11. UConn Husky
    4,425
    CT
    Jay
    #111 UConn Husky, Jun 25, 2008
  12. UConn Husky
    4,425
    CT
    Jay
    #112 UConn Husky, Jun 25, 2008
    Maybe a bit out of order, but here's the degree wheel I used - a .jpg printed out oversize and laminated. Used the bent wire to indicate TDC once I found it...
  13. 285ferrari
    Sponsor
    Sep 11, 2004
    20,983
    MD and NE
    Robbie
    I know of another yellow F1 car like that...:D
  14. UConn Husky
    4,425
    CT
    Jay
    look familiar?? :D
    Next step is connecting everything...right now working on the front brakes (stainless lines, painting, etc.) Also removed the leaking Interstate battery; it always worked fine, but replacing with what seems to be the best battery out there, Sears Platinum P1. It's an AGM battery with 880 CCA - good for F1 cars that need to run the pump for a bit before starting. Consumer Reports gave it far and away the best rating...not cheap at $189, but worth it for my 355 ;)
    http://www.sears.com/shc/s/p_10153_12605_02850034000P?vName=Automotive&cName=Batteries+%26+Chargers&sName=Automotive+Batteries
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
    I LOVE IT!!!!!!!
    OUT FRICKIN STANDING JAY!!!!
  16. ernie
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
    That is a sweet dial Jay!
    How do I get ahold of that jpg so I can have one made up?
  17. PAP 348
    Dec 10, 2005
    100,246
    Mount Isa, Australia
    Pap
    Cool pics Jay. :):)
  18. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    Freaking awesome man! I bet you are itching to get her running so you can go for a spirited drive knowing all those small details (as well as the big ones) are taken care of.
    Great work, I may need some advice in 3 odd years when mine needs its next major.
    Thank you for sharing the photos.
  19. UConn Husky
    4,425
    CT
    Jay
  20. UConn Husky
    4,425
    CT
    Jay
    Front brakes are painted, rotors and calipers. Anyone else looking to do the same thing to their calipers? (pics of the rear calipers are a few pages back). I have 4 stencils left over, enough to do a set of brakes if you don't screw any up. And here's the trick so you don't make my mistake...spray on two very light coats first (for the letters; light meaning it almost looks speckled, not a solid layer), let that dry for about 5 min. Then spray on the finish heavy coat and take the stencil off quick before it dries, say within a minute or two. If the paint starts to dry you'll tear off corners of the letters when the stencil comes up. My finished product isn't perfect, looking close there is a little bit of bleeding and corner tears, but standing back looking through the wheel they are fine.
    First Fchatter to send me a PM with an address can have the 4 extra stencils.
  21. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
    Jay, how close is your front bumper to the ground when putting the engine back in via the jack method? Looks very close in one of the photos.
  22. UConn Husky
    4,425
    CT
    Jay
    #122 UConn Husky, Jun 30, 2008
  23. redryder
    redryder Karting
    May 30, 2008
    100
    usa
    george
    Jay, those cam pulleys look really nasty....any reason why you didn't clean them up?
    Which tensioners and cam o-rings did you go with....Hill E??
    How did you set belt tension for cams, and accessories(a/c,ps,wp,etc.).
  24. ernie
    Nov 19, 2001
    22,629
    The Brickyard
    The Bad Guy
  25. 2MS
    2MS Formula Junior
    Oct 5, 2004
    342
    Bay Area, CA
    Mark
    This is awesome thread! Kudos to you for being a brave soul. Please keep it going and post some more pics!!
