355 F1 gearbox warning light | Page 2 | FerrariChat
Discussion in '348/355' started by rscorer, Jul 28, 2014.
  1. F1moving
    F1moving Formula Junior
    781
    BUCKeYe!
    Marcus
    I'm sure is stored a code, hopefully anyhow!
  2. F1moving
    781
    BUCKeYe!
    Marcus
    #27 F1moving, Aug 18, 2014
    So I was talking to a fried today that has a 99F1, he had the same issue that I had forgotten about. His started a few hundred miles after his last engine out. After multiple trips back to the shop that did the work, he ended up taking it to the dealer. They discovered a pinched F1 wire causing the issue. Fixed and never had the issue since. May be something to look into.
  3. rscorer
    rscorer Rookie
    May 19, 2008
    23
    Richard
    Thanks, I'll pass that on as it is still with the dealer. It repaired itself on the way in only to break on my first trip getting it back, on the motorway at 70mph. Lovely. Just watched the speedo plummet. No change in the engine, nothing else apparent.
    Drove home, and thankfully it remained broken for the technician to take a look. They found a badly soldered wire, but repairing that didn't fix it. It apparently stops working when warmed up to a certain point, and then stops for the rest of the day - at least that's what they're finding.
    Now they've ordered a sender to try that!
  4. F1moving
    781
    BUCKeYe!
    Marcus
    Ouch, what's that cost?
  5. rscorer
    rscorer Rookie
    May 19, 2008
    23
    Richard
    £286
    I'll be very happy if it fixes it though! The trick seems to be making it reproducible, once they can see the problem they can fix it. (Sounds obvious :)
    Cheers,
    R.
  6. rscorer
    rscorer Rookie
    May 19, 2008
    23
    Richard
    I wish :)
    No codes pertaining to the issue - plenty showing that I'd "stalled" it into 4th and above, but none to do with the speedo not working.
    Had same issue when the engine mount collapsed. The computer never expected to be disconnected, so never recorded that error.
    R.
  7. spiderscott
    spiderscott Formula 3
    1,662
    Ratarossa HQ UK
    Ratarossa
    What was the fix for this in the end ?
    My F1 has literally just gone the exact same thing today
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Whats the car doing?.
  9. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  10. Qavion
    Qavion F1 World Champ
    14,674
    Ian Riddell
    spiderscott likes this.
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    If you take the tire and inner fenders off you should b able to work from. The sideor just go from underneath
  12. phrogs
    phrogs F1 Veteran
    7,378
    Kzoo Michigan
    I used a open/boxed end wrench maybe even an adjustable wrench, you only need to break it loose. It will spin out by hand after that.
